Liquid Metal Embrittlement in PFMEA - Hot Dip Galvanizer - A scream for help
MaWin
Hej folks,
:topic:
due to some warranties, I was asked to review a P-FMEA on a hot dip galvanizers site. However I must confess, there is no much knowledge about deep details of HDG in in our company. There is mentioned a section "liquid metal embrittlement" :confused: - does anybody here has some experience with this (obviously rare) occurance?
Thanks for your help in advance!
:thanx:
With best regards
MaWin
Wes Bucey
embrittlement (also see "hydrogen embritlement") is not rare - it is a frequent cause of failure in a lot of platng situations. With hot dip zinc (definitely NOT my area of expertise), I have heard one of the proximate causes is the temperature of the cooling process after the dip.
I might suggest you check with some other websites specializing in metal fnishing troubleshooting.
FWIW, try looking over these industry association links for company names (chemical suppliers for all plating and finishing chemicals often have troubleshooting Q/A pages or a "go to" guy to answer such questions):
http://www.namf.org/
http://www.finishing.com/
http://www.aesf.org/
http://www.mfsa.org/
http://www.nmfrc.org/
ajaxmule
Hej folks,
:topic:
:thanx:
With best regards
MaWin
In a molten lead (approx 1400-1800 F) wire patenting quench we woudl erode the steel lead pots , the molten lead acting as a corrosive tohte steel pot and also the temperature cycling would exacerbate this problem by continually cycling the stresses in the pots themselves ( think of a 30 foot long , 2foot deep , 6 foot wide bathtub affair) which would lead to fatigue cracking. If this is process failure mode you are reviewing perhaps HDG may have simalar failure modes. If the is product fmea they may be referring to instrusion of the zinc into the substrate causing essentially dislocation pinning due to intrusion into and upset of the crystal matrix.. result=embrittlement. Hydrogen embrittlement in steel heat treating is probably similar. You heat up a metal' scrystal matrix and all sortsof ugly little things can slip in and foul up the works. I am Mech Engineer and was QM in steel wire mfg for 12 years and know enough metallurgy to get me in a lot of trouble. You could call a local metals test lab and ,for free , get bored out of your skull by a metallurgist with some time to kill that would love to tell you all about it. Just play dumb and you will get all you could ever want to know. Metallurgists don' tget out much.
David DeLong
Hydrogen Embrittlement - yes many years ago, I was the Quality Manager of a company that produced tractor trailers. We did get into a situation where the wooden floors that were held on with zinc plated screws had the screw heads pop off. We didn't know what why this was happening.
We found out that it was caused by hydrogen embrittlement caused by not baking the plated screws after plating.
The easy to confirm this situation was to take a sample at receiving, place each in a vise and tap the sides of the heads. If the product had embrittlement, the screws were like glass and the head would pop off. Baked product would just bend.
Now, does your company own the process of galvanized dipping? I don't think so and I would suggest that you supplier's Process FMEA should be reviewed. Place the responsibility on your supplier and only they can make changes to their process.
Sidney Vianna NASA to Develop a Novel Approach for All-Electric Aircraft Using Cryogenic Liquid Hydrogen as Energy Storage World News 2
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
C Liquid Food Grade Transportation Requirements Supply Chain Security Management Systems 1
J OQ (Operational Qualification) for Liquid-Water Isotope Analyser Other Medical Device and Orthopedic Related Topics 2
G Glass Ampoules for a Liquid Embolic System Medical Device Other Medical Device and Orthopedic Related Topics 1
T Liquid in Glass Thermometers verification Reliability Analysis - Predictions, Testing and Standards 4
Y Calibration Frequency Requirements of Liquid in Glass Thermometer General Measurement Device and Calibration Topics 2
T Solution to Calibration Failure of Liquid Chromatography Calibration Frequency (Interval) 1
E Liquid Particle Counter - Which test is for OQ and which on is for PQ? Quality Tools, Improvement and Analysis 4
D ASTM E165 Liquid Penetrant Equivalent Other ISO and International Standards and European Regulations 6
T Enclosure Flammability Rating of Molded-In Custom Color Liquid Concentrates IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Appropriate Test Environments for In-Glass Liquid Thermometer Calibrations General Measurement Device and Calibration Topics 2
M Medical Device Classification Question - Liquid Nitrogen Freezers EU Medical Device Regulations 10
R Use of Automated Liquid Handling Robot for a PCR based Assay CE Marking (Conformité Européene) / CB Scheme 2
A Liquid Bath Thermometer Calibration - Chemical Baths (Anodize Line) General Measurement Device and Calibration Topics 3
AnaMariaVR2 Liquid Handler (equipment) SOP? US Food and Drug Administration (FDA) 4
B Is Liquid Reagent Volume Underfill a Recall Requirement? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Best Material for Casting a Pig Mold Tub used for filling up Liquid Lead Manufacturing and Related Processes 4
J IQ, OQ and PQ for HPLC-UV or Liquid Chromatography-Mass Spectrometry (LC-MS) system General Measurement Device and Calibration Topics 1
P Liquid Nitrogen to shrink fit a new plug into a hole in a casting Manufacturing and Related Processes 7
M Liquid Bath Depth for Calibration of Glass Immersion Type Thermometer General Measurement Device and Calibration Topics 10
R What's the cause of tailing factor in High Performance Liquid Chromatography (HPLC)? General Measurement Device and Calibration Topics 6
C New edition of IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Porosity Testing anyone? Ceramics using Liquid Ceramic Slurry Reliability Analysis - Predictions, Testing and Standards 2
A Non-sterile liquid bandage as Class 1 - Anyone concur or disagree? EU Medical Device Regulations 17
Marc The world's largest LCD TV, a behemoth 108-inch liquid-crystal display After Work and Weekend Discussion Topics 2
B MSA for Application Test Results - Supplying liquid raw materials to foam producers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
F Anyone have any experience setting up a Liquid Penetrant Test program? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Alloy Wheels - Seeking Paint Supplier - Powder Primer, Liquid Base, etc. Misc. Quality Assurance and Business Systems Related Topics 1
G Process Control 4.9 for Liquid Cargo Transport ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc Calibration of Glassware and Liquid in Glass Thermometers General Measurement Device and Calibration Topics 2
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
J Raw material certificates - CC - Safety products - Sheet metal stamping IATF 16949 - Automotive Quality Systems Standard 1
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational US FDA paper – Biological Responses to Metal Implants Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Q IATF rule for single site - Ingots from scrap metal recycling company IATF 16949 - Automotive Quality Systems Standard 0
C AMS2750E - Noble metal as a Load sensor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D IEC 60601 Defibrillation protection test - Metal foil IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
A Test method for presence or absence of hexavalent chromium on a metal coating RoHS, REACH, ELV, IMDS and Restricted Substances 4
R Statutory/Regulatory for NACE Code 25.9 (Manufacture of fabricated metal products) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Measuring an Untrue Radius - Metal Stamped and Formed Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
