LED Lighting Manufacturing Quality Checks
Re: LED lighting Quality Checks
The quality checks are dependent on the specifications and the manufacturer's risk assessment. If you could give us more information about your specific concerns we can give better advice.
MIREGMGR
LED lighting has a non-flat color spectrum...white LED lighting is created by combining multiple nearly-monochromatic (narrow wavelength-bandwidth) chips. This might or might not be relevant. (Of course, fluorescent tube phosphor coatings also can have non-flat color spectrums.)
Sometimes the differing color-chips have different emission directionalities. This can result in odd color shifts off-axis from the light fixture.
Many LED lighting products take advantage of eye persistance, and pulse the chips with high current with a noncontinuous duty cycle. This generates more apparent brightness for a given chipset thermal dissipation. It however also creates some degree of strobe effect on fast moving objects. In my experience at home where I've recently installed a lot of LED lighting, this strobe effect is much more pronounced for some LED systems than for typical linear-tube fluorescent systems.
Some LED light strips that might be considered to replace fluorescent-tube fixtures have multiple LED chipsets at non-coincident locations. Because there are significant spaces between the chipsets, the light from such LED strips behaves as if it's coming from many point sources, instead of from a continuous line. When DUT reflection is a consideration, this difference in the specularity behavior of the light can be significant.
I have been placed in a possition as a Quality Manager to monitor and insure the quality of outgoing LED type lights. I have no experiance in this feild and was wondering what are so of the common areas that are controlled in the process of manufacturing LED lights.
MIREGMGR
Heh, sorry, I totally misunderstood the original post...I thought the question had to do with using LED lighting for visual inspection. My apologies for diverting the thread.
M Informational TGA-led IMDRF Personalised Medical Devices working group meets in Canberra Medical Device and FDA Regulations and Standards News 0
Marc Renewables, led by wind, provided more power than coal in Germany in 2018 Sustainability, Green Initiatives and Ecology 2
R Air-powered dental handpiece with LED IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Bar Lights vs LED-606 in vision inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
T What innovations led to Ford's production line? Coffee Break and Water Cooler Discussions 5
R Equivalent CE for export to Japan - Stand exibition with LED lights CE Marking (Conformité Européene) / CB Scheme 3
C CE Mark Technical Construction File for LVD (LED Luminaire) CE Marking (Conformité Européene) / CB Scheme 6
S Medical Device or Cosmetic Device in Korea? Hand Held Wrinkle Reduction LED Light Other Medical Device Regulations World-Wide 1
S Medical Device or Cosmetic Device in Japan? Hand Held Wrinkle Reduction LED Light Japan Medical Device Regulations 3
R Red LED vs. White Light Inspection Lamp Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Is LED STREP 12v with power supply Class C - IEC 61000 3-2 CE Marking (Conformité Européene) / CB Scheme 2
P How to prevent the LED wrong polarity when insertion on the production line? Problem Solving, Root Cause Fault and Failure Analysis 8
J Which is better: Plasma, LCD or LED TV? After Work and Weekend Discussion Topics 39
somashekar Optical epoxy for LED having good thermal shock resistance. Manufacturing and Related Processes 2
S Copy of LED Standard IEC60825 Other ISO and International Standards and European Regulations 1
N Which standard is applicable for IR LED in conjunction with medical devices? Other Medical Device Related Standards 5
U Process Ownership - APQP shall be be led by Design & Development Dept? Design and Development of Products and Processes 2
Y Identifying lighting requirements for in house Calibrations General Measurement Device and Calibration Topics 8
C AS9100, ISO Standard Applicable to Lighting for Workstations and Inspection Stations AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
C Standard for Lighting for Visual Control at Work Stations IATF 16949 - Automotive Quality Systems Standard 7
M Metrology Room Lighting Requirements General Measurement Device and Calibration Topics 7
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
M Visual 5S Lighting Systems Equipment Vendors - Recomendations please Lean in Manufacturing and Service Industries 3
sonflowerinwales CE marking, required for prototypes? New technology lighting source CE Marking (Conformité Européene) / CB Scheme 4
T Inspection Lighting Standard for Class A automotive inspection area Various Other Specifications, Standards, and related Requirements 6
G What material would you use in extreme humidity and mercury vapor lighting? Various Other Specifications, Standards, and related Requirements 20
G Lighting Requirements For Inspection - What output is required? Is there a standard? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L SAE AS9145 vs. SAE AS6500 (Manufacturing Management Program) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 4
Q Automation in manufacturing - Print Shop ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Address of Legal Manufacturing Site in ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
M Operational (free) simulation games for manufacturing and quality Lean in Manufacturing and Service Industries 5
V Manufacturing requirements for respiratory ventilators - clean room required? Medical Device and FDA Regulations and Standards News 6
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
S Contagious Diseases in Medical Device Manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 5
C Manufacturing overages & nonconforming material documentation ISO 13485:2016 - Medical Device Quality Management Systems 3
Z US Manufacturing Site Closing, device manufactured elsewhere Medical Device and FDA Regulations and Standards News 1
L Manufacturing site expansion - When to notify your NB EU Medical Device Regulations 3
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N China - Start manufacturing before change approval? China Medical Device Regulations 1
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F AS9100D, raw material standards are a requirement for manufacturing? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
C Looking for China Good manufacturing practice China Medical Device Regulations 1
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
C Design Control - Ways of capturing inputs from manufacturing Other Medical Device Related Standards 5
A Medical Device Contract Manufacturing Requirements and Information - Help wanted ISO 13485:2016 - Medical Device Quality Management Systems 5
