Let's fix Six Sigma!
artichoke
I believe it boils down to you should not use specification as a "basis", nor should you only use "target" as a basis. You should consider both.
The target should be the basis for process management but naturally the specification must be attained. There is no point in having a tightly controlled process where the specification limits are inside control limits. If the process is in-control and in-spec, we can be sure that in-specification product will be made both now and in the immediate future. That is, the process is predictable.
If we base process management on setting very wide specification limits (ie Six Sigma) to allow for "drifts" or "shifts", the latter will result in an out-of-control process. We will have no guarantee that specification will be met, no matter where specification limits have been set.
bobdoering
Stop X-bar/R Madness!!
I'll buy that.
If we ignore allowing for natural "drifts" or "shifts" in process management, the controls (e.g. process specifications, control limits, etc.) will also be false. The biggest fallacy of the common capability study is that it generally only envelopes one setup, one lot of material, one or two operators, etc. What would one think is going to be the ongoing effect of the natural variation of these parameters? Material variation will likely provide drifts, operator changes can provide shifts. Now, hopefully the process will permit adjustment to accommodate these shifts - and hold them between economically and statistically valid control limits. If not, then you truly will have no guarantee that the design specification will be met, no matter where the process specification limits have been set and with any attempt of process control. You would have to walk away from that product. The design specifications can not be met - and sometime that is the bottom line, no matter how hard the process is tweaked. Or, they may need to be reconsidered - such as opened up -if the design criteria was too strict.
artichoke
.... Material variation will likely provide drifts, operator changes can provide shifts. ... etc
Yes, processes and attitudes to process management, have gone back to the bad old days with 6 Sigma, where the only solution was/is to broaden specifications and/or inspect finished product for defects.
Deming recognised these issues and provided a path out of such problems ... such as page 35 "Out of the Crisis" discussing the benefits of single suppliers ... and many others ... his books are worth re-reading.
bobdoering
If you interpret 6 Sigma as where the only solution is to broaden specifications and inspect finished product for defects, then I recommend you find another set of tools to meet your needs.
Yes, as blue sky some of those ideas were handy for the time. Single suppliers these days borders on extreme wishful thinking: either wishful that they never go out of business, wishful that they never raise their prices, wishful that they are not bought out and obsolete your raw material, wishful that your customer will immediately accept a new supplier when the previous one closes up in bankruptcy or your customer will willingly accept a line shut down while a new supplier is being verified.
Deming was a deep thinker, and we can learn from his writings. But, we must always look at any work with a critical eye for historical changes affecting its application or new knowledge countering the content. Deming, Six Sigma - all the authors, all the concepts - all should be viewed critically. Otherwise, if it was that easy, one book written in the 1800's would suffice for today.
It always gives me a chuckle when people claim that Six Sigma is not about six sigma. :D
Who said that? You are making too big of a deal about the 3.4 PPM. If you don't like it, forget it. Consider Six Sigma as having a Cp index of 2.0.
There are two ways to obtain a Cp of 2.0. If the specifications accurately reflect the true customer requirements, you must reduce the process variation. However, there are many situations where engineers picked a standard tolerance that in no way reflected the customer's requirements, but were much tighter than necessary. In these situations , it is 100% legitimate to open the tolerance to achieve capability. There is nothing wrong with this approach. In fact it is foolish to ignore it.
Stijloor
<snip>However, there are many situations where engineers picked a standard tolerance that in no way reflected the customer's requirements, but were much tighter than necessary. In these situations, it is 100% legitimate to open the tolerance to achieve capability. There is nothing wrong with this approach. In fact it is foolish to ignore it.
Regretfully, this usually happens after excessive tooling/equipment costs already have been incurred. A result of poor design/process evaluations or rather the lack of it.
Stijloor.
artichoke
Who said that ... there's still thousands of web sites such as isixsigma.com who claim:
"The objective of Six Sigma Quality is to reduce process output variation so that on a long term basis, which is the customer's aggregate experience with our process over time, this will result in no more than 3.4 defect Parts Per Million (PPM) opportunities."
Perhaps some of the true believers here would like to present their evidence for their belief in 3.4 dpmo ? Or does everyone here now accept that 3.4 dpmo is historical rubbish ... and we can move on ?
bobdoering
I will buy that a process of no more than 3.4 defect Parts Per Million (PPM) opportunities is a poor long term target. I like 0 PPM. I have some customers that dig that, too. Handling process capability in the short term utilizing the concept may be acceptable for a normal process, or distributions that are similarly acceptable.
Of course, with the continuous uniform distribution found in properly controlled precision machining operations, 0 ppm from common causes is rather easy to achieve - short term or long term. I can live with that, too. And, true, one does not achieve that with +/-3 standard deviations from the mean. The mean is not even considered in controlling that process. So, it clearly does not apply to all processes, if that makes you feel better.
