Laser Welding Process - Impact on Electrical Properties
Good Day,
We are doing laser welding to fuse Cu sheet & Cu terminal,
I have a question on that, does the laser welding affect the electrical properties of Cu sheet / Cu Terminal?
Anyone please help on this.
Thanks,
Vivek
lyuluck
The quality of laser welding has a direct influence on properties such as absorptivity, thermal conductivity, and viscosity of the melt. etc. Bad laser welding with copper even creates safety issues.
Vivek
Bad welding may create some other issues. But I would like to know the impact on electrical properties such as conductivity, resistance etc.
thanks.
@Vivek I do not know the answer to your question directly, but will ask a few questions that may guide you. These questions come at the problem from a physics perspective.
  • Can the laser welding process create nonconductive impurities/oxidation?
  • Can the laser welding process reduce the cross-sectional area through which current must flow?
Either of these could reduce conductivity/increase resistance.
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
A Innovation in Laser Welding Manufacturing and Related Processes 2
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
bobdoering US Standard for Laser Welding of small parts Various Other Specifications, Standards, and related Requirements 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
M Cleaning Process after laser marking on orthopaedic implants Other Medical Device and Orthopedic Related Topics 3
M Informational US FDA Laser guidances Medical Device and FDA Regulations and Standards News 2
V Class IV Laser Regulations IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Installation Qualification (IQ) and Operational Qualification (OQ) for Laser Marking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Medical Device Classification - Laser Guided Positioner EU Medical Device Regulations 2
Pmarszal Precise Laser Printer: Recommendation Manufacturing and Related Processes 2
M Laser Micrometer Suggestion (if any) for diameters that are +/-.0001 inch General Measurement Device and Calibration Topics 1
G Traceability of laser based x-y measuring machine General Measurement Device and Calibration Topics 5
T A question on Calibration on In-line Laser Micrometer General Measurement Device and Calibration Topics 1
M Laser Etching Advice for Permanent Device Marking Manufacturing and Related Processes 5
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
G Metrology Laser Reliability General Measurement Device and Calibration Topics 2
B IEC 60825-1 Class 3R Laser Off-The-Shelf or Custom Label Needed Other ISO and International Standards and European Regulations 3
A Is IEC 80601-2-60 necessary for Dental Laser? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
A Standards for Emergency Button for a Dental Laser IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Laser Wavelength Traceability for Laser Interferometers General Measurement Device and Calibration Topics 4
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
A Dental Laser Certification IEC 62304 for a Firmware IEC 62304 - Medical Device Software Life Cycle Processes 1
A Type of Materials to comply with IEC 60601 (Dental Laser Case) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P White Light vs. Laser Scanner - Investing in a 3d Scanner Quality Tools, Improvement and Analysis 6
S FDA releases Updated Laser Products Regulation Other US Medical Device Regulations 1
P Laboratory Scope for a Laser Fabrication Shop IATF 16949 - Automotive Quality Systems Standard 2
Fender1 PPAP-PSW Accuracy Concern - Laser Cut Holes In Formed Fabricated Steel Part APQP and PPAP 15
E Laser Marking effects on the Fatigue Strength of Alloys CE Marking (Conformité Européene) / CB Scheme 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
H Laser Etching on Stainless Steel Knobs - Quality Issue Manufacturing and Related Processes 17
P 400 micron Difference between CMM Results and Laser Tracker Results General Measurement Device and Calibration Topics 7
D FMEA for Laser Cutting of Die Cast parts in AM60B Magnesium FMEA and Control Plans 1
J Method to determine the Uncertainty of the readings of a Laser Scanner Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Do FDA Laser Regulations Apply to Components? US Food and Drug Administration (FDA) 1
D How to do MSA on a Laser Mike, Rules, and Pressure Gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Internal Calibration for Laser Temperature Gauges Manufacturing and Related Processes 3
A Substantial Equivalence for Laser Wavelength - Class 2 Aesthetic Product Various Other Specifications, Standards, and related Requirements 2
E Faro Laser Tracker Calibration Source Needed General Measurement Device and Calibration Topics 5
D Laboratory where we can have parts checked for Thickness with a Laser Micrometer General Measurement Device and Calibration Topics 6
D Laser Micrometer for checking Thickness of Steel - Any Recommendations or Comments General Measurement Device and Calibration Topics 3
H Reusable Soft Tissue Surgical Laser Fiber Sterilization Method US Food and Drug Administration (FDA) 3
