Linear Measurement - Radius Center or Intersection Point?
tluker
I'm hoping someone here can help me out or point me in the right direction? I have a drawing that shows a linear measurement from one surface to the intersection of two angled surfaces. There is a radius where the two angled surfaces meet. We are currently having a debate in our lab on whether or not the linear measurement is to the center of the radius or to the theoretical intersection of the two surfaces. I'm trying to find an ISO standard for this but I'm not having any luck. I have seen it done both ways in the past but in this instance I'm reasonably sure that the dimension is to the theoretical intersection. Does anyone have any suggestions on where I could find a standard for this? I'm guessing there has to be an ISO standard or DIN spec somewhere but I'm not even sure where to start on this one? Thanks.
Re: Radius Center or Intersection Point?
Please post the section of drawing to which you are referring.
Ron Rompen
I agree that USUALLY it would call out the intersection of the two surfaces, however that is not a safe assumption to make - if you are really unsure of it, don't assume that your customer is any more certain - call them up and ask them. There may well be a standard (I think it's called out in the ASME Y14.5 standard, but I don't have a copy handy) which clarifies this, but that doesn't mean that your customer did it correctly - and if you make the assumption that they followed the standard and it turns out wrong, you know who will get blamed for it :)
tluker
It's not that I'm unsure but I have to convince a lab full of people that can't spell CMM that they are measuring this wrong. It started with them making one or two questionable measurements and they have since built on that to the point where I'm just shaking my head. I won't get into the details of just how bad this actually is but I really need to put a stop to this now. So I'm hoping to find a standard somewhere that spells this out?
And sorry I can't attach a picture, but it's just the distance from one surface to the intersection of two other surfaces.
tluker
If only people would follow that drawing standard when creating drawings, but they rarely do for drawings of machined parts.
G Laser Precision Linear Measurement - Inherrent Accuracy of 10 -6 - Nice PDF Paper General Measurement Device and Calibration Topics 1
S Measurement Uncertainity of Linear Measuring Equipment General Measurement Device and Calibration Topics 1
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
Q Acceptable calibration accuracy of a 60" linear measuring device General Measurement Device and Calibration Topics 16
P Basic Minitab Help - It's about Linear Regression Using Minitab Software 1
S IEC 60601-2-27: What does "linear within ±20% of the full scale output" mean? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Linearity study on a non-linear gage General Measurement Device and Calibration Topics 7
C Accuracy Equation - Linear gage with a stated accuracy of (1.5+L/50) ?m L= mm General Measurement Device and Calibration Topics 5
E How does Non-Linear UUT affect TAR (Test Accuracy Ratio) Calculation? Measurement Uncertainty (MU) 3
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
G Minitab GLM (General Linear Model) - Problem with recognition of Level Using Minitab Software 1
W General Linear Model - Formatting Data Six Sigma 3
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
Ronen E Ethicon recalls some ECHELON 60 ENDOPATH? STAPLER Endoscopic Linear Cutter lots Other Medical Device and Orthopedic Related Topics 0
S How to interpret a Linear Regression in Minitab? Using Minitab Software 3
M Attribute GLM (Generalized Linear Models) with Minitab Using Minitab Software 4
C Degrees of Freedom with Linear Regression - Pressure Sensor Uncertainty Measurement Uncertainty (MU) 15
S Interpreting Linear Regression Results from Minitab Using Minitab Software 15
C Sample Size: Why are Sample Sizes not Linear according to the Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S How to overload a linear transformer with multiple protective devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
M Uncertainty a Angle using Linear Height (goniometer) Measurement Uncertainty (MU) 2
D NLEC (Non-Linear Error Correction) vs. SLEC (Segmented Linear) Calibration Technique Calibration and Metrology Software and Hardware 3
W Discrete vs. Continuous Variables and Linear Regression. Statistical Analysis Tools, Techniques and SPC 7
S How to represent interactions in non-linear regression analysis in Minitab Using Minitab Software 5
A Linear Least Squares in Minitab Using Minitab Software 2
S Regression testing / Linear Analysis - Can you use dates in regression models? Quality Assurance and Compliance Software Tools and Solutions 5
D How do I measure Pounds per Linear Inch (PLI) of a Continuous Wire? General Measurement Device and Calibration Topics 3
S Display confidence intervals for non-linear relationship Using Minitab Software 4
M Appropriate Retention Periods - Digital linacs (linear accelerators) Records and Data - Quality, Legal and Other Evidence 4
D "Circular Thinking vs Linear Thinking" - Your Thoughts? The Reading Room 13
G Count By Weight Scale - Calibration within specification, but not linear General Measurement Device and Calibration Topics 8
P Find the best fit of data: linear or quadratic Reliability Analysis - Predictions, Testing and Standards 4
C Every problem in world has linear regression equation ?!!?? Statistical Analysis Tools, Techniques and SPC 9
J Linear measuring device that can accurately measure 0.00001 or better - Suggestions? General Measurement Device and Calibration Topics 10
M Linear Regression: What should be the appropriate value for R2 (R-Squared) parameter? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
G Document Format - Flow Charts vs. Strictly Linear Text for Procedures Document Control Systems, Procedures, Forms and Templates 4
D Circular vs. Linear - We look at systems the wrong way Philosophy, Gurus, Innovation and Evolution 25
B ISO 6508 and portable hardness measurement instruments General Measurement Device and Calibration Topics 0
Ron Rompen Measurement of residual magnetism General Measurement Device and Calibration Topics 2
M Surgical angle measurement guide device with an application software Medical Device and FDA Regulations and Standards News 1
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Most versatile measurement device General Measurement Device and Calibration Topics 2
P Surface scratch measurement General Measurement Device and Calibration Topics 1
P Thermo-Hygrometer - Measurement of 10DegC @10%RH ISO 17025 related Discussions 4
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
