KPIs (Key Performance Indicators) and Risk Management Process (ISO14971:2007)
Sanne
Hi there,
I am currently defining KPIs for our Risk Management Process (ISO14971:2007) and having some difficulties since I've never done this before.
Here is what I came up with so far:
TIME:
Are Risk Reviews done in time as planned
How long does it take to approve Risk Management Documents
PERFORMANCE
How often is Risk Analysis updated due to feedback from field (the more updates the less is the quality of the Risk Analysis)
RESOURCES:
Is Risk Management Team available when needed and "stable"...
Maybe anyone of this forum has an idea what else could be a key performance indicator...
Thanks a lot!!!
Cheers
Sanne
yodon
A few points to consider:
1) Tying the number of updates due to feedback from the field to an indicator of quaility of the risk analysis might send the wrong signals. If someone is being measured by this, then it could lead to suppressing feedback from the field. The system is designed to be updated as a result from actual use so to tie negative connotations to something that's supposed to happen might result in a less effective process.
2) Not exactly sure how this would be accomplished, but an examination of the effectiveness of the controls might be good information. Did the controls limit the number of occurrences and/or detectability?
3) Based on field data, were there risks that were not identified? This might be a good indicator of having the right resources.
When all this is said and done, I hope you re-post whatever you come up with and give us some feedback on if the measures are effective.
Sanne
Thank you a lot for the input!!!! :)
I'll let you know what I came up with, once I have defined all KPIs.
yodon
I don't think that measuring the frequency of risk analysis updates is an effective measure for risk analysis quality. Over the life of a project, it's rather natural that the frequency decreases. The product stabilizes and so the need for risk analysis meetings diminishes.
Also not sure the measures for product safety will be meaningful. For example, unless you have a homogenous product line, it's not likely that an average risk for each project will mean anything. Similar concerns about measuring severity across product lines.
IMO, what you should focus on for risk management is an post-release analysis to determine if you identified all the risks, if the estimated rate of occurrence and estimated severity was realistic, and if the controls were sufficient.
For example, if you identified a risk that you considered minor severity and unlikely to occur and after the product was fielded, there were frequent serious injuries (or worse), then irrespective of the number of updates and reviews you held, your risk analysis was not sufficient. Similarly, if you implemented controls to bring the risk to an acceptable level yet you saw serious injuries in the field, then you know your controls were inadequate.
Don't get so tied up in the process that you lose sight of the goal (safety and effectiveness).
R KPIs (Key Performance Indicators) for Telecom Operators TL 9000 Telecommunications Standard and QuEST 1
I Are KPIs (Key Performance Indicators) considered as Quality Objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Do Key Performance Indicators (KPIs) really make a difference in the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Key Performance Indicators (KPIs) in the Construction Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Key Performance Indicators (KPIs) book - Reviews and suggestions wanted Statistical Analysis Tools, Techniques and SPC 9
B Defining Physical Asset Maintenance KPIs (Key Performance Indicators) Benchmarking 6
J Key Performance Indicators (KPIs) for Management Review process Management Review Meetings and related Processes 37
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Training KPIs (Key Process Indicators) Training - Internal, External, Online and Distance Learning 8
B Laboratory KPIs ISO 17025 related Discussions 13
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
qualprod Proposed Kpis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Received a minor for not having good measureables/goals. Need help with KPIs. IATF 16949 - Automotive Quality Systems Standard 52
K IATF16949 inputs/outputs & KPIs Internal Auditing 3
Q Corrective Action - Assigning KPIs to Non-Guilty Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Suggested KPIs for a Manufacturing Production Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to align a Business Strategy to Operative KPIs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q KPIs - Lead and Lag Indicators - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A If 4.1 is a process, how to assign KPIs for this process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J Lean Appropriate KPIs for a Distribution Centre Lean in Manufacturing and Service Industries 1
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S Process Map and defining KPIs Misc. Quality Assurance and Business Systems Related Topics 5
K Can you Suggest KPIs for a Business Process Improvement Team? Pls. Benchmarking 4
R Document Control Person - Setting KPIs, Development Plan, and Career Path Quality Manager and Management Related Issues 6
B Is there a necessity of two sets of KPIs for Delivery Process Quality Manager and Management Related Issues 15
M First Draft of Policy, Objectives and KPIs - Your feedback appreciated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Aircraft Maintenance Quality & Safety KPIs - Industry Trend or Database EASA and JAA Aviation Standards and Requirements 3
A Aircraft Maintenance Quality & Safety KPIs - Industry Trend or Database Quality Manager and Management Related Issues 4
R Quality for Telco Companies - Quality in Customer Experiences & KPIs Quality Tools, Improvement and Analysis 5
0 Problem with setting up KPIs via Excel Pivot Table Misc. Quality Assurance and Business Systems Related Topics 6
A Department KPIs - Plant, Machineries and vehicles (PMV) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Jim Wynne "Business Coach" Touts Basing Pay on KPIs Philosophy, Gurus, Innovation and Evolution 43
S Differences Between KPIs and Objectives/Targets ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G KPIs required by TOP Management for strategic planning Statistical Analysis Tools, Techniques and SPC 2
Ajit Basrur Customer Satisfaction Survey Content - Which KPIs employed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Definition Key Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
B Four Key Performance Indicators for Continual Improvement (Dec. 3 2019) [Deleted] Training - Internal, External, Online and Distance Learning 2
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Inactive key supplier question - We are not actively buying from them ISO 13485:2016 - Medical Device Quality Management Systems 2
D Customer and Company Specific Requirements for notification of Customers of a change in Management or Key Personnel Customer and Company Specific Requirements 3
W Key functional characteristic definition - Tolerances and Deviations Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
Ed Panek Supplier Auditing - No purchases from our key suppliers in the last 24 months ISO 13485:2016 - Medical Device Quality Management Systems 5
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R ISO 9001:2015 - KPI (Key Performance Indicators) vs. Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Further Analysis of Departmental KPI (Key Performance Indicator) Statistical Analysis Tools, Techniques and SPC 2
