Laboratory Layout - Please comment & give ideas on my proposal
blueicecube
I've been assigned to design layout for an in process lab. I need some advice & thoughts on the layout that I've made especially on the following :
1. Looking at the layout, how many people do you think will be comfortable to be inside the lab at any given time?
2. Are the spaces between workbenches reasonable, or too tight?
Your thoughts are highly appreciated.
:thanx:
bobdoering
Stop X-bar/R Madness!!
Re: Please comment & give ideas on my proposed Laboratory Layout
Suggestion: add work flow to the layout to understand efficiency.
brahmaiah
:thanx:
Name and purpose of the Laboratory,Names of equipment located inside lab.Which side is west and which side is east etc.Position of windows and A/C unit have to be indicated.Each equipment should be shown inside a rectangle .
The plan should be drawn to scale.
V.J.Brahmaiah
CarolX
Both questions are a little hard to answer without some additional info - you have the room size shown, but I can only estimate the size of the workbenches and the space to move around. Could you detail a little more?
One thing I did notice - the sink and the cabinets are in the corners and may make them difficult to access.
BradM
Exactly. Saying, are there going to be chemicals? Heavy instruments? Instruments subjected to draft and such? What type of work that will be done is pretty important as to the lab layout.
The cabinets were the first thing I thought about. While it "appears" to be organized, having technicians walking all the way across the room to get out/put up instruments is a pain, not to mention increases the chances to drop something.
Just some additional consideration besides Carol's:
If there is a wall facing the sun, it might get hotter on that side of the room.
You will need to take into consideration air flow/ air draft conditions. That would be very critical for some processes over others.
Are you going to have a Quarantine Area? like near the door, where people put instruments to be calibrated, equipment/instrumentation to be checked in prior to use?
Are there any vibration considerations? Also, if there is a Cube Farm on the other side of one of the walls, I would try to put low-usage items (sink/cabinets/etc.) on that wall, and put workstations near the most quiet areas.
Would it be possible to spread the data units out? One thing that is universal: People like their space.:D
Again, depending on the work, cleanliness of the lab and such, I would think that any more than 3 people will get really cozy in there.
bobdoering
Instruments subjected to draft and such? ...If there is a wall facing the sun, it might get hotter on that side of the room.
...or light considerations for optical measurement machines.
:thanx:
As the responses so far correctly indicate, more information is needed. One thing that I noticed is surface plates in a corner against the wall. It's usually best to have at least one of adequate size positioned such that it's accessible all the way around. Think of it like a pool table. There's often a need to approach a piece from different directions, and having more accessibility means that (sometimes) more than one person can use it at the same time.
Ajit Basrur
blueicecube,
Pl have another layout uploaded with instruments in place to get more ideas :)
Do not forget safety aspects as well - the simple one being an emergency exit, in case you are handling chemicals !
OK, my :2cents: Just general things without knowing exactly what is to be done in the room:
I would avoid the "slalom course" created in the drawing. Someone doing much work at the granite plates in the upper right corner may be driven bonkers by having to go round the 10 ft whatever it is protrusion between them and the door, and anyone entering data in the bottom left corner may be similarly affected by having people walking by behind their backs all the time. If there is to be little movement in there, this may on the other hand be minor problems.
The room is small, but perhaps it would be a better idea to create an "island" in its center if that is possible?
/Claes
blueicecube
"Name and purpose of the Laboratory,Names of equipment located inside lab.Which side is west and which side is east etc.Position of windows and A/C unit have to be indicated.Each equipment should be shown inside a rectangle"
- In Process QC Lab, Equipment (glasswares, balance, 1 analyzer, microscope), Left side is west, the Room is half glass/half solid on the bottom, solid wall on the left, top-side & door side, A/C outlet is in the middle of the room.
It is a room inside production area (no direct sunlight)
Granite Plate is meant for use by 1 person only at a time - using the 1 analyzer. The smaller plate is for balance.
I forgot about the microscope & vibration (thank you for reminding me)
The only chemical used is 0.1 N (something) Acid - the rest are just water, hot water and more water.
I need to re-consider the data entry station (yes, people likes spaces).
