Layout Of Management Review Meeting Form
#11
Debbie
Randy is right (of course) - the clause provides the basic template for Man Rev. Just make sure that you review the information that tells you how your QMS is working - ensuring that you cover at least those items in 5.6.2.
The outputs from the review should be in the form that allows you to assign any actions required to individuals and with timescales for their completion. In my experience, outputs are not always done very well, they often comprise just a record of what was discussed rather than what will be done about what was discussed, or at least confirming that no action is required at this time.
Good deal, Colpart!
From the examples here, I'm more than a little concerned that management review doesn't become a 'form filling' exercise.
Although I've read many excellent postings, I fail to see how 'going through the standard' or similar is going to do anything for management. Sure external auditors will love it, but that's not what this review is for.:nope:
As posted many times in the past, Management Review is a navigational exercise, using data from the quality system, including customer feedback, process & product performance and audits. We should be comparing the performance against the objectives and coming to some conclusions about whether the organization followed its processes (results of audits). We can then decide what to correct and what to improve.:yes:
The forms make it look like lip service to me. I'd wager that if we asked your management what this review is all about they have some problems giving a good account! Yeah, I know, you'll all say otherwise, but think. If it wasn't for you, would they even hold a review.............:notme:
:2cents:
Crusader
#12
akalbulus
#13
Here's all you need.
5.6.2 Review input
The input to management review shall include information on
a) results of audits,
b) customer feedback,
c) process performance and product conformity,
d) status of preventive and corrective actions,
e) follow-up actions from previous management reviews,
f) changes that could affect the quality management system, and
g) recommendations for improvement.
Hi guys, i would like to know more about point (C) :
Could you guys explain it to me?
Thanx :agree1:
Stijloor
#14
Thanx :agree1:
Hello akalbulus,
Very simple:
How are your processes performing? (Measures of effectiveness and efficiency)
What is the quality of your product? (Quality measures such as PPM, Inspection and test results, etc.)
Search here on The Cove on Process and Product Performance Measures.
Stijloor.
Colin
#15
I like to think of management review as a summary activity so I try to link the MR inputs to other clauses wherever possible. e.g.
a) see 8.2.2
b) see 8.2.1
c) see 8.2.3 & 8.2.4
d) 8.5.2 & 8.5.3
Now, I am not saying this is all I do but as we know, section 8 is about monitoring and measuring where we currently are so the MR should allow us to take a step back and review current performance with a view to deciding if and how we are going to move forwards. By the way, I don't usually do g) as a separate agenda item, I attach it to all inputs.
Colin
#17
It is not a mandatory 'documented procedure' but there must be control over the process. Many organisations do have one. Do a search on this forum, there are a few very good threads on the subject with arguments from both sides.
G
Gary E MacLean
#19
Thanx :agree1:
5.6.2.c: The input to Management Review shall include information on process performance and product conformity.
We must include that first part of "c". ISO is talking about the input to the management review meeting. In other words the stuff people will bring into the meeting with them to talk about or to present. The stuff that actually makes the meeting. So that is the first understanding, all of those points, "a thru g", are required input for the meeting. In order to have something tangible to discuss or to "meet" about there must be something done and something produced. That leads us to a thru g and in your case in particular, to letter c.
One of the first things you will do in the creation of any Quality Management System (QMS) is to;
4.1.a: The organization shall identify the processes needed for the QMS...
That identification will have a lot to do with 5.6.2.c because at;
4.1.c: determine criteria and methods needed...
and then at;
4.1.e: monitor, measure and analyse these processes...
we are told what we will do with those processes. Finally, that brings us to your initial question;
What is the deal with 5.6.2.c; two things:
Do your products conform?
The quick answer for Process Performance is
1) (4.1.a) Identify your processes
2) (4.1.c) Determine criteria and methods
3) (4.1.e) Identify a key measure for each process
4) (8.4.c) Run a trend chart of some kind on the data
5) (5.6.2.c) Take the measurable chart into Management Review as input to discuss performance of your identifed processes.
Product conformity seems a bit more direct. I would suggest you collect information related to internal scrap, internal defects, FAIR performance, PPAP performance, WIP Inspection, Final Inspection, Dock Audit results and so on. This data is all indicative as to whether your product is in conformance or not. Analyze it, summarize it and take your interpretation in to Mangement Review as required input to that meeting - discuss it.
There you go - good luck
G
Gary E MacLean
#20
Hello Wehttam,
Simple answer: NO.
There is no requirement for a written procedure for management review.
However, you must maintain records.
Stijloor.
Having a requirement for something and "actually needing" something are two entirely different things. Although the requirement does not exist that you issue a SOP for Management Review there is the requirement that you
4.1: ...establish, document, implement and maintain a Quality Management System (QMS) ... in accordance with the requirements of this International Standard.
In other words, document what you perceive as your QMS. If you believe your Management Review process is a part of your QMS then you "need" to issue the type of document you feel is required for that process; perhaps SOPs.
