Labels - How do you control the number of product labels printed, scrapped and used?
abraganza
How important is it to control the number of labels printed versus used?
Device is Class I , CE marked.
Is there a good system or set of rules to follow?
Should the labels be serialized for tracking purposes?
somashekar
Re: Labels - How do you control the number of product labels printed, scrapped and us
Hii and welcome here.
You will find some inputs about your question in the threads seen below in " Similar Discussion Threads "
Label control is indeed important, and your system can be based on the process whether you buy the labels or print them inhouse.
A very good control is to affix the label on the device records also which is maintained for the devices that are manufactured and labeled. Physically destroy unused labels if they can no more be used.
Serial number can also be per a numbering scheme that captures many other information and not necessarly a running serial number.
MIREGMGR
We print the exact number of labels needed, plus one. The extra one goes on the back of the first page of the production work order package, with the production supervisor signoff that the label content has been checked.
We've determined over time that the infrequent cost to us of having to go back and print one or more additional labels to make up for spoilage, is much less than the constant cost we used to have for controlling (and assuring documented destruction of) overprint quantities.
We make some serialized products (durable equipment of various types), and many non-serialized but batch-coded products (disposables and short-life products). Serialized products are much more complicated for us, because we determine serial numbers in advance...thus each unit in product has a serial number well in advance of when it's married up to its labeling. In any case, serialization on labels is never our only, or primary, means of controlling label print quantities.
dzurn
Your label printing software might also be able to keep a log of all printed labels. The log can sometimes be customized to record a little or a lot of information.
This way, you can see which serial number labels have been printed and on which printer. That might help you find out where and when the extra labels are being printed, if that's the problem.
If you are just concerned with spoilage or printing unneeded labels, I would take the advice of MIREGMGR above, and print exactly the number of labels needed. Then if the line needs to print more, it's a sure sign that something went wrong, and you can use that as a trigger to look at where your labeling process is not working as expected.
Hope this helps.
Darryl
ScottK
Not out of the crisis
I work for a label printer that serves many customers in the drug and device area.
the most common things we are asked for are:
- a core label with the exact count
- sequential Videojet coding on the back of the liner
- sequential Videojet coding on the front of the label
- serialized bar codes
when there is sequential numbering each roll of labels must have the start and end number documented either on the C of C and/or core label.
Most of our label product gets 100% inspected on strobe or video inspection units - this is when we would add the Videojet coding and get the exact count.
Serialized bar codes are done on a digital press.
When I did contract packaging we had to do a label reconciliation after every run of certain products. To facilitate this reconciliation we actually peeled portions of waste labels and stuck them to paper to get a count after the run. It worked well enough to meet the tolerance the customer was looking for.
abraganza
Thanks for all your responses, they were helpful for us to set up a procedure, we have done some labels runs and everything has gone well so far.
1 Requirements for the Control of Product Labels Document Control Systems, Procedures, Forms and Templates 3
J Label Control - How to Correctly Control Labels we Print Ourselves Document Control Systems, Procedures, Forms and Templates 2
Ajit Basrur Control of Medical Device Labels and Labelling Activities - Looking for a procedure Document Control Systems, Procedures, Forms and Templates 15
D Label Control - Who handles label control and the issuing of labels Document Control Systems, Procedures, Forms and Templates 4
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
R Rx only - On labels US Food and Drug Administration (FDA) 2
Ajit Basrur Physical Address on Product Labels (EU MDR perspective) EU Medical Device Regulations 2
K EIFU indicator symbol - Class I labels as per EU MDR EU Medical Device Regulations 3
S Can medical device labels in EU be bilingual? EU Medical Device Regulations 2
A In which EU countries would it be okay to use sample labels for registration? EU Medical Device Regulations 0
D Requirements for the dimensions / color of medical device labels - Software as a Medical Device IEC 62304 - Medical Device Software Life Cycle Processes 2
Y CE Mark - Placing the CE mark on medical device labels EU Medical Device Regulations 2
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Tagin Recommendations for calibration labels for ESD floor mats General Measurement Device and Calibration Topics 9
R Labels on sterile packaging EU Medical Device Regulations 5
M Technical File (STED) labelling - When you compile tech files do we have to include all the product labels? EU Medical Device Regulations 2
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
B Site Move - Question about Updating Product Labels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T Definition ECS - Product Labels have "ECS" in the prefix Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R Re-Use of Diagnostic Reagent Solution Labels - Buffer Solutions for Internal Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Company Name Change - ETL Labels and Report Updates CE Marking (Conformité Européene) / CB Scheme 2
U Good Documentation Practice (GDocP or GDP) - Labels and Attachments Document Control Systems, Procedures, Forms and Templates 2
S Dates on Labels acceptable to the USA - GS1 General Specification 3.4.4 Other US Medical Device Regulations 3
S OBL CE Marked Medical Device Labels EU Medical Device Regulations 5
R Standard for Rounding Measurements for Labels Other Medical Device Related Standards 9
C Adding information to Labels - Class II Medical Devices US Food and Drug Administration (FDA) 1
C Medical Device Labels and 21CFR part 801.15 Other US Medical Device Regulations 1
D Medical Device Requirements - Labels - Embossing, Coloring IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
I JIS T 0307:2004 Medical devices -- Symbols to be used with medical device labels Japan Medical Device Regulations 2
M Manufacture and Sales of GHS Labels and Pictograms Occupational Health & Safety Management Standards 1
Y Recommendations for Label Printer / Label Stock for On-Device Labels 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
E Must Patent Numbers be Shown on Product Labels? Other Medical Device and Orthopedic Related Topics 18
S How can I inventory labels supplied by customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Use of Made in XXX Country on Medical Device Labels Other Medical Device Regulations World-Wide 3
S OEM Supplier with ISO 9001 Labels Medical Device Accessory ISO 13485:2016 - Medical Device Quality Management Systems 3
C ESD Bags and Paper Labels (Dymo) on the Bags (Packaging) Misc. Quality Assurance and Business Systems Related Topics 5
J Labeling Software for Medical Device Product and Packaging Labels for Production Use Other Medical Device Regulations World-Wide 5
T DVP&R (Design Verification Plan and Report) for Vehicle Labels? APQP and PPAP 3
B Language Requirements - Labels/IFU (Professional Use Medical Devices) in Bangladesh Other Medical Device Regulations World-Wide 2
J Latex Adhesive Labels used in Medical Device Packaging Other US Medical Device Regulations 7
N China's Regulations regarding Labels on Class II Medical Devices China Medical Device Regulations 4
R Referencing and Controlling Labels & Stickers used internally throughout Production Document Control Systems, Procedures, Forms and Templates 1
P Labels - ASTM D3330/D3330M Acceptance Criteria for Adhesion 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Signal Words for CE Mark and FDA Labels US Food and Drug Administration (FDA) 7
