Listing a Preamendment Medical Device
AJayC
Our company is considering a Private Labeled - 510K Class II devicefrom an OEM. Per the OEM, it is preamendment device.
The OEM would place our Private Label on the device and ships it to our Mexico facility. From the Mexico location the product would be shipped into the USA to our customers. Also, some product will be repackaged in smaller quantities (example: A 500 unit box repackaged as 100 units per box.)
Since the OEM does not have a 510K, would we need a 510K?
How should this be registered with the FDA as a repackager or relabler?
MIREGMGR
Listing a preamendment device.
Note that this isn't a Class II device if it's Preamendment. Preamendment is an alternate status to Class II.
I can envision some potential glitches.
1. Will this device be marketed in Mexico? If so, COFEPRIS approval might require jumping through some hoops, depending on how much attention is paid to the device classification and its US-maker Listing status.
2. You don't need a 510(k) of your own if you are a Private Label Distributor. You also don't Register or List.
3. If however you Repackage, you must Register and List. I don't know how Preamendment status is handled through a Repackager. Repackaging status is one of the ways that kit packing is regulated, when the objects being repackaged/combined are already legally devices. I've never dealt with that situation when the involved product was Preamendment. That however must be a common situation, so I'm sure DSMICA could point you to an answer.
4. Will you be combining the Preamendment device with other products and/or doing sterilization etc.?
5. When the devices re-enter the country, an FDA PREDICT declaration will be needed. You'll have to declare the original Manufacturer for that purpose. I've heard that Preamendment devices can be complicated in the PREDICT system, which isn't exactly well documented. You might want to talk to the PREDICT people about that well in advance of your first shipment.
ascherp
A Class 2 device can be either preamenment or 510(k), depending on when it was placed into commercial distribution in the United STates. If it was legally marketed prior to May 28, 1976, has not been significantly changed since then nor is marketed for a new intended use, it is preamendment.
Preamendment status needs to be demonstrated by the appropriate documentation. You can find guidelines on preamendment requirements at http://www.fda.gov/MedicalDevices/DeviceRegulationandGuidance/ComplianceActivities/ucm072746.htm
Ask your OEM for a copy of his preamendment documentation and check to see if it complies with the guidelines. If you're not sure, you can submit the documents to the FDA with the form mentioned in the guidance or call the Office of Compliance at the number provided there as well.
If you can confirm the documentation is ok, you can compare the current device with the one marketed before 1976 according to the guidelines provided in "Deciding When to Submit a 510(k) for a Change to an Existing Device" (510k Memorandum #K97-1). If you come to the conclusion that the current device meets the requirements listed there for a new 510(k) submission, either you or the manufacturer should submit a 510(k) before marketing it.
Your facility in Mexico is a Repackager and should list the (preamendment or 510k) device as such.
Since your name is provided on the device itself and on the packaging, if I understand you correctly, and you aren't just adding your name to the otherwise original labeling, you are a Relabeler and will need to list the (preamendment or 510k) device as such.
Good luck! I hope you can confirm it's preamendment.:)
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
J US Device Listing when not the 510(k) owner Medical Device and FDA Regulations and Standards News 2
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
S Philippines CMDL (Certificate of Medical Device Listing) Elsmar Cove Forum ToS and Forum Policies 0
A 510(k) registration and listing US Food and Drug Administration (FDA) 1
D Certifcate of Free Sale Listing Physical Site from Belgium Competant Authority EU Medical Device Regulations 3
P Establishment Registration and Device listing - Wording of 807.20 (a) (6) Medical Device and FDA Regulations and Standards News 3
D Colombia Device Listing Other Medical Device Regulations World-Wide 3
S Which department manages Establishment Registration, Device Listing and GUDID? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Payment for Establishment Registration and Device Listing US Food and Drug Administration (FDA) 0
Marc Latest Posts in Right Sidebar on the Forum Listing Home Page Forum News and General Information 6
Ajit Basrur FDA - Tobacco Registration and Product Listing US Food and Drug Administration (FDA) 2
P FDA's DRLM (Device Registration & Listing Module) Listing Number Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
supadrai Confusion on 510(k) Transfer Guidance - Device Listing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc IAQG-OASIS - 9101:2016 Form 4: Cause Code Listing Now Included in Form AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Registration/Listing; Initial Importer - Private Label w/ Foreign Establishment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Q Medical Device Establishment Registration/Listing for Foreign Private Labeler Other US Medical Device Regulations 8
J US Listing of Medical Device with Different Models Other US Medical Device Regulations 3
B FDA Listing of a Class I Medical Device in USA (Manufactured in China) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
J Does anyone have an example Authority Listing SOP example? Misc. Quality Assurance and Business Systems Related Topics 3
I GUDID listing - Inputting data into the GUDID database Other US Medical Device Regulations 3
K Medical Device Listing for 801(e) Export of Uncleared 510(k)able Device Other US Medical Device Regulations 5
M Which documents are required for a class I medical device listing US Food and Drug Administration (FDA) 4
R Medical Device Registration and Listing Help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
I FDA FURLS Medical Device Listing Naming Scheme 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Medical Device and Accessory Establishment Registration and Listing Query Other US Medical Device Regulations 7
G New model for existing Class I Device Listing (510K exempt) US Food and Drug Administration (FDA) 8
ScottK FDA Listing a Class I that goes into a Class II 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Listing Exempt Medical Devices with the USFDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H Listing the gaps between EN ISO 14630:2012 and recent vesions Other Medical Device Related Standards 1
Q Giving out a Medical Device DRLM Listing US Food and Drug Administration (FDA) 3
somashekar Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B How to change the FDA Device Registration and Listing Module - Owner/Operator Other US Medical Device Regulations 10
S FDA 483 Listing Observations - Mostly Corrective Action and Root Causes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Question on Device Listing for a FDA registered facility US Food and Drug Administration (FDA) 6
B Convenient source for finding a listing of changes to BS EN ISO standards Various Other Specifications, Standards, and related Requirements 5
B Listing both OEM which is owned by OBL on a CE Mark Certificate CE Marking (Conformité Européene) / CB Scheme 4
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Uncompleted Registration and Medical Device Listing US Food and Drug Administration (FDA) 1
D FDA MDDS - Listing Obligations for a Generic Data Interface US Food and Drug Administration (FDA) 3
W Listing of Similar Medical Devices approved by CE NB EU Medical Device Regulations 6
B FDA - New Establishment Registration and Device Listing Requirements Other US Medical Device Regulations 14
L Approved Parts Listing- ISO 13485- Is an approved parts listing necessary? ISO 13485:2016 - Medical Device Quality Management Systems 9
AnaMariaVR2 Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Ronen E New Establishment Registration and Device Listing Rule - August 2012 Other US Medical Device Regulations 32
P FDA Approved API (Active Pharmaceutical Listing) Bioequivalence Study Lab for India Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T Schedule for SOP Review - Listing by Names of Process Owner versus Job Titles? Document Control Systems, Procedures, Forms and Templates 12
E Registration & Listing of a Dental Device - Class Enforcement Descretion 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
G LST (Device Listing Number) for Medical Device Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
