Justification/Rationale for not investigating a nonconformance
Q
QA Systems Manager
I am looking for some examples of justification and or rationale for not investigating a nonconformance. Preferably something that an auditor would find acceptable! We all have instances in our plants that we deem doesn't warrant an investigation...how do you write that into a justification or rationale to show compliance to 820.90? Thank you.
achorste
Re: Justification/Rationale
Has the non-conformance been investigated & solved before? (ie did the non-conformance occur before previous corrective actions were implemented)
Can you justify it statistically? If the non-conformance is a very small proportion of the total you may be able to justfy it as being too small to bother with.
It all depends on the nature of the non-conformance, the risk associated with the non-conformance and the cost implications of investigated / correcting / preventing the non-conformance.
Please provide a bit more detail (as above).
It would be helpful to know what kinds of non conformance you have found to be not worth investigating.
Most standards are pretty clear that a real nonconformance mus tbe investigated and corrected. In that light, one might say that if the nonconformance isn't real (the auditor didn't have his or her facts correct) then you woudln't have to investigate further; just prove it's not real.
Q
QA Systems Manager
Hi, good questions. Sometimes the quantity is low, 1 out of 200. I like your statement, "a real nonconformance", maybe that is an idea. I am looking at nonconformances identified by inspectors, and then dispositioned by Quality Engineer or Process Engineers. What would prove that it is not real?
Sidney Vianna
Post Responsibly
(ie did the non-conformance occur before previous preventive actions.
If it already happened, there is no preventive action possible.
Only if the products were incorrectly rejected. I.e., the inspectors rejected an acceptable product. But even that would require an "investigation".
ISO 13485 is pretty clear about the need for an investigation. What might happen is that, after investigation, a determination is made that no corrective action is justified nor necessary.
RoxaneB
While I'm not in the medical profession or field and, quite honestly, the sight of blood or even the mere mention of it makes me queasy.....I can talk about nonconformances very easily! :rolleyes:
1. Define a nonconformance at your site...the parameters for what makes a nonconformance a nonconformance
2. Define triggers for when you will take action...and to what level action will be taken.
3. Formalize process.
4. Record data.
5. Review nonconformances on a regular basis.
6. Adjust definitions for nonconformance and triggers accordingly.
Here's how we look at...
If the process has an unscheduled delay of let's say 5 seconds. There is no impact to the product. Machines are still okay. We don't sweat it. We do, however, record the fact that the delay occured, where it occured, when, etc.
If the delay was 20 minutes, that's more of an issue and we do all the above, but resolve the issue and get back to making product.
If the delay is 40 minutes, wow! That's caused a lot of problems and we'll do a full-blown corrective action on that nonconformance.
But we also have stats on our process that back us up on our defined triggers. And, as we start to see the larger problems decrease in number, we start to lower our triggers so that we can still focus on nonconformances.
This approach also helps in the demonstration of continual improvement.
Ajit Basrur
I am not sure if you can do away with an investigation.
21 CFR Part 820.90 says -
(a)Control of nonconforming product. Each manufacturer shall establish and maintain procedures to control product that does not conform to specified requirements. The procedures shall address the identification, documentation, evaluation, segregation, and disposition of nonconforming product. The evaluation of nonconformance shall include a determination of the need for an investigation and notification of the persons or organizations responsible for the nonconformance. The evaluation and any investigation shall be documented.
Being in the medical devices, I would definitely initiate an investigation with corrections and corrective actions but may or may not include preventive actions. This all depends on the type of nonconformance.
PS - you referred section 820.90 which is applicable for the product and not for non product conformances.
trainerbob
The time spent justifying the non-investigation of the non-conformance would be much better spent taking care of the issue. I certainly don't know your particualar issue, but remember that we need to work at improvement, not avoidance or justification for non-action. If these are internal issues you are dealing with and they are not "true" issues then it sounds like internal auditor training is your real problem, rather than justification of non-investigation of items that don't pertain to your quality management system. This is the type of rationale that an auditor can understand and live with.
