Kanban Sizing Formula
P
processanalyzer
I have been working on Kanban sizing and found this helpful formula. I thought I would share it with the Networking Forum.
The formula:
Where,
Y: number of cards
D: demand per unit of time
T: lead time
C: container capacity
X: buffer, or safety factor
For example, suppose that hourly demand was 200 units, lead time was 12 hours, and the container capacity was 144 units. Assume that there was variation in lead time or demand, then we can set the safety factor to 15%:
Y = ((200*12)*(1+.15)) / 144= 20 Kanban Cards
How many hours worth of demand will 20 cards represent?
(20 cards * 144 units) = 2880 units
2880 / 200 units per hour = 14.4 hours worth of material
As you can see, this simple yet effective visual approach that encourages flow, reduces the need for forecasting — and all forecasting is almost always wrong no matter which model you choose — and the Kanban reinforces coordination and cooperation within a system.
I found this from Shumla (Blog). It is much easier than the formula I had been using from John Constanza JIT.
Hope this is helpful to someone else! Forward to me from network affiliate Rosemary.:magic:
W
wmarhel
Hi processanalsyzer;
Here's something to think about. The use of kanban doesn't encourage flow, it used because their is an absence of flow within a process. The typically order is:
FLOW ---> FIFO Flow ---> Kanban ---> Batch
You use kanban because there is a disconnect between processes, possibly through distance or capacity constraints. Forecasting and kanban are very different animals. Forecasting has its place just as kanban does. Forecasting is a planning technique that even Toyota uses. Whereas forecasting is for planning, kanban is for execution within a process/factory/supplychain.
John Constanza of JCIT (John Costanza Institute of Technology) is the creator of DFT (Demand Flow Technology). He applied mathematical models to production processes in order to take out some issues that occur people. It is a solid method, but I think the absence of people involvement when compared to Toyota, is also one the weaknesses within the system. One of the spreadsheets I've posted here on the cove is based on the DFT methodology. I've seen factories using DFT that worked very well.
What the DFT crowd refers to as an In-Process Kanban (IPK), the lean crowd might refer to it as a supermarket or even just a small FIFO area between two stations in order to account for imbalances.
Wayne
B Kanban - What is the pulling force which triggers replenishment? Lean in Manufacturing and Service Industries 7
B Implementing and Rolling Out a Kanban System to Dictate our Scheduling Lean in Manufacturing and Service Industries 3
M If a process has one basic raw material, can I use Kanban? Lean in Manufacturing and Service Industries 2
K To use Kanban or Not for 300 of our 5000 Products Lean in Manufacturing and Service Industries 4
M Kanban vs. Line Balancing - Process Engineering our Warehouse Process Lean in Manufacturing and Service Industries 3
B Kanban Agreement Template wanted Lean in Manufacturing and Service Industries 1
M Using a Kanban Lifecycle for the Software Development IEC 62304 - Medical Device Software Life Cycle Processes 8
F Trend Analysis of Kanban System for our Finished Goods Statistical Analysis Tools, Techniques and SPC 6
R Kanban Work Instructions / Procedure for reference Lean in Manufacturing and Service Industries 4
P Kanban Supply Agreements - Any content ideas? Lean in Manufacturing and Service Industries 6
O Kanban - What procedures with which priorities should I implement Lean in Manufacturing and Service Industries 3
P Small parts trouble Kanban - Problems with the common small/bulk parts Lean in Manufacturing and Service Industries 8
A Running MRP and Kanban on the same blank/part - Is this possible? Lean in Manufacturing and Service Industries 3
B Kanban Calculation - Correct Kanban Sizes Lean in Manufacturing and Service Industries 4
A Economic Order Quantity - Implementing Kanban Supplier Quality Assurance and other Supplier Issues 8
A Kanban cards for single pull - Looking for template Six Sigma 2
S Developing a Spares System - 2-bin Kanban System the best option? Lean in Manufacturing and Service Industries 3
Y Visual Kanban Board & Job Ticket - Label Printing Industry Lean in Manufacturing and Service Industries 17
L Kanban cards - Trying to initiate a true Pull System - Fastener Products Lean in Manufacturing and Service Industries 3
R Operation sign-offs and test stamps for KanBan cards - Inspection stamp ink smears Lean in Manufacturing and Service Industries 2
P Help me with this Kanban/CONWIP case! Lean in Manufacturing and Service Industries 1
S Kanban System Game - A Computer Simulation Quality Tools, Improvement and Analysis 1
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
I Formula in the Annex of IEC 61000-4-3 - How is k=7 determined? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
L Signal-to-Noise (S/N) Ratio formula check Design and Development of Products and Processes 2
S Scrap % Calculation Formula Manufacturing and Related Processes 10
P IF formula - Excel 2003 Excel .xls Spreadsheet Templates and Tools 4
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
M Should I use binomial or Poisson distribution formula? Statistical Analysis Tools, Techniques and SPC 6
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
M Formula for Bell Shape in Excel Using Minitab Software 1
M What is the formula to create a bell curve? Excel .xls Spreadsheet Templates and Tools 8
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
B Attrition Rate and the formula to calculate Attrition Rate Quality Manager and Management Related Issues 1
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
