Labeling template on QMS - Kitting and labeling documentation
CPhelan
We are heading into a first in human clinical trial this year and I am getting all of the kitting and labeling documentation together.
I have the label created and uploaded the template onto our electronic QMS, though it is not yet released and still in a collaboration phase.
There is still some information I'm missing form some of the kitting labels however is it best practice to upload and approve a template to be used for the device and packaging labels. Then when making the actual label for a specific lot with a specific expiration date would you download the template create your label, save a copy of the label and go through a labeling check list to verify all of the necessary information is on the label?
I just don't think I should have all of the final information on the label thats uploaded to the QMS but maybe the label should be approved and released but I can't see how this would be practical.
I just wanted to ask what was best practice with other companies.
Any advice is greatly appreciated.
Ronen E
Problem Solver
Moderator
If you have labels with variable fields, your base label (fixed fields) should be reviewed and approved in your QMS, then every instance formally proofed and released for use, and a record kept as part of the lot's DHR (batch record). And of course all this process needs to be captured in a formally approved SOP / WI.
CPhelan
Thank you Ronen.
Steven Severt
What format do you typically make your labels in? I'm currently working on my first UDI label as part of a 510k submission, and my client is wanting me to make some CAD diagrams of the labeling. I'm not sure if he wants them modeled in CAD for the purpose of updating the information, like you're talking about here, or if the CAD files are used for label printing? When I saw your post about updating labels I figured I'd ask what format you typically make them and control them in your QMS. It sounds like they want me to export the CAD files as PDFs for their submission, so I'm pretty confused about the purpose if they already have the templates in a Word document.
Ronen E
Problem Solver
Moderator
"CAD" is very general. It would help understanding if you could please specify what kind of software you are referring to. Thanks.
Steven Severt
I use Onshape to make solid models (similar to SolidWorks). I never send him any solid models but can export in any of the typical formats. I use that to make my drawings and typically export as a .dwg and .pdf for the client. But we’re usually creating the engineering information for the devices in the DHF. He asked for ‘engineering diagrams’ similar to what I send him as a .pdf of drawings that I create in Onshape from my models. I’m not really sure what he’s looking for. I tried to inquire a bit, but he just asked that I do what I’ve been doing for the drawings of the devices. I’m trying to understand what he’s looking for so I can deliver what he needs, and I was wondering what is normal for UDI files to try to point me in the right direction.
CPhelan
Hi Stephen we are going into FIH trials so just getting our labels ready for that. We are currently just completing the initial draft in Word or Powerpoint just to get the general layout and proposed colors.
I have completed the draft labels in Adobe Illustrator. Very intuitive, can select bleed distance if getting labels printed by a third party they will request bleed for the label. I personally found Adobe Illustrator good to work with. Ensure you download the necessary label symbols from ISO store from 15223-01. These are the internationally recognized symbols for labeling. When you download the labels from ISO store you get the option to download the label as an .ai file which is specifically meant for Adobe Illustrator. Converts to high quality PDFs
Ronen E
Problem Solver
Moderator
Thanks for explaining.
That's quite confusing actually. As a mechanical engineer who has used SolidWorks extensively, I can't quite understand why would one use solid models for labelling...? If the output needs to be PDF (or even DWG) there are simpler ways to do it.
This is unrelated to creating solid models and drawings of the device itself.
Perhaps what your client means by "engineering diagrams" is the label artwork in a formal drawing title block, with all the relevant information (fields and notes) + dimensions.
There are purpose built tools for generating compliant UDI barcodes (that's what I initially thought you were referring to in "CAD").
Steven Severt
That's definitely something I was wondering about. A different consultant made the proposed labels and sent them to the client, who then sent them to me in a Word document. They had all of these symbols in them and I had no idea where they came from. I appreciate that feedback.