J Sampling Plan Justification and Rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P Reference Only Gages - "For Reference Only" Rationale (Reasoning/Justification) General Measurement Device and Calibration Topics 25
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
B Per 21CFR 820.198 (b) - Justification for no investigation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
M CER Adverse events - Justification of databases searched EU Medical Device Regulations 5
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
O Statistical justification of sampling size in V&V tests ISO 13485:2016 - Medical Device Quality Management Systems 5
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J Calibration Justification - Requirements for Measurement with a Calibrated Device General Measurement Device and Calibration Topics 1
SATHYABALARAMAN Exclusion of IATF 16949 Clauses - 8.5.5.1 & 8.5.5.2 & Justification IATF 16949 - Automotive Quality Systems Standard 9
N Sample Size Justification for Medical Device Shelf-Life Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
B EMC Repeat Justification - Reducing NRTL testing required after modification of ME IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Biocompatibility omission justification for FDA 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
G Exemption Filing / Exemption Justification RoHS, REACH, ELV, IMDS and Restricted Substances 9
H Factory Dictated Sample Size Justification Statistical Analysis Tools, Techniques and SPC 9
J Justification for Exclusion of Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 8
S Justification of Lifetime of a Medical Device including Component Aspects ISO 13485:2016 - Medical Device Quality Management Systems 13
C Justification for No CAPA in Complaint Files Nonconformance and Corrective Action 24
Q Sample Size justification for IEC 60601-1 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Wes Bucey A justification to take HR out of hiring Career and Occupation Discussions 3
S Establishing an MSA Plan and Justification Suggestions wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Sampling Plan - Sample Size Justification for a Bottling Cleaning Process Validation Qualification and Validation (including 21 CFR Part 11) 2
M Justification for Month End Calibration Date Calibration Frequency (Interval) 24
X Justification of Decrease in Receivables, Increase in Negative Cashflows Coffee Break and Water Cooler Discussions 2
S MDR (Medical Device Reporting) Justification - Canned Statements Other US Medical Device Regulations 2
P Out of Tolerance Gage - Justification for not Recalling Product Misc. Quality Assurance and Business Systems Related Topics 7
Wes Bucey Justification for organization's tax-exempt status? Funny Stuff - Jokes and Humour 1
C Looking for Skills Matrix & Justification of skill levels. Document Control Systems, Procedures, Forms and Templates 5
A Justification for not performing overseas supplier audit General Auditing Discussions 6
G Justification for Supplier Quality Engineer Career and Occupation Discussions 3
M Justification for not doing Gage R&R Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J Medical Device FMEA Occurence Rating Scale Justification FMEA and Control Plans 3
J What would be the justification for exclusion of ISO9001 clause 7.5.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Software Justification in a Lean Environment - Convincing Management Lean in Manufacturing and Service Industries 12
R Frequency of self control and costs - Justification for 4 Hours vs. Every Hour IATF 16949 - Automotive Quality Systems Standard 2
N CE Mark Auditing - All they had for CE was a written Technical Justification EU Medical Device Regulations 5
R Cost Justification Based Upon Intangibles - Cost of Quality Misc. Quality Assurance and Business Systems Related Topics 4
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
I Device modifications - Clinical sample size rationale EU Medical Device Regulations 5
R Rationale for changes to ISO Standards Other Medical Device Related Standards 4
S PMCF (Post Market Clinical Followup): Rationale for Exemption - Software Medical Devices EU Medical Device Regulations 6
D Rationale for Risk Acceptability Matrix - ISO 14971 ISO 14971 - Medical Device Risk Management 9
S Literature Search - Notified Body Had Questions About our Rationale CE Marking (Conformité Européene) / CB Scheme 9
M Rationale for 60601-1-2 Accompanying Documents Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Please explain Medical Device Product Classification Rationale 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Revising Declaration of Conformity and Classification Rationale EU Medical Device Regulations 2
Z Example of a Classification Rationale Statement CE Marking (Conformité Européene) / CB Scheme 3
