Hello All,
I have received a customer complaint in a brake assembly in which leak is observed. After doing analysis on field samples, it is found that the leak is due to improper O-ring installation. Actually an O-ring is installed in a groove in the bore ID & piston is assembled in the Bore ID. This is done by manually.
Any improper placement of O-ring in the groove making the leak in the process. Now we would like to ensure the proper O-ring installation in the bore. Kindly suggest any process improvements to automate the O-ring installation in the groove of Bore ID. Kindly suggest
Thank you
Thank you
