Large sand steel casting discontinuities
LMO
Quality
Casting (discontinuities)
I have rather large sand steel castings (800 to 900) lbs. Some surfaces have an extra 3mm per side to allow for machining operation. Someone decided to change the standard to say [Linear discontinuities ?None Acceptable?] such as, cracks, porosity, hot tears, etc.
Can this specification be met (100%) defect free on discontinuities?
What does it take to meet this specification?
:confused:
:thanx::thanx:
AndyN
Moved On
It might need a change in process, from sand casting to some other technology. For a given component - which may not have been designed with the sand casting process in mind - it might be a practical impossibility to produce castings with out these features. If the part designer was consulted about how the mold is configured for runners, risers etc. then it doesn't matter how goo you are at controlling pour, temps etc. the casting will likely exhibit these defects...
normzone
Ah, the casting fantasy. Somebody didn't like the voids inherent in the casting process, so they changed the spec.
That's okay - all you have to do to meet that is machine your part out of a 900 pound piece of solid stock.
(Princess Bride - Wesley's voice) " Castings ARE flawed, princess. Anybody who tells you different is selling something ".
This falls under what I refer to as " unrealistic expectation of process capabillity".
:nope:
John Broomfield
Sound castings from sand.
Do we have any bell foundry experts on the Cove?
Most bells do not end up cracked and displayed as tourist attractions.
Must the casting material be steel?
Steve Prevette
Deming Disciple
My father spent several years in the iron/ steel casting industry, and I have some engineering knowledge of metallurgy.
Generally all sand iron/steel castings will have some level of pores and flaws. You basically do have to go to forging if you want less flaws. However, castings have been successfully used for years in many applications, so one really needs to look at what the application is and what are acceptable defects.
normzone
Yeah, in my limited experience the flaws either don't matter, represent structural or dimensional problems, or are only cosmetic challenges. Some of those can be worked around by welding and machining/grinding.
LMO
Quality
I thank you all for you input. My thoughts exactly.
Welding and some others have unrealistic expectations.
:agree:
N
ncwalker
Let's talk just general steel billets - they have terms like capped, rimmed, killed, semi-killed all of which are used to control defects. Basically pull them to the top of the billet. Then if you need "clean" steel, you can hog off the top where all the impurities are.
And a billet is nothing more than a large, rectangular casting. But all the process I mentioned above either reduce the defect or move the defect to where it does not matter.
And that's the game in casting a part.
Because you are mentioning a 3 mm stock for machining, I am going to assume that it is only a problem once you machine the part, exposing the defect and because these defects are much more rare on the surface. If you're getting these on the "as cast" surface, you really have gating/riser problems.
So the first answer is minimize your machining stock. This can be done by carefully choosing datums in the casting and machining so the "sensitive" areas have the best controls - stackups of follow on ops needing more stock. But 3 mm isn't a lot for a casting of this size.
The second answer (in processing) is control your temperature on solidification. There are two approaches, both can work.
a) Make the surface right near the problem area cooler - causing this area to solidify sooner which drives the porosity away from this surface.
b) Make the surface right near the problem area hotter - in this scheme, you attempt to pull the porosity into the machining stock to be machined away.
This is going to come down to your sand mold - and the spectrum of additives you can choose from, which in most cases come down to application of graphite (better conductor of heat, cooler sand in that area) or possibly a sand core insert, like a shell core. But that's money.
I have had most success with a) above. For b) you may have to have more stock, to provide more room for the defects to go. Most people don't like this option - it's not steel safe in the pattern, it slows the machining process removing more stock.
And I forgot option c) make the porosity acceptable. Make samples and functionally test them. Again, given the size of your castings - yeek. That's an expensive testing program.
Final thought on the metal chemistry side: you could play around with your Moly content or your Silicon or both. An experiment with those at the high/low range may be fruitful. But be careful with this, you will wind up with a "special" batch recipe for this part. And that's easy to mess up in production - your lab releases a billet because it is in spec for the "book value" of this steel, but forgets this one is a special case.
Englishman Abroad
Yes, it is not possible to have defect free steel sand castings. (It is not possible either to have defect free continuously cast steel). In both cases you need a clear definition from the customer about what is and what is not acceptable.
In a previous life, I dealt with steel (and iron) sand castings for the railway industry. We specified acceptable surface and volumetric flaws as detected by Magnetic Particle Inspection (MPI), and X Ray.
For surface defects we accepted rework by grinding, MPI inspection of the bottom of the grind (to ensure removal of the crack) and then welding, followed by repeat MPI. (against a national standard for steel castings).
Needless to say that MPI, X Ray and welding were all special processes and the persons performing had to be certified, and the processes qualified, and approved by the Customer.
