Literature search over how many years?
Vetty007
Hello everyone,
we have the situation that there is no proper literature search for MD that are already sold for many years or rather there was only a sporadic literature search (its more a unsystematic collection of suitable literature) carried out, but also with wrong search terms and filters, so that the publications filtered out afterwards are actually hardly relevant and thus are only written somewhere on paper, but don't appear anywhere else. As they are not relevant they are also in no way helpful for the CER.
How could that happen? Quite simply, a non-specialist service provider was commissioned with a literature research - formally a great literature research, in terms of content off topic in several respects. Now a new literature search should be made, but since you can't actually fall back on any data - or just wrong ones - the question is how many years the literature research should be made up for now?!? If a product has been sold for 20 years and thus there normally should be literature data for this time, but they are not (exist), 20 years?!
Of Course the company only wants to do a search for the period up to the last literature search and simply ignorr the previously incorrect search.
I'd love to hear your thoughts or experiences on such a situation -thanks for sharing them in advance :)
Raisin picker
I can give you a lawyers answer: It depends.
It depends on the device type, or rather, on the literature you can find. If the device type is still topic of clinical investigations, 5 years might be sufficient. If there was no scientific activity for the last 20 years, do an open search, and work with keyword combinations and filters to reduce the number of hits. With PubMed, you now get a bar graph showing the number of publications vs. time.
And don't forget MDR article 61 (10). You are required to define what data you need. If you have own clinical investigations (e.g. PMCF studies), you can easily argue for a shorter search period. Otherwise ...
And, of course, start with the state of the art. You might find guidelines, textbooks, HTAs that reference the most important publications for the device type.
If the company only does a literature search for 3 years, they might hear from the NB ;-)
Junn1992
Hmm...if it is for CER you will have to justify the timeframe used. What is the search used for? A good guide :: Preferred Reporting Items for Systematic Reviews and Meta-Analyses (PRISMA), MEDDEV 2.7/1 Revision 4 even though old document, has a good section for literature review under A5.
katezhang
it really depends.
for the old product with mature practice, it's better to expend the literature search period and provide your justification. For in most cases, clinical articles will more focus on new tech, new device, new treatments, etc.
Vetty007
Thank you very much for all the helpfull comments - I am very sorry, that I haven't recognized them earlier.
In this Case there are also no own clinical data (escept laboratory data) and the "Intend Use" is mainly bassed on literature. I just tried to reduce the results of a pubmed research with the help of the bar, going back over a period of time until which there is a obvious fall in the amount of publications. Ending up with approx. 1.500 publications, but as this also accounts for several products its not that much per Product, but of course in general.
Surprisingly the NB said nothing, even if they checked the relevant documents. It was the NB of a PLM client, that mentioned that the Literature search nearly doesn't exist and needs to be done, starting from scratch! But the direct NB of the manufacturer accepted everything - they obviously haven't read the literature search results and/or have no idea about these tasks. But this experience made me think about the financial interesst of NB and that they would loose thes company as client if they check them properly.
vaso B
Interesting perspective! I had similar experiences with NBs and initially I thought "ok, if they accept it, I won't bother". However, it all comes down to the manufacturer's responsibility. It is the manufacturer that should do the procedure correctly even if the NB does not notice it. Beacuse think of that: what if a stricter reviewer comes next year, checks the literature search and finds it insufficient? That could cause a big problem :)
As for the time frame of the literature search, I would say that you need to include data on YOUR DEVICE (or equivalent) since market launch. However, the SOtA search (search on YOUR DEVICE and SIMILAR/BENCHMARK DEVICES) should be up to date and only recent data must be provided (since last SOtA search). For a CER with annual updates, the SOtA should also be updated annualy, thus the search timeframe will be 1 year since last CER. If the CER does not have a proper SOtA, then I would suggest to perform a search covering 1-2 years, so that it is up to date.
I know that MEDDEV does not separte the 2 searches (clinical literature search and SOtA search), however each has a different scope. Even if you combine them in your protocol you shouldn't look for SOtA data since market launch, but only the latest data.
I hope that helps!
Raisin picker
... financial interest of NB and that they would loose thes company as client if they check them properly.
Dont think so. Currently, the NB have to hire additional personnell to reject new customers (ok, maybe a bit exaggerated). They have no issues with loosing customers.
I would rather think the NB is so logged with projects that they don't find the time to evaluate everything in detail.
The NBs are regularly audited by their national CA, and by the Commission. If your report is checked, the NB will most likely not have to change your current certificate, but they will look much more closely the next time.
