Interesting Discussion Lean Manufacturing Concepts - Is 'Lean' hype?
Is 'Lean' hype?
  • Total voters
    61
  • Poll closed .
psyched1
I really like Bev's drunk driving analogy so I'm going to continue with it. So the TPS implementation is failing because your (I don't mean you specifically, please don't take offense) not doing the root cause analysis, poke yoke, and other quality steps, and then you blame it on TPS. That's like blaiming the perfectly good vehicle for getting stuck on a muddy road even though you didn't try putting it in four wheel drive.
TPS/lean/demingism (whatever you want to call it) works. It's a perfectly good vehicle to bettering the capabilities of your factory. It's all about making the vehicle run in your environment.
Since I am not doing the implementation I don't take it personally. :cool:
The point I'm trying to make is the vehicle was not perfectly good (out of alignment, missing a wheel and headed off a cliff) but the results of a flawed quality system.
Without a solid design process based on compliance to a quality system we attempted lean. Implementing lean over a flawed system only allows for you to make more bad product faster or in lean terms gives you a greater chance to pull the chain and stop the process.
The question should be which comes first the chicken or the egg. I believe without a structured quality system based on prevention, lean will as my previous company did fail.
Lean is reactive and not preventive. Many have stated that you must fail to implement new corrective actions why not plan ahead using FEMA's, Control Plans, etc. Then again if your company was not failing you might not be implementing lean in the first place. :notme:
W
wmarhel
Yes our training was done by a state funded contractor who spent two days recreating a factory that built an electronic gadget that turned on a small light bulb.
When some of us began to ask questions about how we were not facing realistic properties in the training (design flaws, machine downtime and poor product from suppliers) we were ignored shut down and the instructor moved on. :whip:
Sounds like you had utilized the local MEP (Manufacturing Extension Partnership), please correct me if I'm wrong. If it was a MEP then this is pretty typical from what I've experienced with them in multiple states, with the only advantage to them being that the state picks up some of the tab.
Wayne
psyched1
Yes thats correct but I wasn't trying to point to the obvious perp.
I think they would have got better buy in by answering our questions even if they reflected poorly on the system he was peddling or he said he did not know. After all we are in the "Show Me" state.
P
potdar
I think we are straying. Do we all believe that Lean only means higher production at lower cost?
I believe a rethink is called for. Lean thinking / implementation starts with the concept of VALUE, on to charting the VALUE STREAMS, and then onwards to optimising FLOW, implementing PULL, finally aiming at PERFECTION. The sole aim of the exercise being to maximise the VALUE in the eyes of the customer. The word has not made an appearance so far in this thread.
After WWII, the Japanese started as a war ravaged nation with no resources churning out cheap low quality goods. Nothing different than what the companies that failed (discussed here) are doing. They used Lean and are successful today.
If our examples have failed, thats because they have not understood what the Japanese did in the name of Lean. That would also reflect on the implementers and their gurus.
E
Ernst Kong
I kind of disagree that lean is only for stable manufacturing companies. I work with (not for) a company that makes solid rocket motors for NASA and the defense department. They have been going "lean/TPS" for about 8 years. The differences it has made there are amazing and they are not necessarily a "stable" manufacturing environment. Many of the motors they make for NASA are one of a kind or come in orders of 5-10. I wouldn't call that stable.
stable = stable workforce , for which trust can be built upon.
One pre-requisite I observed during the implementation of Lean is that we need to address employees initial fear towards change, and trust that their jobs are secured, their opinion will be judged solely on fact not rank.
Also an ernomous amount of training is required , in my case > 200hrs/6mths for recruit and >80hrs/yr for all staffs, so it helps to have a stable workforce as to avoid unnecessary resource drain. Personally I don't any chance of suceess for company manned by temps. The culture just isn't there.
I believe lean provide the most benefits to manufacturing companies, viv-a-vis innovation-driven companies looking for breakthrough.
psyched1
Organizations hiring temps are not in the correct mindset for lean nor are companies who purchase from the lowest cost vendor without regard for quality.
