Lessons Learned - Document Control?
TEJ09242010
My company is starting up a document control/records management group and I've been given an opportunity to lead the effort. I was wondering if I could get any lessons learned or tips on what has worked well vs what hasn't on the following points. I've been reading through many of the posts on this forum and feel the experience here could be beneficial as I begin placing the steps for my company to start off in the right direction:
1) We're beginning off in a paper based filing/control system until we can procure an electronic management system. Is there anything I can do in this interim period to help create a more seamless migration from paper to computer? I don't want to create more red tape than necessary and am a firm believer in less is more and following the regulatory orders rather than creating petty internal regulations
2) I haven't begun collecting documentation for control as I want a clear outlined plan of who is responsible for what so all parties involved understand their scope and the end result. Have any been responsible for the daunting task of beginning the orderly collection and control of project documentation with a lack of system and staff at this time?
3) Quality Documentation Control and Configuration Management - we're in the process of reviewing previously established procedures, plans, and forms for our project use and will begin the creation, control, and maintenance of documentation organic to our company. I feel this is a prime opportunity to start out on the right foot so we're all working in the same direction.
If the topics are vague, I apologize up front. I'm trying to look at this in a big picture posture as I know this is going to be a large effort. Any assistance is appreciated.
Jen Kirley
Quality and Auditing Expert
Good morning,
Based on years of groping around for the appropriate procedure for this-or-that while auditing, I can give some insights for system usability.
  • Avoid making a procedure for everything. The rule of thumb is to solidify into written procedures the tasks that are important to be consistently performed the same way - and a capable substitute should be able to take over the process using the document. A flow chart could work for many things - consider scripted flow charts.
  • Avoid splitting up processes into so many procedures that a person needs to use two or three to get a process done.
  • There's a general expectation of a Master List, but I would go one step farther and make a process map of the organization with the procedures noted in the various parts of the process map. This could help eliminate the guesswork that frustrates people enough to not use the procedure.
  • Consider keeping the documents online as .pdfs and using hyperlinks in this process map to access the procedures in the computer network.
  • Ask the people doing the process to help make the procedure, but keep the documents formatted similarly.
  • When updating the procedures, use the Track Changes so it's easy to see what's changed. Upon saving, the document can be saved in .pdf to avoid making changes "on the fly."
  • There is considerable hubbub and confusion regarding how to go about approvals. There is nothing wrong with sending it out in an email and collecting replies saying "I approve." These email strings can be printed out and saved as proof of approvals, or maybe saved as a document - depends on your email system.
  • Consider a matrix method to identify what type of document requires approval by which group and what level of authority. Keep it current by saving the revisions as responsibilities change, or else use Track Changes. This can be done using Excel. Auditors will expect to see something to the effect.
I hope this helps! It's all I can think of for now.
SJWoodcox
:yes:In my corporation, they have an excel spreadsheet set up as the Master List if you will. This had the document hyperlinked so you could access immediately, however filing system quite simple everything is filed in folders on the shared drive, it is broken down by plant location, then department, and then what type of document SOP, WI, OPL(one point lesson), VA(visual aid). We have the "document control center" set up as read only so no worries about accidentally deleting, I also have a tab on the spreadsheet that contains the archive documents as well.
We are in the crawl stages of Document Control, and have a lot to learn and do, I am currently working to convert current system into our SharePoint site. This will reduce the frustration of document location. Which is why the Excel spreadsheet is nice you can filter for your document or Ctrl + F to find it.
Hope this helps just a note on above I work for a food processing plant we obtain our certification from SQF which allows us alot of lea way in creating our system-very different from QS9000 which I came from previously.
Good Luck and you are not alone.
arios
sorry, what is your industry and what is your regulatory environment to conform with?
br
Sz.
Good point!, :applause: glad you raised this question so the answers are bassed considering the potential additional requirements or best practices which could vary from sector to sector
TEJ09242010
br
Sz.
Sorry about that - our industry is mainly construction and the regulatory environment we have to conform with is DoD
SJWoodcox
We are a food processing facility-tomatoes and we are certified SQF 2000. So we have HACCP, and FDA compliances as well. But our auditing for our certification if through SQF.
