Laser Marking effects on the Fatigue Strength of Alloys
E
elsatercool
During reviewing my technical file class III , reviewer asked issued CAR :
[FONT=&quot]The laser marking drawing indicated markings in the highly stressed zone of the stem: it is known that laser marking can affect the fatigue strength of alloys and therefore should be restricted to low stress regions and be minimised in extent [/FONT]
Attached the Drawing , Please HELP ME
Mikishots
Not sure what you're asking as there doesn't seem to be a question here. Can you clarify?
If I was to go out on a limb, I'd suggest to follow the advice from the CAR issuer, unless you have reason or proof to contest it.
pkost
You laser marking does appear to be rather large, I would follow the advice of the reviewer - move it to an area of lower stress and make it much smaller!
Also keep it away from areas of significant wear
John Broomfield
elsatercool,
It is time to request a design change of EMED.
The design will either be changed or the designer will explain why the laser marking is benign.
Either way you have closed the CAR.
John
E
elsatercool
I asked about the reply on the reviewer comment , Means "The influence of laser marking on the material CO Cr "
Can you have an FEA (Finite Element Analysis) run on the part? This could simulate the laser etch and show the effect on stress concentration.
pkost
The effect of the laser will to be a very localised heating of the material that will change it's structure. This will affect the material properties although only to a very localised extent. The problem is that you need to understand the effect of that localised change on the performance of the stem as a whole
Miner - there are more things to consider here than just stress - effect on fatigue, wear properties and characterisation of the wear particles that may be produced. This then follows on to the potential for these factors to exacerbate other risks that are known to be present in hip joints
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Laser Etching Advice for Permanent Device Marking Manufacturing and Related Processes 5
C CE Marking for PCB Components for Laser Printer Cartridges CE Marking (Conformité Européene) / CB Scheme 5
M Procedure for Validating Laser Marking & Electropolishing of Orthopedic Implants Other Medical Device and Orthopedic Related Topics 13
A CE Marking Basics - Medical Laser - Compiling the Technical File ISO 13485:2016 - Medical Device Quality Management Systems 8
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
M Informational US FDA Laser guidances Medical Device and FDA Regulations and Standards News 2
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
S Medical Device Classification - Laser Guided Positioner EU Medical Device Regulations 2
Pmarszal Precise Laser Printer: Recommendation Manufacturing and Related Processes 2
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
B IEC 60825-1 Class 3R Laser Off-The-Shelf or Custom Label Needed Other ISO and International Standards and European Regulations 3
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Innovation in Laser Welding Manufacturing and Related Processes 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
A Standards for Emergency Button for a Dental Laser IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Laser Wavelength Traceability for Laser Interferometers General Measurement Device and Calibration Topics 4
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
A Dental Laser Certification IEC 62304 for a Firmware IEC 62304 - Medical Device Software Life Cycle Processes 1
A Type of Materials to comply with IEC 60601 (Dental Laser Case) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P White Light vs. Laser Scanner - Investing in a 3d Scanner Quality Tools, Improvement and Analysis 6
S FDA releases Updated Laser Products Regulation Other US Medical Device Regulations 1
P Laboratory Scope for a Laser Fabrication Shop IATF 16949 - Automotive Quality Systems Standard 2
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
H Laser Etching on Stainless Steel Knobs - Quality Issue Manufacturing and Related Processes 17
P 400 micron Difference between CMM Results and Laser Tracker Results General Measurement Device and Calibration Topics 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Method to determine the Uncertainty of the readings of a Laser Scanner Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
Q Do FDA Laser Regulations Apply to Components? US Food and Drug Administration (FDA) 1
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
A Substantial Equivalence for Laser Wavelength - Class 2 Aesthetic Product Various Other Specifications, Standards, and related Requirements 2
E Faro Laser Tracker Calibration Source Needed General Measurement Device and Calibration Topics 5
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