In addition, even though "NOTES" are not supposed to be auditable there is the Note at the end of 4.1 that reads like;
NOTE: Processes needed for the QMS referred to above should include processes for management activites (5.0), provision of resources (6.0), product realization (7.0), and measurement (8.0).
In other words ISO is not "requiring" specific documentation but they are implying that you issue the documents you "need"
What decision making process do you use to determine if you "need" a document or not? In my consuolting mind I tell every client to document their process for Management Review because I feel it is so important. In fact it is so important it is generally one of the earliest processes I ask clints to put in place, second only to their documentation approach.
Short answer, one opinion? Yes you need an SOP for management review, whether it is required or not.
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
M Microbiological Testing Lab - Layout & Standards Other Medical Device Regulations World-Wide 0
E Layouts : Can you "verify" things that are not visible (such as loctite present, internal dimensions) in a layout ? APQP and PPAP 2
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
C Detection Action for Failure Effects - AIAG 4th Edition Layout FMEA and Control Plans 5
MDD_QNA Changing the Layout of Medical Device Label(s) CE Marking (Conformité Européene) / CB Scheme 3
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
D Implementing 5S for Multiple Shop Floor Layout Workstations Lean in Manufacturing and Service Industries 2
B Is Gage R&R required on a 100% Dimensional Layout? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
E ISO 17025 Compliant Laboratory Layout ISO 17025 related Discussions 3
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
O Make Layout Higher Resolution? Using Minitab Software 1
O Matlab Layout Command to Increase Size Using Minitab Software 1
M Reporting Composite FCF on Layout (GD&T) Various Other Specifications, Standards, and related Requirements 4
Q Is there a recommended lab layout for a ISO TS requirement? General Measurement Device and Calibration Topics 3
N CMM Layout Data Dispute between two CMM Laboratories General Measurement Device and Calibration Topics 8
T Does the Layout Design of a PCB fall under clause 7.3 in ISO 9001 Design and Development of Products and Processes 7
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
B TS 16949 PPAP/ Layout Inspection Frequency Requirements APQP and PPAP 8
Q Best tools to use to determine the best layout of a given area (Office) Process Maps, Process Mapping and Turtle Diagrams 9
L TS 16949 Clause 8.2.4.1 Layout inspection - Should we pay for this ? APQP and PPAP 4
N General Microbiological Laboratory Layout and Required Equipment General Measurement Device and Calibration Topics 6
J Would like to remodel our QA Layout Laboratory - Your ideas appreciated Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Warehouse Layout Design Lean in Manufacturing and Service Industries 11
I Layout Audit Requirements vs. Batch Inspections IATF 16949 - Automotive Quality Systems Standard 3
R Layout Inspection and Functional Testing - "Product" in 8.2.4.1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Howard Atkins Official TS answers from SMMT- Layout, System Audits, MR and Doc Control IATF 16949 - Automotive Quality Systems Standard 9
B Help with Submitting Part Layout Dimensionals - My first ever PPAP (to GM) APQP and PPAP 5
O The Layout of Dimensional Results and What to Provide the Customer APQP and PPAP 16
B Laboratory Layout - Please comment & give ideas on my proposal General Measurement Device and Calibration Topics 9
Z New Inspection Department Layout - 5S, Lean, etc... Lean in Manufacturing and Service Industries 4
H Lean Office and Office Layout - Sales, customer service, marketing, accounting, HR Lean in Manufacturing and Service Industries 4
S Plant Layouts - What should be in a Plant Layout? IATF 16949 - Automotive Quality Systems Standard 8
P Document Layout - Different layouts for documents depending upon the author Document Control Systems, Procedures, Forms and Templates 7
M 2 versions (different layout) of the same Quality Policy Document Control Systems, Procedures, Forms and Templates 3
L 'U-Shaped Flow' layout of a manufacturing plant Misc. Quality Assurance and Business Systems Related Topics 6
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
I Facility Planning and Layout Programs - Corolap & ALdep software? Design and Development of Products and Processes 2
S Layout inspection - product family approach? IATF 16949 - Automotive Quality Systems Standard 2
S Layout of the Manual of procedures Document Control Systems, Procedures, Forms and Templates 12
M Minitab macro vs. Layout tool Using Minitab Software 9
D Layout Inspection - Sound systems to a German car manufacturer IATF 16949 - Automotive Quality Systems Standard 2
V Plant Layout System from Scratch (AutoCAD) Manufacturing and Related Processes 4
R Layout Inspection Format and Improvement Document Control Systems, Procedures, Forms and Templates 1
C Layout Table (very large surface plate) Manufacturer Options - Warranty Hub Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M How to use Excel to track files for PPAP or annual layout due dates Excel .xls Spreadsheet Templates and Tools 2
S Layout and Dimensional Inspection Training Training - Internal, External, Online and Distance Learning 0
