Keeping your Windows PC running Smoothly
Bob_M
I enjoy fixing/reformatting friends' & family's Windows PC as needed.
I do my best to install lots of protection for them. I also try to teach them how to properly keep their PC safe, up to date, and running smoothly as long as possible.
I have a Word File that I update as needed. Please take a look at my document. I'm looking for suggestions/comments additions/corrections.
Hopefully my doc might help you or your less Windows-Literate friends :rolleyes:
chaosweary
Windows = "Send Error Report"
Boy what a sore spot for me. My windows 98 running on an Intel P3 333mhz platform with Office software for that era runs faster than my Dell Win XP with Office Pro with a Pentium 4 3.6GHZ.
I guess another tip would be if you can afford it, have two computers. One for the internet that you can experiment with and load and unload software at will and one for purely SOHO business purposes. (this model has worked the best for me).
I load and unload software like crazy and it still screws up the registry even in XP. Unloading software still leaves footprints and unassociated filenames. Even with 1 gig of ram, memory still gets clogged and never truly clears after a program is terminated. "Cleaning" or "tuning" software usually just makes things worse. I am not impressed with XP.
:mad: Another thing that gets my goat is that all these software makers just assume your computer is hooked to the internet, some even require internet registration, what a scam.
Installing and uninstalling software will not "screw up" the registry in an NT system. There seems to be a widespread fallacious belief that programs, when needing a registry entry, must scan the whole registry until the entry is found. Under such a scheme, it would make sense that when the registry becomes "bloated" things will slow down. The problem is that the registry doesn't work that way, and programs can and do go directly to the relevant entries, so the relative size of the registry is irrelevant. Orphaned registry entries take up a small amount of disk space, but other than that there really isn't any harm being done. The exception would be an orphaned entry that tries to load a process at startup, but that's the fault of the uninstalled programs own uninstall routine, and not the fault of the OS. In those cases, Task Manager can be used to identify and kill the offending process, and MSconfig can be used to stop the process from loading. As for RAM getting "clogged," that's a fairly rare occurrence (more common in 9x systems, btw) and is almost always due to misbehavior of an application, not the OS.
Bob_M
As far as the registry being bloated:
A word of caution: Registry cleaners sometimes cause more harm than good. I've had bad experiences with Norton's Systemworks' registry cleaner.
However knowing how to use MSCONFIG and similar problems can help speed up your boot time and removed unwanted/unnecessary programs from starting.
That's not something quite covered in the document, but I do alot of tweaking before I return a computer.
I use a program called AutoPatcher to get all of the post-SP2 updates and MANY useful tweaks. I also use TWEAKXP alot (included with Autopatcher - found in control panel after install). However, if you don't know what you're doing, you can screw it up worse. :frust:
Bob_M
Jim Wynne said:
Good job, Bob:agree1: . I've added a few comments and suggestions to your file. Thanks for sharing--if everyone would take your advice, all of us would be a lot safer.
Thanks for the comments/corrections.
IEVIEW - I use it. I just didn't think about it for the list
Firefox ActiveX - I didn't realize it didn't run ActiveX by default, but I think that's why its safer for most "newbies" - I still use IE but very rarely
Password Manager - I just added that today - I don't know of any bad ones by name, but I'm sure some are actually bad and will try to steal your info (user beware) - Depending on the person, they might forget their passwords over time and are screwed if their computer dies or password manager breaks - It all depends on the person
Downloaded/Free games - Good luck finding what HIDDEN stuff might be in the EULA - Most spyware scanners will find them after the fact, but as a rule of thumb people just shouldn't download the "free" stuff - Use at own risk
I give this list to "newbie" and people who had done just about everything wrong from my list. Alot of people, just have no idea what they should/shouldn't do to keep their PC's safe and running.
IMHO - XP was not the cure to computer safety problems like Bill Gates claimed it was! :mad: :bonk: :nope: It may crash less, but its still far from safe. (To bad I don't know how to setup Linux for myself at home - But I like to many Windows-Only software).
Domoreto
Registered Visitor
Hi. Very interesting and helpful collection of tips . :applause:
Few more, which may help :
- Using Download manager ( helps , especially if using unstable Dial-up connection) which can split the downloaded files into few parts and will continue download if interrupted ( Chose on carefully - some are Shareware , some are Adware (brrrr) ( I'm a fan of Fresh Download from - www.freshdevices.com - it is clean and reasonably working freeware)
- Check the downloaded stuff with antivirus (build in freshdownload)
- Monitoring the Start-up programs - easiest way - Start-Run- MSConfig -Startup - then remove all the non-daily used stuff ( if not sure - use "search:" to try and trace the suspicious startup entry) ( CC- normally stands for Norton Products...., etc..)
- back-up data monthly - not the programs but docs , spreadsheets, pix, etc. ( use WR DVD-s ). ( Backup the data after full virus scan )
- If some virus /intruder is detected by your Antivirus /Anti spy ware , before cleaning - disable your System Restore .
- After un-installing some program - use some reg.cleaning software ( don't do it if not sure)
To Long?
OK . Enough for now :bigwave:
chergh - 2008
A few things I would add:
1. Got ADSL? Buy a router with a hardware firewall, a hardware firewall is essential for when connecting a new computer or a fresh install to the internet for the first time.