Steven Severt
Well at least I'm not the only one scratching my head trying to figure out what he's looking for. I appreciate your feedback. I think he pretty much is just talking about a PDF drawing with title block and dimensions, so I'm looking at this morning and seeing if I can just snip all of the info from the Word document that he's already sent and throw some dimensions on it and a title block.
B Is labeling on the device itself required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Reseller Request to Change UPC on Medical Device via Re-labeling Medical Device and FDA Regulations and Standards News 1
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 1
D Hazard symbols and labeling ISO 13485:2016 - Medical Device Quality Management Systems 1
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
D Labeling requirements for reagents, etc ISO 13485:2016 - Medical Device Quality Management Systems 4
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
Anonymous16-2 Labeling Question (Dietary Supplements/Food) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
L Medical-grade power adapter labeling Other US Medical Device Regulations 2
Y Labeling difference for storage and operating conditions EU Medical Device Regulations 1
H MDD Article 12 Labeling for Class IIa Medical Device - Please Advise EU Medical Device Regulations 3
K China Medical Device Labeling requirements - Language China Medical Device Regulations 3
S Special 510(K) - Labeling change from Rx to OTC Other US Medical Device Regulations 11
N Device Labeling - Medtronic Ventilator Files (Risk Management documents) Coffee Break and Water Cooler Discussions 2
JoCam Labeling to Customer Requirements EU Medical Device Regulations 1
Z Labeling for Medical Device Samples - Surgical instruments 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Change Control - Product Name Change and its associated labeling EU Medical Device Regulations 7
D Do User Manuals (Not Device Labeling) HAVE to be in their national languages for these countries? Will English Hardcopy not do? EU Medical Device Regulations 12
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
M MDR Legacy Medical Device Labeling compliance timeline EU Medical Device Regulations 3
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
M Labeling for off-label use - Prevention of off-label use of a medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
P UDI labeling for power module IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Labeling - 2017/745 - EUMDR Requirements and Trademark Issues EU Medical Device Regulations 0
DitchDigger UDI, Labeling Accessories, General Insanity, Etc. US Food and Drug Administration (FDA) 1
K Labeling requirements - Date of manufacture for software devices EU Medical Device Regulations 5
E Annotated US Prescribing Labeling US Food and Drug Administration (FDA) 0
T Product Labeling - Modified the name of one of our products EU Medical Device Regulations 5
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
T Labeling Requirements - Creams in tubes EU Medical Device Regulations 3
K EU MDR Art. 22 - Device + insertion pack - User manual and Labeling EU Medical Device Regulations 4
M MDR 2017/745 sterile and non-sterile labeling EU Medical Device Regulations 12
M Professional Use Medical Software French Labeling for Canada -- Not Considered Medical Device Canada Medical Device Regulations 2
G FDA UDI markings "label" vs. "labelling" (labeling)? US Food and Drug Administration (FDA) 4
G How is the labeling of units cleared for both Rx and OTC uses handled? US Food and Drug Administration (FDA) 4
E FDA Supplier Labeling Requirements ISO 13485:2016 - Medical Device Quality Management Systems 1
L Class IIa Medical Device, CE Mark & 510k - Labeling Content CE Marking (Conformité Européene) / CB Scheme 4
M Scrubbed version of a labeling procedure that is MDR compliant wanted EU Medical Device Regulations 3
M UDI labeling MDR requirement for reusable medical device accessories EU Medical Device Regulations 12
T Change to Country of Origin on Medical Device Labeling Other Medical Device Regulations World-Wide 0
L EU-MDR-Annex I - 10.4 (CMR & Endocrine-disrupting properties) - Labeling Content EU Medical Device Regulations 5
I Medical Device Packaging Multilingual Labeling EU Medical Device Regulations 3
T FDA proposed labeling standalone software cloud based US Food and Drug Administration (FDA) 4
M Putting AR's name and address on label - Authorized Representative Labeling Requirements CE Marking (Conformité Européene) / CB Scheme 0
N IFUs with promotional labeling Other US Medical Device Regulations 0
I Requirements for different Labeling Levels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