If we consider value is design a value added item? The customer will pay for the product they usually do not care about the design. Is that why Lean/TPS avoids design engineering?
P
potdar
Value is directly proportional to utility and inversely proportional to cost. Both need to be worked on to improve value.
Lean thinking process recognises three aspects of operation as means of improving value:
development of new products - to improve utility.
customer service aspect - affects both cost and utility.
physical production - reduce costs using what have come to be known as 'lean techniques'. You will find many techniques here designed to take care of newly designed, even onetime jobs (e.g. SMED).
If TPS ignored engineering developments, everybody wouldn't want to drive a TOYOTA today.
The very fact that these systems are also relevant (not so relevant - the half empty half full syndrome) for even a job shop is proof enough that the engineering change aspect has been given due weightage.
duecesevenOS - 2009
I agree and disagree with this. I totally agree that a company that is manning their workforce with temps does not have a good "culture" for lean. Using temps is all about short term gains at the cost of long term goals and that is contrary to everything TPS. There is an enormous amount of training that goes into changing the culture from bank to pull so some continuity is necessary.
A company that has established a working visual factory and has standardized it's work practices has a huge advantage in situations of high turnover. You are eliminating a lot of the on the job "training" that is much harder to get sometimes. I think the classroom training is just a LOT easier to see in the bottom line than the much more dangerous (think of how many times you are out there troubleshooting mistakes for the new guys in your workforce) on the job training.
Also, once it's established, there is no training. Toyota doesn't do any training on how to run a pull system. It just is the way it is. I know most people aren't willing to wait the 50+ years it took Toyota to get to the way they are now but don't expect to surpass them anytime soon. Luckily we don't have to reinvent the wheel so it shouldn't take more than 10-15 years :rolleyes: ;)
E
Ernst Kong
Toyota rely on its team leader to provide informal training to workers,espeacially in multi-tasking and sharing of experiences, which I think is highly successful.
However I prefer the planned sessions for workers in which I can 'trace' their progress, and decide on the next course of actions. On the other hand, with the use of training material, I kinda obtain some written procedure how thing are done that normally stubborn technician are not willing to put it down to paper.
Well, there is no perfect way, but the most appropriate way to get things done.
E
Ernst Kong
No other automotive maker cares more about design than Toyota. Other design cars, Toyota design car AND the system to build cars.
Why 73% existing owner would buy another Toyota, why BIG 3 lag by a hefty 40%? The value of design shall be judged by customers, not you nor I.
T Examples of Mura and Muri to be used in Training - Key Concepts on Lean Manufacturing Training - Internal, External, Online and Distance Learning 10
S Lean Manufacturing Concepts Discussion Lean in Manufacturing and Service Industries 126
J Lean MFG (manufacturing) process and Work order templates Lean in Manufacturing and Service Industries 6
B Looking for Lean Manufacturing Articles in Spanish Lean in Manufacturing and Service Industries 4
E Lean Manufacturing in Oil & Gas Industry Lean in Manufacturing and Service Industries 4
O Lean Tools in Labour Intensive Manual Manufacturing Lean in Manufacturing and Service Industries 20
F Looking for some type of training on Lean Manufacturing video or web training Lean in Manufacturing and Service Industries 7
C Availability of Lean Manufacturing Training The Woodlands TX Training - Internal, External, Online and Distance Learning 4
O Lean Manufacturing Implementation Lean in Manufacturing and Service Industries 7
L How Lean Can Manufacturing Get? Lean in Manufacturing and Service Industries 7
C Lean Sigma Manufacturing Handoff Package Contents FMEA and Control Plans 8
A Lean Manufacturing in the Food Industry Lean in Manufacturing and Service Industries 4
