Listing standards in a traditional 510(k)
Le Chiffre
Are there any considerations when listing standards on a traditional 510(k)? Section I of the cover sheet (Form FDA 3514) says:
Complete this section if your application cites standards or includes a "Declaration of Conformity to a Recognized Standard" statement.
Should all applicable standards, 3rd party tested and self-certified, be included?
What about FCC part 15?
My application also cites ISO 14971, should that be mentioned too?
Michael Malis
Section 1 of form 3514 asks you for “submission standards or …recognized standards”.
This section should only include all major standards and also standards recognized by the FDA.
Specifically, if you use any CLSI standards you should include them because FDA recognized CLSI.
Also, as an example of major, you should include reference to ISO 13485, ISO 14971, ISO 10993 and ISO 15223. Those are Quality System standards (13485) and specific standards (Biological evaluation for medical devices – ISO 10993; Application of Risk management - ISO14971; Symbols to be used with medical labels – ISO 15223).
In reference to the last example above, I would not include ISO 980 (General symbols labeling standard) because it is not recognized by the FDA and any other referenced self-certified standards.
Please keep in mind, that when you state compliance, make sure it is for the right revision of this standard – good example here would be ISO 14971 (You most likely comply to 2000 revision and not 2007…)
Hope this helps,
Mike
Le Chiffre
Thanks for the response, Mike.
That's just the information I was looking for.
Just to clarify (for anyone else hunting for this info). You mean:
This section should only include major standards that are recognized by the FDA.
i.e. Include applicable major standards that appear in the FDA's recognized list.
regfocus
Mike
Hi Mike,
Thanks for your explanation. I agree most of you mentioned except your comments on quality system. I do not recommend to add compliance with quality system into this section. ISO 13485 is not 510k required and will not be helpful for the application.
regfocus
Coincidentally, the xxxxxxxx doesn't contain ISO 13485, however it does have 14971.
I also do not recommend you to add ISO 14971:2007 into your submission. If you declare that you comply with it, then you have to explain which clause you comply with. If time and labor is enough, yes, you can do it. Otherwise, it is not necessary to include it into submission.
Think about from another direction. ISO 14971 is applicable to any medical device, does that mean every submission declares comply with that?
MIREGMGR
14971-2007 is a Recognized Consensus Standard. See http ://www .accessdata.fda.gov/scripts/cdrh/cfdocs/cfStandards/SimpleSearch.cfm?db=STD&id=19639 - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS
Based on both recent 510(k) preparation-and-filing experience and a significant body of comments by CDRH leadership over the past several years, documentation of risk analysis utilizing 14971 as a guidance is expected in current 510(k) filings of both Traditional and Special format.
This builds on 21 CFR 820.30's explicit requirement that design validation must include risk analysis. In the past, some have interpreted this statement to mean that risk analysis was required only for software. The FDA has explained this point several times; see for instance http ://www fda.gov/MedicalDevices/DeviceRegulationandGuidance/PostmarketRequirements/HumanFactors/ucm119215.htm - OBSOLETE BROKEN 404 LINK(s) UNLINKED - PLEASE HELP - REPORT POSTS WITH BROKEN LINKS, where it is clarified that risk analysis (in this case, in relation to human factors and use engineering) is a freestanding requirement applicable to entire devices, not merely to software.
Michael Malis
...ISO 13485 is not 510k required and will not be helpful for the application.
You are required to list all applicable standards.
If you build Medical Devices than ISO 13485 Standard is applicable for Manufacturer of Medical Devices and some companies in addition, still have ISO 9001!
I asssumed that you don't build product in the basement...
