Lacking Documentation of Customer Requirements, what do I need?
djbeatsent
#11
Re: Lacking Documentation of customer requirements, what do I need?!
OK, so if you recieve an order for p/n 123456 you must then already have processes in-place to produce it (tooling, materials, production, QA, etc.) that are related to this specific part. This would more than likely be because you have made it before (which is were I was driving at earlier, ensure you record what & how you made it so you can retreive that data if made again in the future).
If you already have a qualified part, then the customer is simply ordering a p/n they pulled from somewhere. There is no need at that point for specific "customer" requirements (related to the actual product itself) if the item is a repeat.
Inspect it the same way you did before (again, if ordered regularly it may be an added value to create specific testing methods and/or inspection sheets) and you are demonstrating conformity. All you need to do is ensure that the product your producing meets the requirements & characteristics of p/n 123456 & your good.
OK I understand what you are saying but my question still remains, if the customer did not supply ANY quality requirements EVER (we decided on material, etc, etc, and they approved part), than am I safe when the auditor comes?
Jason PCSwitches
#12
I don't understand how they can place an order without giving you something?? :confused:
If they just said we need a molded part that can do this xxx, and you made a sample/prototype and they then approved it, your good as long as you have records. You designed & developed the part, they approved it and placed an order. Inspect it to the criteria you develop to ensure conformity and that should be that.
If they provided you with any specifics those should be addressed as well.
Am I getting warm :tg:
treesei
#13
After all the "rubbery" issues are resolved, I assume there is a time at which all tooling, materials, process specs, inspection methods etc are finalized and a batch is run. I also assume that you have records for all of that. Then the customer looks at the produced part (may I call it first article?) and approves it. You will record the approval. From then on, if the customer orders 20,000, I assume you will make them using the exact tooling, materials, process specs, and inspection methods as you did with the first run. If you keep records to show that all 20,000 parts are manufactured and inspected in the same way as the first run and pass all same acceptance criteria as the first article, I would think you are pretty safe with an auditor.
To protect myself further, if a customer does not supply any quality requriements and I produced all drawings, quality inspection plans, process charts etc, I would send them all to the customer with my first article to get a "package approval".
#14
The customer has given you requirements. Are you working via clairvoyance? Even if all the customer says is "I need a fuzzy blue thing," and you give them one, you've satisfied the requirements. It shouldn't take much effort, once you've defined the requirements, to write them down--no matter how ridiculous it might appear--and have the customer sign off.
djbeatsent
#15
Looks like what I can do to protect myself and the company is to do exactly what you guys are saying. I will just come up with a form for customers lacking drawings and will write down the verbal requirements (no matter how ridiculous) and send them a copy to sign off on. I am fairly new to ISO so everyone's input is very much appreciated!
:thanx:
Jason PCSwitches
#16
:thanx:
What I'm still having a hard time understanding is how you can develop a mold insert for a particular part that a customer orders when they don't give you any specifications. If I wanted a "blue fuzzy thing" and that's all I told you, how do you determine the characteristics of the mold insert you need to make to produce the part? As I'm sure your aware of tool making isn't a fast & cheap process. There has to be more to this, and if not, your organization should add a fortune telling charge to quotes.
It still seems that something is missing here somewhere. Than again it could be me....:bigwave:
dkusleika
#17
I wouldn't over think this. Just document what your customer says and what he implies and create your requirements doc. If your customer brings in a battery terminal and says "I need a plastic cover for this.", then you already have a preliminary reqs doc.
1. Must be at least .5" in diameter (to fit over terminal)
2. Must be at least 1.1" deep (to fit over terminal)
3. Must be plastic (specific customer requirement)
4. Must be insulative (implied customer requirement because he said it was for a battery)
As your CAD guys make assumptions, add those assumptions to the list. That's it. Take the sample to the customer, he tells you it's too rubbery. Go back to your reqs doc, cross out #3 and write
3. Must be Dupont Plastic #47
Take the next sample back to your customer and he says they need a small flair at the edge. Go back to reqs document and write
5. Must have at least 1mm flair at edge
Once the customer says it's good, you can have them sign off on the reqs doc or not. It's not required, only that you review customer requirements, which you clearly have done by creating this doc. Now you have five requirements for your V&V testing.
