Layered Process Audits vs. Internal System Audits
Marc
#11
Re: Layered Process Audits vs Internal System Audits
OK - The focus is on processes. Does that include shipping? Off line inspections?
Helmut Jilling
Auditor / Consultant
#12
The LPA's I have seen generally included questions about inline inspections, first piece inspections, and final inspections. Those can be offline at many companies.
Packaging is generally included, so I would think it could extend to Shipping, as well.
Douglas E. Purdy
#13
They cannot take the place of internal audits. As discussed throughout this thread, they are different in a number of ways. If properly constructed, they could fulfill the requirements for Manufacturing Process Audits (TS cl 8.2.2.2).
Yea, that is where I went. I first was going to make a distinction between LPAs and TS Manufacturing & Product Audits (see 102506 overview), but since management was so into the LPA I am in the process of modifying the LPA to cover both the manufacturing and product audit requirements (see 111006 overview). To make the LPA work for me (A Cove Principle), I went with the following wording to deal with the objective and impartial requirements:
Auditors performing LPAs are to be knowledgeable of the process for planning and
executing the manufacturing processes as well as the controls for ensuring that only
defect free product is released to the customer. Due to the multi-disciplinary approach to
planning and executing the manufacturing process, a LPA will most likely be performed
by an auditor who has played some role in the process. The coordinator of LPAs is to
ensure that the objectives of LPAs are understood by the auditors and that their conduct
and audit reporting are objective and impartial.
Still Working It!
Doug
Marc
#15
I would like to edit my input to this thread. How can I change attachments I have entered?
'Edit' your post. You'll get the 'mini' edit window. You'll see a tab/button that says 'Go Advanced' - Click on it and it will take you to the full editing mode window. Scroll down a bit and you will see a tab/button that says 'Manage Attachments'. There you can Delete and Add attachments.
NOTE: Editing of posts is open for 7 days from the post date except for Moderators and Administrators. If anyone needs to edit a post after 7 days, just let me know and I'll help. This is set at 7 days because a few years ago someone came in and deleted every post they had posted, and deleted every attachment, going back a couple of years. I don't know why, but I didn't think that was quite 'fair'. It screwed up a lot of discussion threads.
#16
I have the strategie for 2007 to implement LPA. It seems they can be value added according what I have read. Does anybody reccomend to take care for something in particualr regarding your experience?
Raffy
#17
What is actually layered process audit? :confused: Is it the same with the manufacturing checklist in which I can use during Manufacturing Audit?
Please advise.
TIA
Best regards,
Raff :cool:
Helmut Jilling
#18
Please advise.
TIA
Best regards,
Raff :cool:
Layered Process Audits are a Customer Specific Requirement from some customers. Hopefully, it is different than your Manufacturing Process Audits.
Manufacturing Process Audits ideally should be an in-depth review of the details of a particular manufacturing process. Most companies have trained auditors take a control plan and walk through all the checks, all the gages and documents, etc.
Layered Process Audits are promoted or required by certain customers as an additional activity. The framework typically is a one or two page checklist which is a fairly short overview of a particular product being produced. The "layers" come from different levels of managers participating in the same audit. Floor Supervisors, Area Managers, all the way up to top managers are intended to audit the same activity. The perceived benefit comes from the idea that different ranks of managers will see the same activity from different perspectives and might see weaknesses or improvements that others didn't spot. There is also the aspect that higher managers with greater authority are involved, which could bring additional benefit.
So, the two audits audit the same work cell, but in significantly different ways. However, you are free to adapt the techniques to suit your needs, because there is not much written as to mandatory approaches. Most is guidance type information, except customer requirements training such as DCX provides.
