Laser Weld Strength - Laser Welding Medical Instruments
b9ofus
We are laser welding medical instruments togeter and need to do a strength test. Two pieces we are currently needing to test are Ø11.00 mm OD and Ø9.00 mm ID. The will be welded completely around the OD. The joint will be a lap joint. Weld depth will be approx .2mm. Is there any kind of spec for what the weld strength should be on medical instruments?
Thanks for your help.
Ronen E
Problem Solver
Moderator
Sorry, but I am not aware of any such standard (which of course doesn't mean no such standard exists). Anyway, from a performance perspective - will this joint be subject to any mechanical load? If so, IMO that should direct you to the strength requirement and test method.
Cheers,
Ronen.
tonefordays
Are there any customer requirements? Are there any welding symbols or notes shown on the drawing for the part in question?
Weld strength is going to be determined by weld size, base material, and filler metal (among others variables). I would assume that since this is for medical use, that there is a welding procedure specification that is being followed and has been approved by the customer. The welding procedure will define the limitations for the variables allowed for the given process being used. Having a qualified procedure will ensure (if followed properly) that the strength is satisfactory based on the testing involved in qualifying the procedure.
If there is a specific weld strength needed, the engineer of the parts should specify on the drawing all the requirements. Determining weld strength isn't the suppliers responsibility unless you are in control of design.
What material are you welding?
b9ofus
This particular customer has not approved a welding procedure. We are quite sure that the weld is strong but how strong we don't know and what strength is "Good" we don't know. There is no requirement on the drawing. Even the method of welding is up to us (Tig or Laser) The material is 17-4 SS for both parts being welded.
b9ofus
The part is used as some kind of angled driver. There will be some stress but I do not know to what extent.
pkost
I'm unaware of any general "welding in medical devices standard". There may be a device specific standard but I don't know what device you are making, even then in orthopaedics there are a number of standards that tell you how to measure the strength of a device but not what would be an acceptable limit as this is heavily dependent on application
You really need to speak to them so that you can get more detail - as I'm sure you are aware the welding process needs to be validated. Therefore the manufacturer/customer must have defined acceptable values.
tonefordays
b9ofus
If the customer hasn't provided any requirements, and this is a non critical device for non critical application, then as long as you follow good practice, and are aware of visual inspection criteria, all should be good.
If this is going to be an autogenous weld (no filler metal), look closely for crater cracks, throat cracks.
If you are going to use filler, be sure to use the proper filler, I believe E630 is the proper filler for 17-4, assuming the 17-4 has not been heat treated yet.
Look for discontinuities or defects such as undercut, underfill, overlap, any cracks. Cracks are never allowed regardless of size. Be sure weld profile is correct without excessive concavity or convexity.
Excessive concavity will result in a weaker weld, allowing for the possibility of cracking with repeated expansion and contraction cycles.
Excessive convexity could result in overlap at the toes of the weld, which could create a stress riser or notch, this could, under the right circumstances, be a place for cracks to propogate.
jazzalbart
Well, I just want to recommend you that whatever laser medical instrument you use but be careful about its safety. [FONT=Liberation Serif, serif]Be[/FONT][FONT=Liberation Serif, serif]cause [/FONT][FONT=Liberation Serif, serif]Medical laser applications are based primarily on the properties of energy absorption and tissue interaction. So they can damage quickly.[/FONT]
D Laser Weld Operational Qualification ISO 13485:2016 - Medical Device Quality Management Systems 3
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
M Informational US FDA Laser guidances Medical Device and FDA Regulations and Standards News 2
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Medical Device Classification - Laser Guided Positioner EU Medical Device Regulations 2
Pmarszal Precise Laser Printer: Recommendation Manufacturing and Related Processes 2
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
M Laser Etching Advice for Permanent Device Marking Manufacturing and Related Processes 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
B IEC 60825-1 Class 3R Laser Off-The-Shelf or Custom Label Needed Other ISO and International Standards and European Regulations 3
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Innovation in Laser Welding Manufacturing and Related Processes 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
A Standards for Emergency Button for a Dental Laser IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Laser Wavelength Traceability for Laser Interferometers General Measurement Device and Calibration Topics 4
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
A Dental Laser Certification IEC 62304 for a Firmware IEC 62304 - Medical Device Software Life Cycle Processes 1
A Type of Materials to comply with IEC 60601 (Dental Laser Case) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P White Light vs. Laser Scanner - Investing in a 3d Scanner Quality Tools, Improvement and Analysis 6
S FDA releases Updated Laser Products Regulation Other US Medical Device Regulations 1
P Laboratory Scope for a Laser Fabrication Shop IATF 16949 - Automotive Quality Systems Standard 2
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
H Laser Etching on Stainless Steel Knobs - Quality Issue Manufacturing and Related Processes 17
P 400 micron Difference between CMM Results and Laser Tracker Results General Measurement Device and Calibration Topics 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Method to determine the Uncertainty of the readings of a Laser Scanner Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Do FDA Laser Regulations Apply to Components? US Food and Drug Administration (FDA) 1
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
A Substantial Equivalence for Laser Wavelength - Class 2 Aesthetic Product Various Other Specifications, Standards, and related Requirements 2
E Faro Laser Tracker Calibration Source Needed General Measurement Device and Calibration Topics 5
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
H Reusable Soft Tissue Surgical Laser Fiber Sterilization Method US Food and Drug Administration (FDA) 3
E Blade Inspection - Does anyone use blade scaning software for a CMM or laser scanner? Design and Development of Products and Processes 3