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
tnorton Lessons learned from implementing Customer Complaints Customer Complaints 1
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
M What do the terms "Lessons Learned" and "Best Practices" mean ? Preventive Action and Continuous Improvement 2
M Linking Risk Management with Lessons Learned ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Lessons Learned - from ANAB 2013/06/06 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Three Best Practices and Lessons Learned in APQP APQP and PPAP 1
P Implementing a Lessons Learned Program Benchmarking 2
P Lessons Learned Identification - Potential Preventive Action Responsibilities Preventive Action and Continuous Improvement 4
L Lessons Learned from our recent ISO/TS 16949:2009 Surveillance Audit IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Lessons learned from the AS9100 Rev. C Transition Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
T Lessons Learned in a Product Development Project Quality Tools, Improvement and Analysis 2
H Capturing temporary actions in PFMEA in terms of manpower, lessons learned FMEA and Control Plans 9
M "Lessons Learned System" - Evidence for Audit IATF 16949 - Automotive Quality Systems Standard 10
D Lessons Learned Reporting/Utilizing Quality Manager and Management Related Issues 1
S Lessons learned? Asked by my boss to compile a list of lessons learned Preventive Action and Continuous Improvement 33
ScottK Lessons Learned so far from my current ISO9001 adventure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
G What to present for 'Lessons Learned" from audits to Sony Ericsson - Supplier to SE Misc. Quality Assurance and Business Systems Related Topics 2
A Manufacturing Lessons Learned - New product from Design into Manufacturing Design and Development of Products and Processes 4
F Capturing Lessons Learned from a CAPA - One Point Lessons Nonconformance and Corrective Action 6
B Example of Lessons Learned Plan Misc. Quality Assurance and Business Systems Related Topics 4
U Applying Lessons Learned to other products Misc. Quality Assurance and Business Systems Related Topics 2
PatMaz Help creating a Lessons Learned Database Document Control Systems, Procedures, Forms and Templates 3
J Implementing a Pull System in a manufacturing line? Lessons Learned? Manufacturing and Related Processes 8
G Gage R&R derivation with respect to ndc - Lessons Learned Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C MSA on CMM Hard Learned Lessons - Look Before you Leap Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
J Database Lessons Learned - Real issue with the quality of the data being entered Philosophy, Gurus, Innovation and Evolution 0
D 4.1.1 Lessons Learned - Use of Design Data - How to Implement Design and Development of Products and Processes 5
B Lessons Learnt template - Information Security Management System Experiences Document Control Systems, Procedures, Forms and Templates 1
S How to Capture and Share Project Lessons and Improvement Ideas? Lean in Manufacturing and Service Industries 6
RoxaneB Life's Lessons Amidst the Blooms Imported Legacy Blogs 2
P Kaizen your life with the Ten Lessons for Good Health World News 15
S Single Point Lessons Used in Production - Seeking Examples Lean in Manufacturing and Service Industries 21
S Training technical operators on production floor - E.g. Single Point Lessons Training - Internal, External, Online and Distance Learning 5
T Corporate Lessons Coffee Break and Water Cooler Discussions 2
C Quality Lessons from the Field - The need to understand your true costs The Reading Room 18
A Corporate lessons Funny Stuff - Jokes and Humour 7
C Shakespeare's Lessons in Leadership: Macbeth The Reading Room 30
C Shakespeare's Lessons in Leadership: Hamlet Registered Visitor Articles Archive 64
C 6 Business Lessons From Martha Stewart Coffee Break and Water Cooler Discussions 4
M Is a Lesson not Learned if there is no Corrective Action? Misc. Quality Assurance and Business Systems Related Topics 3
L Lesson Learned Database for Audits Internal Auditing 4
Sidney Vianna Mutually Beneficial Supplier Relationships in the real world - GM learned a lesson? Quality Manager and Management Related Issues 1
Q Lesson Learned or OFI (Opportunities for Improvements)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Lesson Learned Cards for Problem Solving and Prevention after 8D Problem Solving, Root Cause Fault and Failure Analysis 1
K Time Management - Lesson Learned , Decades Ago Misc. Quality Assurance and Business Systems Related Topics 0
Chennaiite What is meant by 'Lesson Learned' in the context of Problem Solving Quality Tools, Improvement and Analysis 6
T What have you learned today...? Imported Legacy Blogs 1
B Lesson Learned Funny Stuff - Jokes and Humour 6
Q All I Need to Know About Manufacturing I Learned in Joe's Garage Book, Video, Blog and Web Site Reviews and Recommendations 0
