Kinds of plastic for molded parts in a main frame as structure
markpinto
Hi Folks
I have a small machine to design that the client wants to use molded plastic in a larger role. previously they used molded parts for what I call inconsequential items, rollers knobs and things that are easily replaced and are usually wear items. now they want to use molded parts in the main frame as structure or as adjoining parts in a framing capacity . Has plastics progressed far enough for that? if so what kinds are being used successfully for these things, I envisioned the unit still having a light steel structure and use the plastic to fill out the bulk of a part so the plastic doesn't have to deal with as much force by itself. or even laminating the molded parts with steel. The units have to have a nice fit and finish like a consumer product when done. Ultimately they admitted they are going for a more flowing and rounded look. their competitors use thermoformed covers on ugly structure to get their look but thats not what they want, they want this look built into what would normally be pretty angular sheet metal bodies. Damn it's getting too busy ..
Ninja
Looking for Reality
I can't comment on types of plastics...not my forte...
But for design and "sexy" which seems to be in the mix, you may want to consider tolling out for 3D printing or "additive manufacturing". You have a lot more design freedom there, and don't need the molds.
Check it out and see if it is appropriate for your work...
Ronen E
Problem Solver
Moderator
Hi Markpinto,
Well, I'm a mechanical engineer by education and plastics happen to be my expertise on the engineering side... Sounds like you stumbled upon that field, but let me assure you that what your client is looking for is quite mainstream today.
Definitely!!! The range of materials, design tools and techniques and array of applications and "precedents" are just astonishing compared to even 25 years ago (when I first entered the world of plastics). Today even under-the-bonnet automotive metallic parts are being substituted for plastics, not to mention things like home appliances and business machines (including frames and other load-bearing non-wear parts).
There's a wide range, and typically the best material is selected for each part. There are high-heat grades, high-strength grades etc., and if your strength / rigidity requirements are really high there are also composite grades, eg fibre-reinforced plastics (glass fibres, carbon fibres etc.). In a project like yours, a plastics design engineer is usually involved, both for material selection and for engineering analysis. In most settings I've seen, that person is also the part designer or works in tandem with an industrial designer (where looks are paramount).
No need for any of that today, unless the application is super-demanding. Plastics are the material of choice for design and artistic flexibility, and with the right amount of engineering (not too much is required in most cases) functional / performance requirements can be met as well.
Cheers,
Ronen.
PS If you want to go deeper into specifics of the machine / project, please feel welcome to send me a private message.
Ninja
Looking for Reality
... things like home appliances and business machines (including frames and other load-bearing non-wear parts).
There's a wide range, and typically the best material is selected for each part. There are high-heat grades, high-strength grades etc., ...
At the risk of derailing the thread (which I hope I don't do)...
If there are high strength grades...I've been looking ofr high strength plastic floor joists...are they around yet?
Not suspended...sitting right on a damp concrete slab...just need to hold up the raised floor.
Ninja
Looking for Reality
Do you mean something like that?
Yes, precisely...Thanks for the lead!
$80+ each for a 10' section...ouchers. I think I'll just strip a plastic deck board and put it on the bottom of a wood joist...
NikkiQSM
I work for a plastics compounder. While most of what we produce is medical, we do produce industrial plastics as well.
The first step is to determine the specifications you want.
What would be the minimum impact strength, or other physical properties?
What is the desired cost? Some resins you purchase could only be $1.00 a pound, while others can be $80.00 a pound. So you will want to pick and choose while keeping costs in mind too.
Are you molding this resin? If so, you may want to consider cycle time as well. You will want a resin that can quickly set before being removed. A resin with a long cooling time can result in slower progress.
I would recommend speaking with whomever does your design and development.
Ronen E
Problem Solver
Moderator
I would say cycle time is affected much more by the geometrical design of the part and by the IM tool design than by the selected polymer grade (though that does have some effect too).
Cycle time really matters when the quantities are big and each piece is expected to be super cheap. For a machine / appliance housing I'm not sure it's that critical.
