Leakage Current test and Dielectric strength for Battery operated ECG device?
subbash
Hi All,
Is it required to perform leakage current test and Dielectric Strength test for battery operated ECG devices...?
Marcelo
To show compliance with the applicable leakage current test and Dielectric Strength test for a premarket review, for example, yes, it is.
subbash
Thanks for the reply Mr. Marcelo,
Since our device is a 3.7V battery powered ECG device, and is not connected to mains. Under the leakage current test, Patient leakage current test and Auxiliary leakage current test looks to be applicable for our device.
Section 8.7.2 of the standard mentions that Patient leakage current test and Auxiliary leakage current test are not measured in single fault condition. Hence we need not test at Single fault condition.
Please correct me if I have understood properly regarding the leakage current test.
Can you let me know how the Dielectric strength test is carried out for a battery powered medical device.
swathi.sp
Dear Folks,
Can any one let us know what are the electrical safety test need to perform in production line for Medical Devices.
Peter Selvey
Because the ECG has conductive electrodes to the patient, you still need at least "Type F" isolation barrier between the ECG circuit and all other parts. Usually the same isolation is relied on to pass the defibrillator proof testing. Typically ECGs are rated "Type CF, defibrillator proof" so that means 1.5kV dielectric strength, 4mm spacing, and <50µA with 275Vrms on the applied part. All the voltage tests would be done with the "hot" part (e.g. 1.5kV/5kV defib/275Vrms) applied to the ECG electrodes with all operator accessible parts wrapped in foil and grounded. I/O ports may or may not need grounding in the test depending on use/instructions/risk management.
An exception might be if the device is body worn. In this case the requirements apply, but there are no operator accessible parts, so no part to be grounded. It then becomes a bit like a Faraday cage (the device is still "hot" but nowhere for the voltage to go), hence no isolation required.
For production test, there is no strict requirement. The regulations require that standards be applied both in design and production, but production tests are usually simplified because they only need to address the possibility of variability and/or mistakes in production. So for example, the test in design might be first defib test, humidity pre-conditioning, followed by 1min 1.5kV dielectric strength and leakage current test, followed by warm up to normal temps and then repeat dielectric strength and leakage current test, then apply component fault conditions and re-check leakage current.
In contrast a production test might be just 1.5kV for 5s as a spot check which confirms there are no assembly errors.
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
W How can I test the Patient Leakage Current of an Infusion Pump? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
R Why DC limits more stringent than AC limits for Leakage Current Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Issues with leakage current testing for a CLASS II device since no PE and FE is present IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
M Leakage current measurement with non-frequency-weighted device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60335-1 leakage current measurement Other ISO and International Standards and European Regulations 3
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
J Exceeding the DC Leakage Current Limit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
L Building your own Leakage Current Tester IEC60990 Other US Medical Device Regulations 4
M Leakage Current Measuring Instrument - IEC 60601-1 Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R IEC 60601-2-49 - Touch Current (Enclosure Leakage Current) requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Medical Device Leakage Current Measurement with External Power Supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Pre-Conditioning Leakage Current IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Operator/Patient Leakage Current IEC 60601 - Battery Charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
P Leakage Currents and Patient Auxiliary Current under IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Leakage current from battery - IEC 60601-1 Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
N 60601-2-2 Ed 6 Clause 201.8.8.3.102 - HF instrument leakage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Measuring Leakage Currents with IEC 60601 defined Measurement Device (MD) IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
M ISO 13485 - Are Earth Leakage Tests Required? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Patient Leakage ISO 7176-14 vs. IEC 60601-1:2005 Reporting Requirements Other US Medical Device Regulations 1
M IEC60601-1 Battery Powered Body Worn Device Leakage Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Defining Expected Oxygen Leakage for Safety Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Understanding DC Patient Leakage Failure from 0.3VDC IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Whether some paths exist for leakage to get outside the LCD? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C USB, Clearances and Earth Leakage - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
K Calibration method for Torque Wrench & AC gas leakage Tester General Measurement Device and Calibration Topics 4
H Prodigit DC Electronic Load - Drawing current but showed 0 on the screeen Manufacturing and Related Processes 0
D Add new device to current license Canada Medical Device Regulations 0
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
W Need for current design or process control FMEA and Control Plans 2
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Informational TGA – Current status of breast implant products in Australia Medical Device and FDA Regulations and Standards News 0
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
Q Raising A CAPA on Current CAPA system US Food and Drug Administration (FDA) 3
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
A QMS - Medical Device - New company under a current one ISO 13485:2016 - Medical Device Quality Management Systems 3
K Questions on Technical File to show it is current EU Medical Device Regulations 5
H IS there any database for list of CE marked Medical devices and there current status EU Medical Device Regulations 8
B Mains fuses and OVER-CURRENT RELEASES IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
M IEC 60601-1 and Active Current Protection Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