2. Don't download anything that isn't from a site you trust
3. Never enable macros on MS office documents unless you know they are dafe
4. Get a spam filter for your email client
5. Don't use Outlook Express, get thunderbird instead
6. Never click on any spam ever
7. Someone offering you a few million to help them move some cash/gold/oil etc are not genuine. Try a google for 419 if your not familiar with these offers
8. Dont blindly click on links. http:\\www.microsoft.com
See what I mean now imagine if that is your bank and some fraudster has set up a page to look exactly like your banks page. You would probably put in your log in info.
P MDR Article 27 - UDI - Keeping records of UDIs EU Medical Device Regulations 1
A Keeping the Usability File up to date IEC 62366 - Medical Device Usability Engineering 2
K Not keeping CE mark for some devices CE Marking (Conformité Européene) / CB Scheme 1
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
U Manufacturing solutions and keeping records on quality Content CE Marking (Conformité Européene) / CB Scheme 3
Sidney Vianna Are the Accreditation Bodies doing their job? Keeping CB's accountable? Registrars and Notified Bodies 0
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
S Employee Training Matrix - Keeping track of employee training on various SOPs ISO 13485:2016 - Medical Device Quality Management Systems 4
M Keeping up with "State-of-the-Art" & updated Standards EU Medical Device Regulations 11
S Keeping track of the changing Medical Device Standards Other Medical Device Related Standards 3
S Corporate Quality Manager keeping me out of the Management Review Meeting Management Review Meetings and related Processes 28
S Is not keeping inspection record an ISO 9001 nonconformity? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
knightarmourus Keeping the test samples in after market nlight alloy wheel production Manufacturing and Related Processes 2
A What is the definition of Installation that requires Record Keeping vs Set-up 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Implementing ISO 3834-2 - Keeping the organization informed Other ISO and International Standards and European Regulations 3
L Keeping current on new/revised MEDDEVs EU Medical Device Regulations 8
S Requirements for keeping Records in Electronic Format Records and Data - Quality, Legal and Other Evidence 15
D Keeping Same Medical Device Name but Changing Classification Medical Information Technology, Medical Software and Health Informatics 3
M Keeping Packaging Material and Photographs in Sync with Inventory Manufacturing and Related Processes 5
R FDA Rules and Requirements for Keeping Ink Signed Documents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
M Quality Procedures - General Detail Level and Record Keeping Requirements Document Control Systems, Procedures, Forms and Templates 6
J Annual PPAPs - Keeping Up with Hundreds Of Customers And Hundreds Of Part Numbers APQP and PPAP 12
I Keeping up with changes to External Standards Document Control Systems, Procedures, Forms and Templates 8
T Keeping Track of Procedure Implementation Training Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Keeping Milk for Domestic Consumption Fresh - - Ideas? Coffee Break and Water Cooler Discussions 33
C Keeping Employees Updated on Newly Revised Procedures Document Control Systems, Procedures, Forms and Templates 15
A Document Relationship Matrix - Keeping Track of References to Related Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Wes Bucey Keeping your cool means keeping your job Career and Occupation Discussions 12
M Employee Turnover vs. Keeping up with Training Training - Internal, External, Online and Distance Learning 7
L 5S Auditing & Accountibility - Keeping our 5S tool boards complete and accounted for Lean in Manufacturing and Service Industries 13
J Keeping Gage R&R Samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Keeping Records of Competence of Employees Records and Data - Quality, Legal and Other Evidence 4
S Keeping Employee Self-Motivation Strong Human Factors and Ergonomics in Engineering 23
ScottK 15 year record keeping requirement? Components for Medical Devices Records and Data - Quality, Legal and Other Evidence 16
Casana Keeping old ISO certificates of registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Keeping up with all those changes! Document Control Systems, Procedures, Forms and Templates 5
B Keeping an External Auditor on because he's "useless"... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 55
Marc Paying Attention and Keeping Eyes Open - Girl Falls into Floor Funny Stuff - Jokes and Humour 4
R Keeping the Passion of an ISO9001 System - How to promote your QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
H Keeping Control of Controlled Documents Document Control Systems, Procedures, Forms and Templates 21
C Keeping ISO TS 16949 Certification During Forced Production Interruption IATF 16949 - Automotive Quality Systems Standard 2
A Keeping prototype devices - Is there a regulatory or compendial requirement? ISO 13485:2016 - Medical Device Quality Management Systems 3
Wes Bucey Keeping the job and angling for promotion Career and Occupation Discussions 7
H Keeping a Stable Process for a company, any suggestions? Should I being doing more? Quality Tools, Improvement and Analysis 5
K Struggling with keeping part-time internal auditors in our program Internal Auditing 15
T Occurance of Non-Conformance, MRB (Material Review Board) and Record keeping Records and Data - Quality, Legal and Other Evidence 34
Marc Contract Firms Keeping Training Records Records and Data - Quality, Legal and Other Evidence 2
E Record Retention - NC for keeping records longer than our defined minimum Records and Data - Quality, Legal and Other Evidence 9
G Keeping Horses in the City Coffee Break and Water Cooler Discussions 13
apestate Keeping Procedures Simple - 15 person machine shop using text procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
