Laser Etching on Stainless Steel Knobs - Quality Issue
H
Hiccup
Hi all,
I source some stainless steel knobs and have encountered a possible quality issue. A substance seems to be coming off. I perform an adhesion and rub test to test the quality of the etching and the last test I did, the substance came off on both tests, resulting in fading.
[FONT=&quot]1. [/FONT][FONT=&quot]Use a white cotton cloth soaked in water and rub printed logo 20 times. Repeat test using cloth soaked in alcohol. Look for damage to printing on logo.[/FONT]​
[FONT=&quot]2. [/FONT][FONT=&quot]Firmly stick 3M tape onto printed logo and then remove tape. Look for damage to printing on logo.[/FONT]​
[FONT=&quot]-Use 70% Isopropyl (rubbing alcohol).
[/FONT]The factory says the quality is fine (same as always) and that what is coming off is just residue that builds up during the process. Is this an accurate statement or is the quality of the etching not up to snuff? Is my quality test reasonable? The knobs have not failed this test before.
Q
Quality Practitioner
Hi Hiccup,
I have seen this before, the residue is burned in carbon deposits from the process. As long as the information/text that is lasered onto the surface is still clear and legible and to specification text height etc I think this is fine.
Regards
Chris
Hi Hiccup,
Regards
Chris
Can you comment on Hiccup's test method? It seems that use of alcohol might not be a good thing.
bobdoering
Stop X-bar/R Madness!!
I have used alcohol in the past to remove the loose burn products. It should have no effect on the laser mark. If the loose product are removed and the actual laser mark is light, then it needs adjusted.
I don't know why anyone would want to use an alcohol-rub test on laser etching to begin with. Sounds more like something to use on pad printing or silk screening.
bobdoering
It safely removes loose material and dries quick with no residue.
Ends up being the same thing.
Well, no. Rub testing with solvents is done on paint or ink (pad printing, e.g.) to test the durability and resistance of the applied material. There's no point in doing that to something that's engraved or etched. If the residue needs to be removed, a cleaning operation is needed, not a test method.
bobdoering
With laser marking, you clean off any loose residue by rubbing it with alcohol, and determine if the remaining marking is legible. It is not a durability test, and the reason why it is a test and not a process is because in most cases the residue is left on the part, and the only issue is if it gets rubbed off will the underlying etch still be readable.
M Laser Etching Advice for Permanent Device Marking Manufacturing and Related Processes 5
ISOsandy Laser Etching - Company that will repair/service an InstaMark (control laser) - Help! Manufacturing and Related Processes 7
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
M Informational US FDA Laser guidances Medical Device and FDA Regulations and Standards News 2
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Medical Device Classification - Laser Guided Positioner EU Medical Device Regulations 2
Pmarszal Precise Laser Printer: Recommendation Manufacturing and Related Processes 2
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
B IEC 60825-1 Class 3R Laser Off-The-Shelf or Custom Label Needed Other ISO and International Standards and European Regulations 3
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Innovation in Laser Welding Manufacturing and Related Processes 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
A Standards for Emergency Button for a Dental Laser IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Laser Wavelength Traceability for Laser Interferometers General Measurement Device and Calibration Topics 4
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
A Dental Laser Certification IEC 62304 for a Firmware IEC 62304 - Medical Device Software Life Cycle Processes 1
A Type of Materials to comply with IEC 60601 (Dental Laser Case) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P White Light vs. Laser Scanner - Investing in a 3d Scanner Quality Tools, Improvement and Analysis 6
S FDA releases Updated Laser Products Regulation Other US Medical Device Regulations 1
P Laboratory Scope for a Laser Fabrication Shop IATF 16949 - Automotive Quality Systems Standard 2
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
P 400 micron Difference between CMM Results and Laser Tracker Results General Measurement Device and Calibration Topics 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Method to determine the Uncertainty of the readings of a Laser Scanner Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
Q Do FDA Laser Regulations Apply to Components? US Food and Drug Administration (FDA) 1
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
A Substantial Equivalence for Laser Wavelength - Class 2 Aesthetic Product Various Other Specifications, Standards, and related Requirements 2
E Faro Laser Tracker Calibration Source Needed General Measurement Device and Calibration Topics 5
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
H Reusable Soft Tissue Surgical Laser Fiber Sterilization Method US Food and Drug Administration (FDA) 3
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
