I work for a company that measures shafts. We have a lot of bench gauges with length scales installed in them and use a combination of tooling and software to set offsets for different tooling combinations. One issue I have is that not all of the gauges have the same type of tooling. I’m trying to look into being able to verify linearity in length on these machines. My issue is I dont want to have 50 masters laying around because of all the different tooling types. If everything had a flat to flat tooling, we could have 2-3 masters and be done.
instead, I thought about how cool it would be if I just had a laser or optical send and receive system where I put one on the headstock of the machine and the receiving end on the tailstock. Then get a live read, set a reference point, and check linearity at 2-3 points along the scale. The problem is, I dont know of a measurement system like this. I was hoping that posting here might being forth some options. Does anyone have any ideas?
The way we currently handle this is by having masters that we verify annually and we master the gauge to that. However, this will only show accuracy at one point, but not linearly. Thoughts? Would prefer a measurement system that can do metric and atleast have a resolution of 0.010 (if thats even feasible). Our length measurements usually range in the +\- 0.8mm for our smallest tolerance and +\- 1.5mm for our biggest tolerances. 10 microns might be a stretch, but if its available, we would like to explore that option.
