I'm working to establish a pressure decay maximum psi loss. Is there a standard to reference or a correlation study of sorts that can be referenced.
For instance: Using a typical pressure decay unit with parameters of fill time, stabilization time, tes time and pressure. And ultimately the psi decay input decay.
Test Method Validation - How did you determine the air decay over what amount of time to demonstrate a No-Fluid Leak.
Can the allowable psi decay be 0.16 at 30 seconds? How did you choose the 0.16 psi ??
