KPI Formula Issue - "Change Requests Managed" = Changed/Total
Z
zubairn
If my KPI is "Change Requests Managed" and the formula is: Completed Change Requests/Total number of Change Requests
If in a particular month the number of requested changes is 0 then denominator will be 0 and hence mathematically the result will be infinity. Is this ok or how should the KPI be adjusted?
thanks
Pancho
wikineer
Re: KPI formula issue
Chuck Norris could do it! :lol:
Kidding aside. Why don't you simply report the two numbers along with their ratio?
Here, for the ratio, you can copy and paste this: .
thanks
Welcome to the Cove. :bigwave:
What's your target? If your target is, for example, to have all change requests completed with in x days or weeks, you only have to track the elapsed time between submission and completion.
Z
zubairn
Well, i agree its a silly question but still....
when the formula is inserted in a balance scorecard tool. infinity would not show in the green graph area right...
the purpose of this particular kpi is just to indicate amount of work done (i know, not measuring quality or time aspects)
Pancho
wikineer
Ok, maybe an alternative KPI would provide you with a measure of the work done for your Scorecard with less math yoga. CR = Change Request. Here are a few ideas:
  • Net change in open CRs: CRs opened this period - CRs closed this period
  • Net % change in open CRs: (CRs opened - CRs closed) ÷ (open CRs at the beginning of the period + new CRs this period)
  • Your own, transformed 1: CRs closed this period ÷ (open CRs at the beginning of the period + new CRs) (note that you couldn't close a CR this period if you didn't have it open at the beginning, so no x/0 here. You might get 0/0 tho!)
  • Your own, transformed 2: (Completed Change Requests + 1) ÷ (Total number of Change Requests + 1). (there! Not even Chuck could 0 in this denominator.)
Good luck!
P
pldey42
When people are measured they try to make themselves look good. Therefore I think KPIs should be designed to encourage desired behaviour.
So the first question is, what does “change request managed” mean?
Does it mean that the request has been through impact analysis and either authorized or rejected? I hope so, because if it means that it has been implemented as well, it's asking for hurried implementations and mistakes. Let's assume it means “changes analyzed and authorized or rejected”.
It's trying to drive closure, and it seems as though a monthly cycle is desired by your organization. What happens when a CR is raised just before month end? Is it rushed, or can it be carried over? I would propose carried over. So the KPI ought to reflect the idea of giving a CR one month (30 days) to get itself managed:
Numerator = Number of CRs that were completed this month within their 30 day limit
Denominator = Number of CRs that should have been completed this month because their 30 days expired this month
Multiply the result by 100 to make it a precentage.
This will encourage people to complete CRs within 30 days of receipt, the behaviour I assume you want.
If both numbers are zero in a certain month, forcing the dashboard to go green could be a mistake, for it could indicate that the change request process has failed completely. Green should mean 100% of received CRs were completed on time and nothing else. If it's zero/zero, the KPI should show up as text: “No CRs this month” or such. Please do not allow yourself to be constrained by the tool. Make it do what you want. It's easy in software to write things something like:
If (denominator is zero) report “No CRs” Else (KPI = numerator/denominator * 100; report KPI)
If it won't do it, find a decent programmer or find a better tool.
Of course, if the KPI is defined this way, there is the matter of the CRs that did not get completed. One solution would be to make a similar KPI for overdue CRs, perhaps giving them closure timeframes of 60 and 90 days. This will encourage people to complete overdue CRs within 60, or at most 90 days. (After that I'd raise a corrective action to learn why not even 90 days is enough, and fix it.)
Hope this helps,
Pat
Z
zubairn
thanks Pat and Pancho.
“changes analyzed and authorized or rejected”. i.e., managed change requests definately looks much more useful and indicative of the health of the CR process.
Brgds,
Zubair
K
kgott
Pat
I dont want to appear to be stating the obvious here but we should be focusing on the process not on the people in the process.
I would suggest that you do as Jim suggests. Is there a particular reason for having change requests turnaround time as an improvement indicator?
I would have thought that its far better to use indicators that are directed at building capacity to improve. Some of the common type of indicators that are used are "convienience indicators" which contribute little to improvement of the system.
Perhaps consider the number of suggestions/opportunites for improvement which have been identifed, assessed and exploited by management as an indicator of both management committment and improvement of the management system.
R Cost Reduction Calculation Formula - KPI (Key Performance Indicators) IATF 16949 - Automotive Quality Systems Standard 5
G Kpi doesn't show action plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
D IATF mandatory KPI? IATF 16949 - Automotive Quality Systems Standard 15
Q KPI risk assessment - Criteria for the given score IATF 16949 - Automotive Quality Systems Standard 3
D Key Performance Indicators / KPI Review IATF 16949 - Automotive Quality Systems Standard 11
Jim Wynne Most Important Manufacturing KPI, per Oracle Coffee Break and Water Cooler Discussions 3
Enghabashy Supply chain main policies ,scope, risk assessments & relavant KPI Supply Chain Security Management Systems 2
K FAA Repair Station KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 15
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
V Informational SMMT IATF Oversight - OEM KPI Process IATF 16949 - Automotive Quality Systems Standard 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
qualprod Monitoring of lead time - Good KPI identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
qualprod On Time Delivery KPI for sales? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Level 3 KPI Excel Template Manufacturing and Related Processes 1
K A way to monitor our Internal Audits as a KPI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
M QMS Efficiency KPI as a Manager. IATF 16949 - Automotive Quality Systems Standard 7
J KPI Software - Our weakness is in KPI's Manufacturing and Related Processes 7
D KPI's Data for Customer Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S AS9100 Customer KPI Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R ISO 9001:2015 - KPI (Key Performance Indicators) vs. Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J KPI's for AS9100 Cl. 8.2/8.5 - Bids/Contract Review/Order Entry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K Further Analysis of Departmental KPI (Key Performance Indicator) Statistical Analysis Tools, Techniques and SPC 2
A KPI for Quality Assurance Team in a Service Oriented Industry Service Industry Specific Topics 8
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
1 KPI Dashboard Template in Excel Format wanted Excel .xls Spreadsheet Templates and Tools 9
Q Is KPI in Process Valid if not supported by Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V AS9100 8.2.1 (C) or 9.1.2 (D) Customer Satisfaction - KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A What KPI's do you use at Shop Floor Level and Team Boards? Quality Tools, Improvement and Analysis 4
W NCR Performance KPI Monitoring in an Industry like Construction Nonconformance and Corrective Action 1
armani Does KPI for Processes need to be correlated with the specific Risks for Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Excel Dashboard for Health Safety and Environmental KPI's for Multiple Sites Occupational Health & Safety Management Standards 4
Q Who can Change goals and kpi of top management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q KPI (Key Performance Indicators) for the Audit Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
L KPI Project help - Business and Management Degree Benchmarking 4
Q KPI's (key performance indicators) for a Print shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A KPI's for Individuals (Employees) Manufacturing and Related Processes 10
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
P Internal Audit Scope - Company's KPI (Key Performance Indicators) Internal Auditing 7
S KPI for Q&EHS Management System example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
B Should CAR be issued when the KPI is not achieved ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Determining Processes, Objectives and KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R KPI Review Meetings never discusses previous meeting action plan status Quality Manager and Management Related Issues 5
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Safety Lead and Lag KPI's Quality Manager and Management Related Issues 5
