Liquid Bath Depth for Calibration of Glass Immersion Type Thermometer
Mohammed Gouda
Hi friends,
i would like to ask some questions:
1-what is the optimum liquid bath depth which is needed to calibrate glass thermometers ??
2-also,can i calibrate the total immersion thermometer as a partial immersion and add the emergent liquid column (elc) correction to compensate the change between the set point and the measured one?
(if the depth of the bath isn't sufficient to complete at deeper immersion)
thanks alot...
Mohammed Gouda..:bigwave:
harry
Re: Liquid bath depth for calibration of glass thermometer.
To my knowledge,
1. Depends on the type of thermometer - total immersion, partial immersion or complete immersion type. There is no optimum - you need to calibrate it the way it is intended to be used.
2. You cannot calibrate it this way but for practical purpose, you may read it this way and compensate the readings using some calculation methods recommended in NIST documents. This is not applicable to the complete immersion type which must only be calibrated and read in the immersed condition.
Z
zamclachia
Re: Liquid bath depth for calibration of glass immersion type thermometer?
KISS :2cents:
If it is practical, switch to a digital thermometer. Partial, full immersion does not come into play.
Z
zamclachia
From my experience, the partial immersion glass thermometers I have used have always had a mark indicating the immersion depth to be applied.
Mohammed Gouda
ok,Mr.Harry
i know that it isn't able to be applied for complete immersion thermometers,but :
1- i noticed that not all the liquid baths able to make calibration for tall total immersion thermometers,how we can use it??
2-the equation which is found in NIST is for compensating the emergent liquid column measurement...so we can take the readings and correct it,doesn't it?
harry
Theoretically, the bulb of the completely immersed type is subjected to a different pressure in the immersion stage compared to the partially immersed type so it is not recommended to be calibrated as you suggest. If you do not have the right equipment, I don't see other ways unless you want to play around with the uncertainty figure. For this, I think you need relevant knowledge and data to back you up.
I am not too sure whether you are pursuing this for knowledge or practical purpose. In practice, the cost of doing these things (equipment, people and hassle) is just too high and for critical operations, people nowadays choose to get better quality ones (single calibration is enough) and replace them when the need arise.
Mohammed Gouda
yes,Mr. Harry...but i am talking about "totally immersed therm." not "completely immersed therm."
the correcting equation for "total" immersed thermometer,not for "completely" immersed one...
i know the diffrence between both...but i want to apply this equation during calibration in case of the immersion depth isn't sufficient to insert the totally immered themometer till it reaches high temp.:confused:
i am really confued ...:(
but really,thanks for your concern:read:
thanks alot..
Mohammed Gouda...:bigwave:
BradM
Mohammed, I'm sorry I cannot help on this one. The thermometers that we do in-house (partial and total), we immerse as deep as possible to get sufficiently good readings.
Mohammed Gouda
yes,Brad...i know..
but how can you overcome the extra needed depth for immersing a total immersion thermometer ?? will you buy deeper liquid bath??
i think this isn't easy to do..
but i read SP250-23 twice and found that we can compensate the readings of the total immersion when it isn't been immersed as usual (shorter and emergent liquid column is found)...and the equatin used can make the reading approx. uncertainity 10% (with confidence level 95%)..
so by this correction we can calibrate this thermometer by comarison method to standard thermometer....(also see "traceable temperature" chapter 7...the author told that he could use at thermocouple adjacent to the emergent liquid column (elc)and make the correction on the readings taken..:frust:...i'm still confused
best regards..
Mohammed Gouda.. :bigwave:
BradM
hello, Mohammed!
And yes, we buy deeper baths; Hence the reason we get rid of glass thermometers. In the end, you need to see how much variance you accumulate due to immersion factors.
