Letting go of ISO 9001:2008 certification...What other framework to use?
E
esqchem
Hi. Here I am once again. Being here serves me a lot of information. So I hope you can provide me better information on this one.
I was serving a service company for only 5 months and I've seen how their system works under the ISO9001:2008 framework. They do things all for the sake of ISO. The core is, they make it a burden for themselves. Eventhough I wanted abrupt changes, it would take a while to adjust their culture and system overhaul since I am only there for short time.
A few of management decided to let go of the certification while two or three department wanted to continue. But for me, all dept should be part of it since all processes are connected.
The thing is, is their any other framework I could use? I honestly told them that no matter what framework it would be, it will never be effective if some of the directors/unit heads will not cooperate and not make quality their way of life. Anyway, I got to make it work for them eventhough I felt sad that I wouldn't have the opportunity to make them see that ISO indeed work and only in that company that they misused it that it became a burden rather than an advantage.
somashekar
Not being where you are., we cannot sense the gravity of the situation. However reading from what you say, is the ISO9001 certificate your business requirement ?
If it is not, feel free to get away.
I am not aware of the CB with whom you are associated for the ISO9001 certification, but there are several CB's dishing out the ISO9001 certification, and still you will continue to feel the way you have expressed here. Be sure the CB with whom you associate have the required credentials.
You will come around to the ISO9001 QMS as the simple and logical framework if you go around looking for any other framework.
You need to have the top management commitment to implement an effective QMS. This commitment must be translated into required authority / responsibility among the organization personnel in practice. Top management commitment is not top management fiddling into the QMS operations any which way.
All the inputs and requirements of the top management can well be considered and an effective QMS can still be put in place and maintained. Do assess all possible opportunities to make necessary and suitable changes to the QMS, that you can see operating like a well lubricated machine.
Go to a good CB if you indeed want an ISO9001 certificate for meeting your business requirement.
E
esqchem
The ISO is not a requirement however before I came in, some of the unit head felt it was an advantage and it has been there for the last 12 years. Only now that after the surveillance audit (with major by the way) that the department who's been not that supportive and active at all raised the issue of its effectiveness associated also with the CB they are using. I myself felt when I came in that the CB in very lean. But more on that, it is their issue of adhering to the system.
They wanted me to check an alternative framework. The thing is, I am feeling we are still to use the ISO framework only in different dressing. And I feel, if some of them still acts the way they do, no framework will be useful.
I came in late, i just finished analyzing their data to show them ISO benefits. But it is their decision. Right now, I have to find a way to let them have a strong quality management system. The question is how further I can go..It's funny I should be the one surrendering since they have ISo for the last 12 years but not really working per se. Instead, it's the other way around, they, surrendering to what ISO can do to them. :)
Wes Bucey
I feel your frustration, esqchem.
For years, I have preached that the most important skill of a quality profession is persuasion.
Regardless of whether an organization chooses to register to, or merely be compliant to, an international quality standard like the ISO model, its most important function is to survive, and, hopefully, thrive.
I believe that there are some quality "basics" which contribute to both surviving and thriving:
  1. record keeping (Having a database of the activities and results allows an organization to review and compare to learn what works and what doesn't. It allows the organization to demonstrate its consistency to customers, employees, everyone to give them confidence the organization is stable.)
  2. continual improvement (It is truly said the only constant in life is change. An organization strives to make its changes positive versus negative. Record keeping, of course, provides the benchmark to measure improvement.)
  3. harmony (when all the parts of an organization are acting in concert for the common benefit, there is a greater chance of surviving and thriving. Deming's theory of a System of Profound Knowledge [SoPK] when deployed enthusiastically, can contribute greatly to the harmony.)
A quality professional who can persuade both bosses and workers to follow the basics for the benefit of the organization AND themselves rather than to satisfy some arbitrary Standard is pure gold to that organization.
E
esqchem
I have only been in quality for 6 yrs of my work exp. But I have learnt that implementing QMS is a tough job since dealing with different attitude matters.
It's just disappointing that the company just recently underwent recertification and ISO certificate is on the way. It's already a plus factor and I just have to let them see to appreciate and work from beneath to let quality and the standard work for the organization. It happened that they "advertised" ISO so much that instead of letting people know why things had to be done the way it should be, it's always "because ISO requires it". Guess I just need to find more effective ways to let some heads support it.
QMMike Repercussions of letting your ISO/TS16949 RR date pass.... IATF 16949 - Automotive Quality Systems Standard 3
D Consequences of letting the CE Certificate Expire CE Marking (Conformité Européene) / CB Scheme 15
M Open Book Management Philosophy - Letting the employees see all information Philosophy, Gurus, Innovation and Evolution 35
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 8
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
M ISO 13485:2016 Certification Scope ISO 13485:2016 - Medical Device Quality Management Systems 2
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
P ISO 8 classified medical manufacturing room Qualification and Validation (including 21 CFR Part 11) 1
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
M Scope for ISO 13485 Certification of a Translation Service Provider ISO 13485:2016 - Medical Device Quality Management Systems 17
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
Sidney Vianna Release of ISO 10013:2021, Quality management systems – Guidance for documented information Other ISO and International Standards and European Regulations 0
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
A ISO 13485 Certification for Resin Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
A ISO 13485 Sterilization Clause Applicability ISO 13485:2016 - Medical Device Quality Management Systems 7
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
M ISO 13485:2016 internal audit checklist Medical Device and FDA Regulations and Standards News 5
