KPI for time to close NCs (Nonconformances)
JudyLJ
We have determined that one of our KPI's will be the time it takes to close our non-conformances. Has anyone ever used this as a KPI? And what is the best way to track this visually. Right now I have an excel log that I track the open and closed dates, but I want an idea on how the graph this so that it makes sense.
Judy :confused:
Randy
Re: KPI for time to close NCs
Bad idea, depending upon the NC it could take anywhere from 10 minutes, 10 days, 10 weeks or even longer for a NC to be "corrected" & "effectively closed"
What you'll wind up with is short term fixes but not long term cures
insect warfare
QA=Question Authority
Welcome to the Cove! :bigwave:
It is true that this metric has been used by companies before (and still is), but I don't advise using it for this reason alone - not all nonconformities are created equal, thus the solutions will be different as well, in terms of resources used, people involved, and the time it will take to resolve each issue. Imposing an inflexible rule on time allocation will not give you any valuable indication of how effective your CA system really is, because of the aforementioned.
Much better KPI's to track would be "# of recurring issues" or "effectiveness of corrective actions". Having a low % of the former and a high % of the latter would indicate that you are running a successful CA program. Keeping track of "# of open CA's" is also common for most companies. My two cents....
Brian :rolleyes:
Steve Prevette
Deming Disciple
Still, I am a believer in cycle time metrics.
There are a couple of options here:
Plot the cycle time NC by NC
If there are a lot of NC's, plot them on xbar-R in groups of 5, or go with some time interval and plot the average cycle time and either highest cycle time or 90th percentile.
Plotting an average age of open NC's along with the cycle time chart can help you tell if you are building up an inventory of aging NC's.
Plot an age distribution for those NC's that are currently open.
Now, for the issue of "not all NC's are created equal", if you really have that issue, an idea is to assign due dates, and then track percent completed by due date. If extensions to due dates are allowed, track percent completed on time, without extensions.
Of course, except for the average age of open NC's, plot the charts in a SPC format.
Good points of caution about the downside of tracking time to close. If cycle time isn't the only metric AND you emphasize quality of action you can avoid this but it takes diligence and continual monitoring
Given that I would plot cycle time and I would trend it. But I wouldn't use the average I would use the median and plot the data monthly. You may also play with adding age of NCs that aren't yet closed as a seperate measure, otherwise you will only have a very lagging metric.
Bill McNeese
Just wondering what made you select the time to close NCs as a KPI.
This is something that should be tracked - good advice above on how to do that. How many do you have a month? That will determine how you track it.
But, I probably would not consider it as a KPI. There are too many other metrics that I would view as more critical. Not than NCs are not important, but hopefully you don't have too many. What other KPIs are you using?
JudyLJ
I agree will all of you, that this isn't the best thing to track, but I lost the vote!
We are also tracking rework and number of samples reported. We are an internal ISO 17025 acrredited lab. We could have 0 to 20+ NCs in a month depending if they are coming from errors, complaints or internal audits.
Some are closed with a simple correction to a procedure and some are some stay open for months, because we are trying to aquire new equipment etc...
This is our first attempt and KPIs. We are trying to align our functions to the manufacturing plants we serve.
The KPI for time NC is open was set up by others and now it's my job to do the tracking but it was set up to just graph the number of days open for each NC. the y axis is #days and the x axis is the NC number but when I close them and add the information, it gets dispersed within the graph. It doesn't make sense to me.
LUV-d-4UM
How about tracking the effectiveness of KPI from the Pareto charts that you generate periodically? If the problem occurs less and less then the Corrective Action is effective.
Stijloor
Not quite. The purpose of corrective action on Non-conformities is to prevent recurrence. So, no recurrences will be the measurement.
M Having Trouble Identifying KPI for Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Compliance Dept KPI Dashboard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G Kpi doesn't show action plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
D IATF mandatory KPI? IATF 16949 - Automotive Quality Systems Standard 15
Q KPI risk assessment - Criteria for the given score IATF 16949 - Automotive Quality Systems Standard 3
D Key Performance Indicators / KPI Review IATF 16949 - Automotive Quality Systems Standard 11
Jim Wynne Most Important Manufacturing KPI, per Oracle Coffee Break and Water Cooler Discussions 3
Enghabashy Supply chain main policies ,scope, risk assessments & relavant KPI Supply Chain Security Management Systems 2
K FAA Repair Station KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 15
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
V Informational SMMT IATF Oversight - OEM KPI Process IATF 16949 - Automotive Quality Systems Standard 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
qualprod Monitoring of lead time - Good KPI identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
qualprod On Time Delivery KPI for sales? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Level 3 KPI Excel Template Manufacturing and Related Processes 0
K A way to monitor our Internal Audits as a KPI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
M QMS Efficiency KPI as a Manager. IATF 16949 - Automotive Quality Systems Standard 7
J KPI Software - Our weakness is in KPI's Manufacturing and Related Processes 7
D KPI's Data for Customer Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S AS9100 Customer KPI Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R ISO 9001:2015 - KPI (Key Performance Indicators) vs. Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J KPI's for AS9100 Cl. 8.2/8.5 - Bids/Contract Review/Order Entry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K Further Analysis of Departmental KPI (Key Performance Indicator) Statistical Analysis Tools, Techniques and SPC 2
A KPI for Quality Assurance Team in a Service Oriented Industry Service Industry Specific Topics 8
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
1 KPI Dashboard Template in Excel Format wanted Excel .xls Spreadsheet Templates and Tools 9
Q Is KPI in Process Valid if not supported by Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V AS9100 8.2.1 (C) or 9.1.2 (D) Customer Satisfaction - KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A What KPI's do you use at Shop Floor Level and Team Boards? Quality Tools, Improvement and Analysis 4
W NCR Performance KPI Monitoring in an Industry like Construction Nonconformance and Corrective Action 1
armani Does KPI for Processes need to be correlated with the specific Risks for Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Excel Dashboard for Health Safety and Environmental KPI's for Multiple Sites Occupational Health & Safety Management Standards 3
Q Who can Change goals and kpi of top management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q KPI (Key Performance Indicators) for the Audit Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
L KPI Project help - Business and Management Degree Benchmarking 4
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A KPI's for Individuals (Employees) Manufacturing and Related Processes 10
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
P Internal Audit Scope - Company's KPI (Key Performance Indicators) Internal Auditing 7
S KPI for Q&EHS Management System example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
B Should CAR be issued when the KPI is not achieved ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Determining Processes, Objectives and KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R KPI Review Meetings never discusses previous meeting action plan status Quality Manager and Management Related Issues 5
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Safety Lead and Lag KPI's Quality Manager and Management Related Issues 5