D Layered Process Audits - FCA 9.2.2 - Exemption Clause? IATF 16949 - Automotive Quality Systems Standard 5
J Requirements for Layered Process Audits including Maintenance, Shipping, Receiving IATF 16949 - Automotive Quality Systems Standard 4
J Layered Process Audits using Kamishibai Board Process Audits and Layered Process Audits 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
S Help explaining LPA (Layered Process Audits) IATF 16949 - Automotive Quality Systems Standard 4
V QSB Layered Process Audits GM/OPEL Customer and Company Specific Requirements 3
R Layered Process Audits Procedure of Form Process Audits and Layered Process Audits 3
A LPA's (Layered Process Audits) for Non-Production Support Processes Process Audits and Layered Process Audits 13
C Handling Repeated Non-Conformities when doing Layered Process Audits Process Audits and Layered Process Audits 11
automoto Implementation of Layered Process Audits (LPA) Process Audits and Layered Process Audits 7
L Layered Process Audits: Efficiency, quality, safety or all the above? Process Audits and Layered Process Audits 11
L Having faith in your Layered Process Auditors - Pencil whipping audits Process Audits and Layered Process Audits 8
A Definition Layered Process Audits - What are Layered Process Audits? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
H LPA's (Layered Process Audits) - Evaluation of Effectiveness Process Audits and Layered Process Audits 22
J LPAs (Layered Process Audits) and TS 16949 Clause 8.2.2.2 - Quick Question Process Audits and Layered Process Audits 20
J Evaluating and Reporting the Results of Layered Process Audits Document Control Systems, Procedures, Forms and Templates 9
M The Difference between Process Audits and Layered Audits General Auditing Discussions 5
F Tell me about Layered Process Audits (LPA) Process Audits and Layered Process Audits 2
A Layered Process Audits - Getting Results? Show me the data! Process Audits and Layered Process Audits 11
J Does anyone have a procedure that covers Layered Process Audits Process Audits and Layered Process Audits 1
J Internal Process Auditing - Auditor Unhappy - Wants Layered Process Audits Process Audits and Layered Process Audits 13
T Does Delphi's requirement for layered process audits only apply to their products? Process Audits and Layered Process Audits 15
Crusader Layered Process Audits - Recommended Reading? Process Audits and Layered Process Audits 24
R Layered Audits - Where to tie the layered audit process back to FMEA & Control Plan FMEA and Control Plans 10
D Layered Process Audits? Are they required by TS16949? Process Audits and Layered Process Audits 13
B Defining Top Management for Layered Process Audits Process Audits and Layered Process Audits 9
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
K Layered Process Audit (LPA) Software IATF 16949 - Automotive Quality Systems Standard 5
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
H Layered Process Audit Hard Copy Records Retention Records and Data - Quality, Legal and Other Evidence 6
N LPA (Layered Process Audit) Program - Visual Shop Display Process Audits and Layered Process Audits 4
T Historical Backround of LPA (Layered Process Audit) Process Audits and Layered Process Audits 7
Celtic Warrior Consolidating results of LPA (Layered Process Audit) for Management Review Process Audits and Layered Process Audits 13
A Access Database for LPA (Layered Process Audit) questions Process Audits and Layered Process Audits 3
V Layered Process Audit Schedule example Process Audits and Layered Process Audits 2
S Layered Process Audit Examples Process Audits and Layered Process Audits 4
I Can we use layered process audit (LPA) for HR Processes? Process Audits and Layered Process Audits 9
L Layered Process Audit Basics Explained Process Audits and Layered Process Audits 5
Q Layered Process Auditing (LPA) for a service provider Process Audits and Layered Process Audits 4
Douglas E. Purdy Delphi CSR (Customer Specific Requirements) and LPAs (Layered Process Audit) IATF 16949 - Automotive Quality Systems Standard 3
J What is meant by number of "items"? Chrysler Layered Process Audit Question Process Audits and Layered Process Audits 10
J Layered Process Audit Examples Process Audits and Layered Process Audits 25
P Layered Process Audit & the Document Audit - Can anyone explain to me, Please? Process Audits and Layered Process Audits 2
K What is a 'layered audit'? Layered Process Audit (LPA) - A GM requirement? Process Audits and Layered Process Audits 9
A Layered Process Audit Guidelines - The AIAG's CQI-8 Process Audits and Layered Process Audits 17
M Layered Process Audit (LPA) - Discipline in completely filling in the reports Process Audits and Layered Process Audits 3
Z Layered Process Audit Training - Need Powerpoint Presentation to train LPA auditors Process Audits and Layered Process Audits 5
PatMaz Layered Process Audit Procedure - Seeking an example Process Audits and Layered Process Audits 5
C DaimlerChrysler Layered Process audit experiences per the DC CSR's Process Audits and Layered Process Audits 3
C DaimlerChrysler Layered Process Audit Experiences per the DC CSR's Process Audits and Layered Process Audits 2
