Limited Range Calibration - 5000 lb Industrial floor scale
Devin A
Good day all,
I have a question regarding calibration on an industrial floor scale at a tier 1 automotive plant. We use a scale to measure our finished product for an extra layer of verification that everything internal is there. This is a pretty high capacity scale compared to our used range. The scale has a 5000lbs max capacity, and our finished product is less than 400lbs. We use an external 17025 accredited calibration company to handle most of our gauge calibration, however they are only capable of calibrating scales up to 600lbs.
Would calibrating a limited range that exceeds our used range be sufficient for an IATF audit? The scale is only used for this one task, so we would never use it for anything beyond the calibrated range. The calibrated range would be noted physically on the scale as well as in the calibration record. I'm already working on quotes from providers that can calibrate the full range, however if the partial range is sufficient for IATF then our current calibration provider will be significantly less expensive and easier to plan overall.
Devin A
You only need to calibrate the scale in the range you are using it for. There is no requirement for calibration of the full range of the scale. This is true for all measurement equipment.
Perfect! That's exactly what I needed. Thank you very much for your time. I get the feeling my supervisor will still push for full range calibration but at least now I know I'm covered with the used range calibration and don't need to push to try to get someone else in on time to do the full range.
Marc
Fully vaccinated are you?
Explain the cost factor. If your supervisor wants to throw away money for no reason there is nothing you can do.
H Implementing ISO22301 on a Limited Scope Business Continuity & Resiliency Planning (BCRP) 2
D Limited Scope for second site Question? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N ISO 9001 certification with limited scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S How PMEL does a limited calibration - Tensiometers ISO 17025 related Discussions 1
B Control of Duplicate Documents - Limited Scope (long) Document Control Systems, Procedures, Forms and Templates 5
J Design Control - Can Validation be based on a limited/first Production Run ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T How to study for the SQE exam but am limited on funding Career and Occupation Discussions 1
M Offered Management Position - Limited Experience - Any Concerns? Quality Manager and Management Related Issues 13
S Differentiate ISO 9001 System MNC vs. Public Limited Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
AnaMariaVR2 Agila Specialties Private Limited Warning Letter US Food and Drug Administration (FDA) 0
D How is transport of Dangerous Goods (limited quantity) regulated for Bulk Transport? RoHS, REACH, ELV, IMDS and Restricted Substances 9
B Is limited scope a CAPA System Weakness? Preventive Action and Continuous Improvement 14
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Capability Analysis for Limited Resolution (thickness of sheets) Capability, Accuracy and Stability - Processes, Machines, etc. 6
J O & D can not be predetermined, assigned or limited by the customer, only the S. FMEA and Control Plans 1
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
M Limited manufacturing release (LMR) vs. Full manufacturing release (FMR) EU Medical Device Regulations 3
C Company is not FDA/ISO regulated - Limited ISO/FDA experience in Resume! Career and Occupation Discussions 8
D Control of Records limited to ISO 9001 Required Records - ISO 9001 Clause 4.2.4 Records and Data - Quality, Legal and Other Evidence 1
G Limited Calibration requirements in ISO 13485 - Temperature controller ISO 13485:2016 - Medical Device Quality Management Systems 3
N QMS Scope length limited to 10 to 15 words maximum - How is that possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Are Sales Offices with limited and controlled tasks Remote Locations IATF 16949 - Automotive Quality Systems Standard 3
M Limited Duty Workers - If a person is hurt on the job and transferred to another job Various Other Specifications, Standards, and related Requirements 1
D Certification - Changing from 'Partnership' to 'Private Limited Company' Misc. Quality Assurance and Business Systems Related Topics 6
P Limited Scope in Quality System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Cl. 4.15 Limited Shelf Life materials ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
S How MR (Moving Range) in Z-MR chart is calculated Using Minitab Software 5
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
K Please Help! what is ARL for the range and standard deviation Statistical Analysis Tools, Techniques and SPC 0
M Electropolishing Validation of Orthopedic Parts - What OQ parameter range Manufacturing and Related Processes 1
T Adding an adapter to a Torque Meter to change the Range Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Correlating Maximum 'Range' of Values for a given "RSD" (Control Limits) Statistical Analysis Tools, Techniques and SPC 3
Ajit Basrur Should calibration range of Oscilloscope cover the test ranges? General Measurement Device and Calibration Topics 8
S Supplier Evaluations of a wide range of suppliers and different products IATF 16949 - Automotive Quality Systems Standard 8
S Excel Help - Equivalent of "Range($G$14:$AD$121).Select" in R1C1 notation Excel .xls Spreadsheet Templates and Tools 5
S Calibration Documents that offer guidance on Calibration Range vs Use Range General Measurement Device and Calibration Topics 6
W Is the GR&R result caused by the wide spec range? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is the accepted range for "Inventory Reconciliation" for RM and FG ? US Food and Drug Administration (FDA) 3
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Long Range OC Curves - Acceptance Sampling Switching Rules Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Performing a Gage R and R with No Specification Range Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
R Count NDC from Graphik Sample Range vs R chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M SPC, Moving Range Chart and Weighted Graph Basic Questions Statistical Analysis Tools, Techniques and SPC 1
L Remote Control Inspection Digital Indicator with a TIR (range) function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Method Comparison Design Onput Sample Range Requirement Design and Development of Products and Processes 3
M Validity of Calibration outside the Calibration Range General Measurement Device and Calibration Topics 7
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