D Different kinds of Risk Analysis for various Hazards ISO 14971 - Medical Device Risk Management 3
N What are three kinds of flow in Lean or Six Sigma? Lean in Manufacturing and Service Industries 4
M One Fluid, two kinds of Fluids...? Coffee Break and Water Cooler Discussions 3
F ISO 13485 & FDA Requirements - What kinds of software require validation? ISO 13485:2016 - Medical Device Quality Management Systems 2
R If ME equipment of any kinds should have NRTL mark when sold in North America? IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
A Process Audits for 1200 different kinds of Tube Sizes Process Audits and Layered Process Audits 9
K Inquiry on kinds of document a customer is requiring us to submit? Quality Tools, Improvement and Analysis 2
Q Charts and Diagrams as Controlled Documents - Do all kinds have to be controlled? Document Control Systems, Procedures, Forms and Templates 3
M Deburring plastic medical device Manufacturing and Related Processes 1
A Validation Plastic Injection Molding Process protocol ISO 13485:2016 - Medical Device Quality Management Systems 5
Stoic Details of Operational Qualification (OQ) test design for plastic extrusion processes, effect of material property noise, and GHTF/SG3/N99-10 US Medical Device Regulations 2
R Suggest modern equipment/instrument for plastic bottle inspection? Quality Tools, Improvement and Analysis 1
S Impeller Unbalancing inconsistancy on plastic impellers Manufacturing and Related Processes 0
M How to measure a plastic cap General Measurement Device and Calibration Topics 19
I Class VI certification on seals, o-ring and plastic for a WFI system Qualification and Validation (including 21 CFR Part 11) 0
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
D Measurables for Plastic Injection molding process Manufacturing and Related Processes 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
A Help establishing regulatory requirements - Plastic dental cartridge syringe US Food and Drug Administration (FDA) 0
C ABS plastic : which IEC 60601-1 tests to redo? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Glass and brittle plastic Policy - Required per FSSC 220002-4? Food Safety - ISO 22000, HACCP (21 CFR 120) 0
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Nicole Desouza AS9100D - Calibration of Dies & Tooling - Plastic Extrusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Fernando Drumond Calibration and Control of Plastic Volumetric Measurement Instruments General Measurement Device and Calibration Topics 1
erozas2003 Color test on molded plastic parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 5
M Informational 2019 Meeting Materials of the General and Plastic Surgery Devices Panel Medical Device and FDA Regulations and Standards News 0
M Informational The USFDA Announces General and Plastic Surgery Devices Panel of the Medical Devices Advisory Committee Meeting on March 25-26, 2019 Medical Device and FDA Regulations and Standards News 0
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
John Broomfield Cleaning plastic from our oceans - The Ocean Cleanup Venture Sustainability, Green Initiatives and Ecology 33
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
A Cleaning plastic parts for sterilized medical devices ISO 13485:2016 - Medical Device Quality Management Systems 15
smryan Chemistry and physics of plastic behavior - Any plastics experts in the house? Coffee Break and Water Cooler Discussions 1
K Sampling Plan for transparent tubular plastic parts from 32 different cavities Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Finishes on Plastic Molded Parts Manufacturing and Related Processes 9
D Hot Plate Welded Plastic Strength Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Testing Large Plastic Pipe Imported Legacy Blogs 0
L Product Requalification for Plastic Injected Parts APQP and PPAP 3
A Plastic Injection Molding Process Troubleshooting Guide Manufacturing and Related Processes 1
T Customer Requirement for Sorting - Visual Defect on Plastic Part IATF 16949 - Automotive Quality Systems Standard 9
M How to fix a plastic bag on leg with a bandage to take a shower Coffee Break and Water Cooler Discussions 15
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
M Lot Numbers of Plastic Disposables in an LDT (laboratory developed test) ISO 13485:2016 - Medical Device Quality Management Systems 6
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
N What Can I Do With Plastic Pellet Scrap? Manufacturing and Related Processes 17
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