B Convenient source for finding a listing of changes to BS EN ISO standards Various Other Specifications, Standards, and related Requirements 5
J Listing Standards in DoC and Technical File EU Medical Device Regulations 1
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
J US Device Listing when not the 510(k) owner Medical Device and FDA Regulations and Standards News 2
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
S Philippines CMDL (Certificate of Medical Device Listing) Elsmar Cove Forum ToS and Forum Policies 0
A 510(k) registration and listing US Food and Drug Administration (FDA) 1
D Certifcate of Free Sale Listing Physical Site from Belgium Competant Authority EU Medical Device Regulations 3
P Establishment Registration and Device listing - Wording of 807.20 (a) (6) Medical Device and FDA Regulations and Standards News 3
D Colombia Device Listing Other Medical Device Regulations World-Wide 3
S Which department manages Establishment Registration, Device Listing and GUDID? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Payment for Establishment Registration and Device Listing US Food and Drug Administration (FDA) 0
Marc Latest Posts in Right Sidebar on the Forum Listing Home Page Forum News and General Information 6
Ajit Basrur FDA - Tobacco Registration and Product Listing US Food and Drug Administration (FDA) 2
P FDA's DRLM (Device Registration & Listing Module) Listing Number Question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
supadrai Confusion on 510(k) Transfer Guidance - Device Listing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc IAQG-OASIS - 9101:2016 Form 4: Cause Code Listing Now Included in Form AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Registration/Listing; Initial Importer - Private Label w/ Foreign Establishment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Q Medical Device Establishment Registration/Listing for Foreign Private Labeler Other US Medical Device Regulations 8
J US Listing of Medical Device with Different Models Other US Medical Device Regulations 3
B FDA Listing of a Class I Medical Device in USA (Manufactured in China) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
J Does anyone have an example Authority Listing SOP example? Misc. Quality Assurance and Business Systems Related Topics 3
I GUDID listing - Inputting data into the GUDID database Other US Medical Device Regulations 3
K Medical Device Listing for 801(e) Export of Uncleared 510(k)able Device Other US Medical Device Regulations 5
M Which documents are required for a class I medical device listing US Food and Drug Administration (FDA) 4
R Medical Device Registration and Listing Help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
I FDA FURLS Medical Device Listing Naming Scheme 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R Medical Device and Accessory Establishment Registration and Listing Query Other US Medical Device Regulations 7
G New model for existing Class I Device Listing (510K exempt) US Food and Drug Administration (FDA) 8
ScottK FDA Listing a Class I that goes into a Class II 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Listing Exempt Medical Devices with the USFDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
H Listing the gaps between EN ISO 14630:2012 and recent vesions Other Medical Device Related Standards 1
Q Giving out a Medical Device DRLM Listing US Food and Drug Administration (FDA) 3
somashekar Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B How to change the FDA Device Registration and Listing Module - Owner/Operator Other US Medical Device Regulations 10
S FDA 483 Listing Observations - Mostly Corrective Action and Root Causes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Question on Device Listing for a FDA registered facility US Food and Drug Administration (FDA) 6
B Listing both OEM which is owned by OBL on a CE Mark Certificate CE Marking (Conformité Européene) / CB Scheme 4
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Uncompleted Registration and Medical Device Listing US Food and Drug Administration (FDA) 1
D FDA MDDS - Listing Obligations for a Generic Data Interface US Food and Drug Administration (FDA) 3
W Listing of Similar Medical Devices approved by CE NB EU Medical Device Regulations 6
A Listing a Preamendment Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B FDA - New Establishment Registration and Device Listing Requirements Other US Medical Device Regulations 14
L Approved Parts Listing- ISO 13485- Is an approved parts listing necessary? ISO 13485:2016 - Medical Device Quality Management Systems 9
AnaMariaVR2 Medical Device Establishment Registration and Listing - Notice of Changes for FY 2013 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Ronen E New Establishment Registration and Device Listing Rule - August 2012 Other US Medical Device Regulations 32
P FDA Approved API (Active Pharmaceutical Listing) Bioequivalence Study Lab for India Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
T Schedule for SOP Review - Listing by Names of Process Owner versus Job Titles? Document Control Systems, Procedures, Forms and Templates 12
