Labeling Placement Requirements according to the 60601-1
muhammad sadiq
Hi, so we are working on a medical device(home healthcare device) that is potable(not transit operable), we have made the labels for it according to the 60601-1(clause 7) requirements it contains information like warning signs eg keep dry - information regarding the input power eg 220 VAC , Serial number, manufactures information.
you can make a single label that contains all this info or you can divide this label into one sticker that contains the Serial number lot number and a second sticker that has all other info ie warning signs, input voltages etc
So now my question is related to the placement of this sticker, in clause 7 of 60601-1 the legibility of labels is covered in which it defines when the labels should be visible to the user.
I need some clarity on this clause, again our device is portable + used in home health care + clinics as well, can I put the said label/sticker at the bottom of the machine, it will not be visible to the user until he picks up the machine, the normal use condition of the machine is when its placed straight on the table (hiding the stickers underneath), for reference the machine weighs around to 17 Kgs.
Or the sticker needs to be at the back of the machine clearly visible to the user (this for us will require a redesign of the enclosure).
if the above option is true then can I put the serial number part of the label underneath the machine while keeping the warnings and input voltages label on he back(in order to make it smaller)
thank you in advance.
Peter Selvey
The applicable clause/requirement is 7.1.2, 3rd dash. This references "turning" the equipment, so strictly speaking it could be on the bottom.
I personally think it's good to have the mains related information near the power cord exit/appliance inlet, which is often at the back of the equipment, that is not specified in the standard but it makes it easy for the user to locate. Especially if the equipment is 17kg, you don't want to be rotating around trying to find the label.
Note that warnings should be visible from the position of normal use. This is different to ratings. So it is important to take care about what is really a "warning". The symbols used for 7.2.3 (read the IFU) are not usually treated as warnings.
A IVDR Labeling - Importer EU Medical Device Regulations 1
H Battery Labeling Requirements US Medical Device Regulations 0
M Labeling Specification in a DMR Other Medical Device and Orthopedic Related Topics 0
M Product Labeling EU Medical Device Regulations 11
B Labeling question about different manufacturers on a single label Manufacturing and Related Processes 4
G Labeling requirements for REFURBISHED medical devices EU Medical Device Regulations 0
S Labeling; User Guide US Food and Drug Administration (FDA) 4
T FDA labeling requirements US Food and Drug Administration (FDA) 2
C UDI assignment and labeling. EU Medical Device Regulations 4
M Labeling IVD Class III Medical Device and FDA Regulations and Standards News 0
L Class II Accessory Labeling Conundrum US Medical Device Regulations 19
S Labeling requirements for class 1, fashion sunglasses US Food and Drug Administration (FDA) 0
R Labeling requirements for single use devices Manufacturing and Related Processes 4
Edward Reesor Class I non-sterile "Shelf Life" labeling (EU/UK) CE Marking (Conformité Européene) / CB Scheme 4
S Sterile Disposable Cardiac Guidewire 3yr Real Time Sterility Failure When Confirming Accelerated Aging / Labeling US Medical Device Regulations 3
A Labeling Requirements for Medical Device Travel Case US Medical Device Regulations 9
A Labeling colors IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
M Reworking MDD product w MDR labeling CE Marking (Conformité Européene) / CB Scheme 5
U Medical Devices Labeling Medical Device and FDA Regulations and Standards News 0
Watchcat REGULATORY WATCHCAT - De Novo Proposed Rule - Samples & Labeling Other US Medical Device Regulations 0
C Product Lifetime on Labeling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L EU MDR Ramifications for no expiration date on labeling EU Medical Device Regulations 4
B Is labeling on the device itself required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
S Reseller Request to Change UPC on Medical Device via Re-labeling Medical Device and FDA Regulations and Standards News 5
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 1
D Hazard symbols and labeling ISO 13485:2016 - Medical Device Quality Management Systems 1
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
D Labeling requirements for reagents, etc ISO 13485:2016 - Medical Device Quality Management Systems 4
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
K China Medical Device Labeling requirements - Language China Medical Device Regulations 9
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
JoCam Labeling to Customer Requirements EU Medical Device Regulations 1
Z Labeling for Medical Device Samples - Surgical instruments 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
D Do User Manuals (Not Device Labeling) HAVE to be in their national languages for these countries? Will English Hardcopy not do? EU Medical Device Regulations 12
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
M MDR Legacy Medical Device Labeling compliance timeline EU Medical Device Regulations 3
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Labeling for off-label use - Prevention of off-label use of a medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Labeling - 2017/745 - EUMDR Requirements and Trademark Issues EU Medical Device Regulations 0