JaneB
#18
There's a difference, surely, between creating a prototype (on flimsy/very sketchy requirements) and doing a production run of 20,000 once the prototype is agreed?
I don't see that you need to get the 'customer to sign off on' the prototype requirements if they're pretty flimsy, unless it adds some value to the whole process, even if that is to protect you from risk. I do not see the argument 'it keeps our auditor happy' as one that adds value, by the way.
If you're doing a prototype, then you're doing a prototype. And going back to the requirements document each time and writing something on to it and then getting the customer to sign off on that? If I were a customer, at this point I might be thinking of finding someone who can do it with a bit less bureaucracy. I do understand the need to capture customer requirements... but not everything has to be writtendown. If it's effectively captured into the prototype model, and that process is working well, then I'd use the prototype itself as the agreed customer requirements and focus on control at that point.
Sounds a bit like a trial and error/iterative design process... similar things happen in the IT world. And writing down everything and getting everything signed off one itty bitty step at a time? Surely sounds like over-control to me.
K Root Cause for lacking Analysis of Data procedure? ISO 13485 Problem Solving, Root Cause Fault and Failure Analysis 7
RoxaneB Focusing on Quality - Flawed Survey or Responses Lacking? QualityInsider Philosophy, Gurus, Innovation and Evolution 9
T Lacking Auditors for Internal Process Audits - What to Do? Process Audits and Layered Process Audits 8
G Does FDA allows remote approvals of quality documentation. Is there any specific guidance on signing any quality records remotely? Document Control Systems, Procedures, Forms and Templates 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
NDesouza COTS Items CoC for FAI Documentation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
C Documentation hold during submissions? ISO 13485:2016 - Medical Device Quality Management Systems 0
K SOUP (Software of Unknown Provenance) Anomaly Documentation IEC 62304 - Medical Device Software Life Cycle Processes 2
C Gobys for operations documentation plan Oil and Gas Industry Standards and Regulations 4
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
P Does anyone have a API Q1 Documentation Package? Quality Management System (QMS) Manuals 1
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Robert Stanley Required Documentation Templates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
was named killer CLOUD BASED QUALITY DOCUMENTATION vs. SERVER BASED Document Control Systems, Procedures, Forms and Templates 5
S How to start with ISO process in project based team - Documentation Document Control Systems, Procedures, Forms and Templates 4
K ITAR Visitor Documentation of Citizenship AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
A Process Documentation for ISO 9001:2015 Internal Auditing 2
F Process Review - What is the ISO requirement for reviewing SOPs and quality documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 mandatory documentation requirements ISO 17025 related Discussions 1
D Virtual Documentation via Master Flow Chart? Process Maps, Process Mapping and Turtle Diagrams 4
S Defining a Quality System from scratch - Preferred system and documentation names Document Control Systems, Procedures, Forms and Templates 4
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
F PPAP Documentation Control APQP and PPAP 8
V Every good documentation practice observation is an data integrity issue US Food and Drug Administration (FDA) 7
CPhelan Labeling template on QMS - Kitting and labeling documentation Manufacturing and Related Processes 9
DuncanGibbons Documentation aerospace OEMs require with purchase of parts from manufacturers/suppliers Manufacturing and Related Processes 0
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
L AS9100 D- Handling Nonconformance Documentation for an organization that outsources most of the work. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
L ISO 9001:2015 standard documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Time source for paper-based documentation (research nurses) US Food and Drug Administration (FDA) 1
W Documentation - Use of Addendum vs Amendment Document Control Systems, Procedures, Forms and Templates 1
I What level of change in documentation requires re-training? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
D QMS Documentation Process - I want to put all the Process SOPs to a QMS system Document Control Systems, Procedures, Forms and Templates 3
T QMS - Documentation Cloud Storage EU Medical Device Regulations 0
C Updates on Documentation for outsourced OEM from ISO 13485:2003 to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 4
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