I will also buy that Taguchi's loss function is useless in the short term, because it needs historical data to determine both the process distribution and the determination of the applicable variation to apply. It can not be derived from thin air. It may better direct long term variation control - IF one bothers to properly develop the total variation (that is, the sum of the individual cost variation contributors) that contributes to the loss function. If not, it is just exploitation of academic jargon.
R The Improvement in Sigma Level (from Let's fix six sigma) Six Sigma 4
ScottK Let's Catch Up... what's happened to you since last June Coffee Break and Water Cooler Discussions 24
E Contacting FDA via phone to let them know a Submission is Imminent Other US Medical Device Regulations 6
W Let's play... Classify My Medical Device!!! EU Medical Device Regulations 15
S Is it alright to let the supplier do all measurements and inspection? Quality Manager and Management Related Issues 10
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
T Let's share ideas about an inspection problem.... Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Z Let us Discuss ISO 9001's Tomorrow ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N TL 9000 Starter - Please let me know if anyone has worked on TL 9000 Software Quality Assurance 1
L It is fair and legal to let a customer to make an assessment audit based on other cus IATF 16949 - Automotive Quality Systems Standard 2
Hershal Congrats! Let's talk about top posters in the threads General Measurement Device and Calibration Topics 17
R Quality Management System not active for 6 months. Registration let it Lapse or Fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S How do you let customers know you are certified on your literature? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q How to write my CV if I was let go? Career and Occupation Discussions 11
A Quality Policy - Please let me know your opinions and comments ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
tony s Let the Registrar audit the Internal Audit process Internal Auditing 45
Claes Gefvenberg Let's do age! How 'Old' will you be in 2007? A poll - Version 3 Coffee Break and Water Cooler Discussions 91
K What do you expect from a new position? Let?s compare benefits Career and Occupation Discussions 18
Hershal Football! (OK, we will even let soccer come in) - Fall 2006 Coffee Break and Water Cooler Discussions 162
H Benchmarks for Plastic Injection Molding - Let's Share! Benchmarking 18
Hershal MEMORIAL DAY 2007 - Let it be heard Coffee Break and Water Cooler Discussions 18
W Useful PC software utilities let's share some info? After Work and Weekend Discussion Topics 20
Jim Wynne A Modest Proposal: Let's Get Rid of "Quality." Philosophy, Gurus, Innovation and Evolution 15
Douglas E. Purdy 7.5.2 e) Revalidation - Let me run this by you for verification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Steve Prevette Let's nominate a Cove'r for ASQ Board! ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
Q And now, let's add software development - Medical Devices - Applying ISO9001:2000 ISO 13485:2016 - Medical Device Quality Management Systems 12
E The Chit Chat and 'Let's Meet' Thread - Meeting Other Elsmar Cove Participants Coffee Break and Water Cooler Discussions 186
E Let's do age! How 'Old' are you? A poll - Version 2 Coffee Break and Water Cooler Discussions 223
Marc Let The Lawsuits Begin! Lawsuit could set crucial Y2K precedent World News 3
R Problem solving activity - Three hours to fix the issue Manufacturing and Related Processes 15
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
G How to Fix Mis-Identified Dimensionally Identical Parts Nonconformance and Corrective Action 5
M How to fix a plastic bag on leg with a bandage to take a shower Coffee Break and Water Cooler Discussions 15
M Can an Auditor introduce a Consultant to help fix NCs after the audit? General Auditing Discussions 12
N How to Fix this Problem that is caused by so many different issues... Quality Tools, Improvement and Analysis 20
K Is there a "maximum time limit" for nonconformity to fix? Internal Auditing 11
S Systemic Problems Identified in Audit and How to Fix Them IATF 16949 - Automotive Quality Systems Standard 10
M Questions pertaining to our last audit - Fix or Minimum Document Retention time? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S SW (Software) Deferred Bug Fix - FDA Requirements IEC 62304 - Medical Device Software Life Cycle Processes 4
M How to Fix the Standard Bar of a Screw Thread Micrometer General Measurement Device and Calibration Topics 9
N IMDS Warnings - Customer Requesting Fix (removal of warnings) RoHS, REACH, ELV, IMDS and Restricted Substances 17
P Too Many purchasing/supplier procedures How do I fix them? Document Control Systems, Procedures, Forms and Templates 6
W A Diagnostic Exercise to Fix Problems - An Article Lean in Manufacturing and Service Industries 0
J Document control error - Root cause fix - Employee error Problem Solving, Root Cause Fault and Failure Analysis 27
Marc Step by step, NASA is doing what it takes to 'fix the culture' Philosophy, Gurus, Innovation and Evolution 4
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
michellemmm What is the Cost of six sigma certification? Six Sigma 10
K Looking for a good Six Sigma book Six Sigma 7
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