A Liquid Bath Thermometer Calibration - Chemical Baths (Anodize Line) General Measurement Device and Calibration Topics 3
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
C Liquid Food Grade Transportation Requirements Supply Chain Security Management Systems 1
J OQ (Operational Qualification) for Liquid-Water Isotope Analyser Other Medical Device and Orthopedic Related Topics 2
G Glass Ampoules for a Liquid Embolic System Medical Device Other Medical Device and Orthopedic Related Topics 1
T Liquid in Glass Thermometers verification Reliability Analysis - Predictions, Testing and Standards 4
Y Calibration Frequency Requirements of Liquid in Glass Thermometer General Measurement Device and Calibration Topics 2
T Solution to Calibration Failure of Liquid Chromatography Calibration Frequency (Interval) 1
E Liquid Particle Counter - Which test is for OQ and which on is for PQ? Quality Tools, Improvement and Analysis 4
D ASTM E165 Liquid Penetrant Equivalent Other ISO and International Standards and European Regulations 6
T Enclosure Flammability Rating of Molded-In Custom Color Liquid Concentrates IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Appropriate Test Environments for In-Glass Liquid Thermometer Calibrations General Measurement Device and Calibration Topics 2
M Medical Device Classification Question - Liquid Nitrogen Freezers EU Medical Device Regulations 10
R Use of Automated Liquid Handling Robot for a PCR based Assay CE Marking (Conformité Européene) / CB Scheme 2
AnaMariaVR2 Liquid Handler (equipment) SOP? US Food and Drug Administration (FDA) 4
B Is Liquid Reagent Volume Underfill a Recall Requirement? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Best Material for Casting a Pig Mold Tub used for filling up Liquid Lead Manufacturing and Related Processes 4
J IQ, OQ and PQ for HPLC-UV or Liquid Chromatography-Mass Spectrometry (LC-MS) system General Measurement Device and Calibration Topics 1
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
R What's the cause of tailing factor in High Performance Liquid Chromatography (HPLC)? General Measurement Device and Calibration Topics 6
C New edition of IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Porosity Testing anyone? Ceramics using Liquid Ceramic Slurry Reliability Analysis - Predictions, Testing and Standards 2
A Non-sterile liquid bandage as Class 1 - Anyone concur or disagree? EU Medical Device Regulations 17
Marc The world's largest LCD TV, a behemoth 108-inch liquid-crystal display After Work and Weekend Discussion Topics 2
B MSA for Application Test Results - Supplying liquid raw materials to foam producers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Liquid Metal Embrittlement in PFMEA - Hot Dip Galvanizer - A scream for help FMEA and Control Plans 3
F Anyone have any experience setting up a Liquid Penetrant Test program? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Alloy Wheels - Seeking Paint Supplier - Powder Primer, Liquid Base, etc. Misc. Quality Assurance and Business Systems Related Topics 1
G Process Control 4.9 for Liquid Cargo Transport ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Calibration of Glassware and Liquid in Glass Thermometers General Measurement Device and Calibration Topics 2
A Salt Bath Probe Style SAT requirement Waiver per AMS 2750 Rev E Section 3.4.7 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Clifton Ne series 5 -28 D Water Bath Temperature Manufacturing and Related Processes 3
M Plating - A quick, certifiable way to measure Plating Bath Temperature Manufacturing and Related Processes 3
R Qualification of Water Bath & pH Meter Qualification and Validation (including 21 CFR Part 11) 5
W Calculating Minimum Heat Treatment Quench Bath Size Manufacturing and Related Processes 2
D Zinc Phosphate problems - Green Bath has turned White Manufacturing and Related Processes 11
D Does anyone have a standard used for How to prepare an ice bath? General Measurement Device and Calibration Topics 12
A Chrome burning and yellowness in chrome bath - Electroplating of brass Manufacturing and Related Processes 3
R MDR & depth of technical files review by NB's EU Medical Device Regulations 18
A Depth micrometer rod adjustment? General Measurement Device and Calibration Topics 8
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
H Depth in the organization for Interested Parties and Risks & Opportunities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
F The depth of the required Design Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Depth Gage Spindle moved when changing Contact Point Calibration and Metrology Software and Hardware 6
C Case Hardening and Case Depth Measurement Manufacturing and Related Processes 4
T How to interprete .600/.625 depth in the drawing callout ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