R Demand Flow Technology vs. Lean Manufacturing - Same method with just another name? Lean in Manufacturing and Service Industries 9
C Lean Manufacturing Implementation and Training Materials - Recommendations wanted Lean in Manufacturing and Service Industries 6
S Lean - Ways to Measure Equipment Flexibility - Flexible Manufacturing System (FMS) Lean in Manufacturing and Service Industries 2
Z Lean Manufacturing Conferences - Could anyone suggest some good conferences? Lean in Manufacturing and Service Industries 1
P Where can one get trained in belts and lean manufacturing? Professional Certifications and Degrees 10
B Quality & Lean Written Quiz on terms and defintion of Quality and Lean Manufacturing Software Quality Assurance 8
R Beyond Lean manufacturing - Operation management / Performance improvement Lean in Manufacturing and Service Industries 1
B Cell Manufacturing - Project to implement lean manufacturing principles Lean in Manufacturing and Service Industries 4
M Lean To Attack Manufacturing Wastes Lean in Manufacturing and Service Industries 8
hogheavenfarm Lean manufacturing seminars in NY/CT area? Training - Internal, External, Online and Distance Learning 8
C HMLV Lean Questions - PCB manufacturing industry Value Stream Mapping Lean in Manufacturing and Service Industries 3
T At what stage in a company's life can you introduce Lean Manufacturing Principles Lean in Manufacturing and Service Industries 12
A Where does the Lean Manufacturing philosophy / tool set come from? Lean in Manufacturing and Service Industries 30
E Lean Manufacturing Presentation - What should I include? Lean in Manufacturing and Service Industries 13
J Lean Manufacturing without stability - Rate it 1 to 5. Lean in Manufacturing and Service Industries 4
D Lean 6 Sigma book recommendations for young, inexperienced manufacturing Engineers Book, Video, Blog and Web Site Reviews and Recommendations 4
A Does anyone know some metrics can I use to measure Lean Manufacturing? Lean in Manufacturing and Service Industries 8
J Lean Manufacturing using the FMEA? Lean in Manufacturing and Service Industries 4
P The Significance of Lean and Six Sigma Outside Manufacturing - Thesis Questionnaire Six Sigma 0
S Student needs advice on his career in the field of Lean Manufacturing and Six Sigma Career and Occupation Discussions 14
S Student requests help on Lean Manufacturing - Masters in industrial engineering Lean in Manufacturing and Service Industries 14
A What is the expectation of Lean manufacturing plans in Visteon specific requirements Customer and Company Specific Requirements 0
P Definition Lean Manufacturing - Definitions of (thesis assignment) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
R Surveys about Quality Management and Lean Manufacturing The Reading Room 0
M Lean Manufacturing Overview Aimed at Management Lean in Manufacturing and Service Industries 4
A VSM (Value Stream Management) for service industry - Lean Manufacturing Lean in Manufacturing and Service Industries 4
Wes Bucey Body of Knowledge for Lean Manufacturing Lean in Manufacturing and Service Industries 47
S SAE Jrr 003 (RR-003?) - SAE J4000 - Lean Manufacturing - Status Evaluation Various Other Specifications, Standards, and related Requirements 9
M Lean Manufacturing, SAP and 8.2.4 - No records indicating release of product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Any folks have article, insight about Lean / Lean manufacturing to share? Book, Video, Blog and Web Site Reviews and Recommendations 12
WALLACE LEAN 'manufacturing' within a Leasing environment Lean in Manufacturing and Service Industries 6
G Low Hanging Fruit - Lean Manufacturing Ideas for a Job Shop Lean in Manufacturing and Service Industries 9
A TS 16949 Clause 6.3.1 and Lean Manufacturing - Any guideline for implementation? IATF 16949 - Automotive Quality Systems Standard 3
P Lean Manufacturing - Eliminating Inspection - Can Quality Survive? Lean in Manufacturing and Service Industries 49
A Linkage of ISO 9001:2000, ISO/TS16949 and Lean Manufacturing Lean in Manufacturing and Service Industries 19
Q Has Lean Manufacturing put on weight due to Middle Age? Lean in Manufacturing and Service Industries 14
A Lean Manufacturing - How do I change my company's Culture? Lean in Manufacturing and Service Industries 26
S Teams and Lean Manufacturing Lean in Manufacturing and Service Industries 20