Junn1992
If the initial review was accepted, then just keep it current for the time being is what I would do
S PMS Literature Search EU Medical Device Regulations 2
R Clinical Evaluation - state of the art literature search EU Medical Device Regulations 5
Y CER: can "state of the art" help to make up for literature search on equivalant devices? EU Medical Device Regulations 1
M MDR Literature search timeline EU Medical Device Regulations 13
J CER - Literature search strategy and PMV data Timeline - MEDDEV 2.7.1/ Rev 4 CE Marking (Conformité Européene) / CB Scheme 2
S Literature Search - Notified Body Had Questions About our Rationale CE Marking (Conformité Européene) / CB Scheme 9
D MDR literature review on device without clinical claims EU Medical Device Regulations 7
M Is complete testing required as per ISO 10993 for materials used in orthopedic implants or is literature review route possible Other Medical Device Related Standards 5
N MSA Frequency related literature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T PMCF Planning : Only Literature screening qualify? EU Medical Device Regulations 5
V Medical Device Literature Translation Software ISO 13485:2016 - Medical Device Quality Management Systems 1
A Purchasing Controls on Change Management of Literature/Labeling ISO 13485:2016 - Medical Device Quality Management Systems 3
A Literature review/HACCP validation of metal detection Food Safety - ISO 22000, HACCP (21 CFR 120) 0
M Informational Grey literature and medical devices Medical Device and FDA Regulations and Standards News 0
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
Watchcat CERs Literature Databases - Searching for data to evaluate EU Medical Device Regulations 16
J Literature Review (marketing etc) ISO 13485:2016 - Medical Device Quality Management Systems 1
W Literature used in the clinical evaluation ISO 13485:2016 - Medical Device Quality Management Systems 4
SK13485 Can a literature alone be used for the purpose of Clinical Evaluation of a device? EU Medical Device Regulations 6
H CER - Considering similar device/other medical devices for as relevant literature CE Marking (Conformité Européene) / CB Scheme 4
M Clinical Evaluation - MEDDEV 2.7/1 rev4 - Literature route Other Medical Device Related Standards 2
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
R IQ/OQ/PQ Literature - Learning and implementing IQ/OQ/PQ procedures at my facility Design and Development of Products and Processes 3
A Finding Literature References for Clinical Evaluations per Annex X of MDD 93/42/EEU EU Medical Device Regulations 2
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Q Books / Literature: Risk Management for Medical Device Software recommendations Other Medical Device and Orthopedic Related Topics 4
S Clinical Evaluation using the Literature Method - Example or information wanted EU Medical Device Regulations 26
N Proving a Medical Device is equivalent to another device from Literature Review EU Medical Device Regulations 4
D FDA CGMP's Training Material - Slides, literature, handouts, etc. Training - Internal, External, Online and Distance Learning 1
S How do you let customers know you are certified on your literature? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R ISO 10993 - Required Testing - Can I follow the literature route? ISO 13485:2016 - Medical Device Quality Management Systems 3
Marc Liberating Scholarly Literature with E-Prints and Open Access Journals Book, Video, Blog and Web Site Reviews and Recommendations 0
L How many registrars require the use of their name in company literature Registrars and Notified Bodies 11
L Clinical Data Report - Literature Route - MEDDEV guidance (MEDDEV 2.7.1) EU Medical Device Regulations 28
I Seeking: References for online literature about ISO/TS Implementation Book, Video, Blog and Web Site Reviews and Recommendations 1
C What literature is available on Preventive Action? Book, Video, Blog and Web Site Reviews and Recommendations 7
D Control of Point of Sale Literature Document Control Systems, Procedures, Forms and Templates 3
FRA 2 FDA Searching The Cove - how to improve search effectiveness Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 8
N How to streamline the search for environmental legislation? ISO 14001:2015 Specific Discussions 1
I VDA Standard search VDA Standards - Germany's Automotive Standards 1
D PFMEA Software search Quality Assurance and Compliance Software Tools and Solutions 8
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
M Predicate device - Search for a Class IIa device US Food and Drug Administration (FDA) 2
M Search for predicates to see what claims are being made for those predicates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Marc Search - Search for Discussion Threads started by a specific User Elsmar Xenforo Forum Software Instructions and Help 0
Marc Search for Posts - By specific User Name(s) Elsmar Xenforo Forum Software Instructions and Help 1
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
Q Search for FDA Class I Medical Device Listings US Food and Drug Administration (FDA) 5
Mikishots Malaysian Airlines Flight Search is Over? Coffee Break and Water Cooler Discussions 25
Marc Google "Hummingbird" Search Algorithm Announced - Sept 2013 After Work and Weekend Discussion Topics 1