You will need to investigate with an NDT specialist what level of defect is detectable for your industry, and, discuss with the customer what is acceptable in terms of defect level, and explain that to guarantee this level of defect you will probably need some extra NDT inspection and welding rework.
Tagin Incorporating Large Language Model (LLM) AI into a QMS Coffee Break and Water Cooler Discussions 14
A Supplier File info for large (Microsoft) companies. Medical Device and FDA Regulations and Standards News 2
supadrai Remote Opportunity - Large Scale Glove Factory QMS / RA / Legal Job Openings, Consulting and Employment Opportunities 0
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Large outside micrometers calibrations General Measurement Device and Calibration Topics 2
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
M Informational EU – Minutes of the 24 July 2019 SCHEER Working Group on safety of breast implants in relation to anaplastic large cell lymphoma (BIA-ALCL) meeting Medical Device and FDA Regulations and Standards News 0
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
P Large data sets of continuous individual data - Estimated or actual deviation Capability, Accuracy and Stability - Processes, Machines, etc. 2
M FDA News USFDA – Breast Implant Associated- Anaplastic Large Cell Lymphoma (BIA-ALCL) – Letter to Health Care Providers Medical Device and FDA Regulations and Standards News 0
S My department inherited a large number CAPAs ISO 13485:2016 - Medical Device Quality Management Systems 4
M Tracking External Oversight at a large Naval Shipyard Quality Manager and Management Related Issues 9
K Testing Large Plastic Pipe Imported Legacy Blogs 0
M Leaving Footprints in the Data - Large Database Validation Statistical Analysis Tools, Techniques and SPC 7
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
P IT tools for Knowledge Sharing in a large Organization Misc. Quality Assurance and Business Systems Related Topics 1
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M David vs Goliath (Large Suppliers vs Low Volume Purchasers) Supplier Quality Assurance and other Supplier Issues 11
R Which large corporations require their suppliers to be ISO 9001 certified? Registrars and Notified Bodies 14
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
M Large Construction Project Quality Plan - ISO 9001-2008 using ISO 10006 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
M Large Sample Size - up to 32 - for Control Charts Capability, Accuracy and Stability - Processes, Machines, etc. 2
N Definition of Large-Scale Fixed Installation per the RoHS2 Directive EU Medical Device Regulations 3
D Single-Point Scale Calibration - Very Large Scales General Measurement Device and Calibration Topics 3
D Large, untoleranced radius of 20? - Inspection and Tolerancing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Recently purchased a large number of gages (measurement equipment) General Measurement Device and Calibration Topics 13
T How to move from a small company to a large company Career and Occupation Discussions 7
Proud Liberal Minitab - Organizing a large number of graphs using file details Using Minitab Software 5
J ISO13485 File-Index getting too large Document Control Systems, Procedures, Forms and Templates 2
H Certification of a large commercial helicopter acc. AC29-2C / CS29 EASA and JAA Aviation Standards and Requirements 1
M What is an acceptable PPM for large volume fasteners? APQP and PPAP 6
V Sample Size for Attribute Data - Large Production Lots Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q "Enterprise Certification" in Large Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Using a Tape Measure for +/- 1/16" Tolerance - Large Welded Assemblies (6 to 12') Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Capability Analysis of a Small Sample Size (as small as 2 and as large as 30) Statistical Analysis Tools, Techniques and SPC 14
D "On Time Delivery" Flowdown from Large Corporation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L DPPM (Defective Parts Per Million) Reporting - Large Quantity Approach Benchmarking 8
A The use of SPC in Graphic Design and Large Printers Lean in Manufacturing and Service Industries 14
D CMM vs. Measuring Arm for both Large and Small Items Inspection, Prints (Drawings), Testing, Sampling and Related Topics 26
S Special Inspection Levels - Batch sizes are large (typically 100k - 150k) AQL - Acceptable Quality Level 10
A What is a good Sampling Plan for LARGE Lots of Supplier Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S AS9100 REV B Sampling Requirements - Heat Treatment of Large Cylinders AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
bobdoering Dr Wheeler pokes at the Theorem of Large Numbers Statistical Analysis Tools, Techniques and SPC 2
F Determining the Number of Samples for receiving large lots of wire? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O Average Life Cycle Duration for a large number of medical equipment types Other Medical Device and Orthopedic Related Topics 2
C Seeking a holder/jig to calibrate large OD micrometer calipers (up to 23") General Measurement Device and Calibration Topics 8
J Large Weldment Inspection Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J Large Projects, large number of partners? Document Numbering/Identifying Issues Benchmarking 6
K Inspection filter needed - Large machine tools Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