(and maybe consider storage cabinet on top of bench-tops instead of standalone. It seems 'Island' may work better in this environment)
Really appreciate your reply. Thank you very much!
E ISO 17025 Compliant Laboratory Layout ISO 17025 related Discussions 3
N General Microbiological Laboratory Layout and Required Equipment General Measurement Device and Calibration Topics 6
J Would like to remodel our QA Layout Laboratory - Your ideas appreciated Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
X ISO 17025 certification for Laboratory for online gambling products ISO 17025 related Discussions 3
B Laboratory KPIs ISO 17025 related Discussions 13
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
T Laboratory Verification after validation ISO 17025 related Discussions 3
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
G ITAR Registration for Metrology Laboratory? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S Laboratory Environmental Conditions Outside of limits ISO 17025 related Discussions 4
I Laboratory Fridge / Freezer Inventory - Requirement(s) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
DMLqms Material for laboratory use or Medical Device? EU Medical Device Regulations 2
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
B Accredited laboratory or not under MDD 93/42/EEC IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
Casana IATF 16949 7.1.5.3.2 External Laboratory - On Site Calibration IATF 16949 - Automotive Quality Systems Standard 8
A Information on good laboratory practices (GLP) for the non-medical or food industry wanted Manufacturing and Related Processes 1
D Internal audit forms or checklists for a medical/veterinary laboratory General Auditing Discussions 5
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
Q Calibration laboratory scope - Include software such as Gagetrak or Mini tab used? General Measurement Device and Calibration Topics 3
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
P Procedure for maintaining Confidentiality And Impartiality in a Laboratory Quality Management System (QMS) Manuals 2
sswaim IATF 16949 7.1.5.3.2 External Calibration Laboratory Requirelents IATF 16949 - Automotive Quality Systems Standard 15
J Good Laboratory Practice: online training course recommendations? US Food and Drug Administration (FDA) 0
E 2 participants in inter-laboratory comparison tests ISO 17025 related Discussions 3
T MDR on Good Laboratory Practice (GLP) - Pg 110, section 6.1 (b) EU Medical Device Regulations 1
D Laboratory Manual ISO/IEC 17025 Example wanted ISO 17025 related Discussions 2
D Help identify a Nationally Recognized Testing Laboratory (NRTL) (UL) certified lab General Measurement Device and Calibration Topics 3
L How to manage a Metrology Department or Calibration Laboratory General Measurement Device and Calibration Topics 3
J IATF 16949 Calibration Laboratory Scope IATF 16949 - Automotive Quality Systems Standard 22
H Internal laboratory scope requirements - IATF 16949 Cl. 7.1.5.3.1 IATF 16949 - Automotive Quality Systems Standard 1
S RSL (Remote Site Location) Laboratory - Does it need to be ISO 17025 IATF 16949 - Automotive Quality Systems Standard 5
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
rob73 Requirement for independent certification of device using an ISO 17025 laboratory EU Medical Device Regulations 2
G Calibration Laboratory Dimensional Temperature Question General Measurement Device and Calibration Topics 2
G ISO 17025 Calibration Laboratory Assessor's Common Questions and Procedures ISO 17025 related Discussions 11
H Need to Start an R&D Laboratory, what to do? Design and Development of Products and Processes 6
B IATF 16949 - 7.1.5.3.1 Internal calibration laboratory requirements IATF 16949 - Automotive Quality Systems Standard 9
A Pharmaceutical Manufacturer's obligations - Laboratory Test instruments General Measurement Device and Calibration Topics 0
S HVAC Thermostat for Calibration Laboratory General Measurement Device and Calibration Topics 8
V Temperature/humidity requirements in internal metrology laboratory General Measurement Device and Calibration Topics 3
C Looking for Testing Laboratory for Aluminum Products - CE Marking General Measurement Device and Calibration Topics 5
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
J Internal Laboratory Scope and Measurement Uncertainty (MU) IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 7.1.5.3.2 - External Laboratory Sub-Supplier Requirements IATF 16949 - Automotive Quality Systems Standard 2
J Is a Laboratory Scope Necessary if... IATF 16949 - Automotive Quality Systems Standard 15
