LOGS - Record or Document? How to control logs?
L
lrl116
There is a lot of discussion within my organization on whether a log is a record or a document. Currently, we list logs on our document control master list. Management then defines a completed log as a record but does not list it on the Quality Record Index. The logs are manintained on a web site repository. Some of the logs are blank in this repository, considered a document, and the completed logs are maintained on shared LAN drives, considered records.
Does anyone have any insight on how to control logs?
Examples of some of the logs that are maintained include: security logs (include details of nightly security checks), continuous improvement logs, data load testing, systems issue logs, etc.
Please send advice!
Crusader
Logs...
We have logs that are not records and some that are! For instance, we have a QC Log for in-process parts that are incoming into the department for inspection, who received/inspected them. The logs are merely just that and nothing more. It's for internal use/tracking of how many parts are being checked per shift. We also have Logs that are used for recording operator maintenance on machinery - that's a record. It is better to name your documents appropriately - something we need to go back and do ourselves. Hope that helps. :bigwave:
K
Kevin H
IMO, your blank logs are the equivalent of forms. The completed ones are records. Both forms and records are special types/categories of documents. They need to be controlled based upon the needs of your management system for quality. If you define a completed log as a quality record, I would expect to find it in your quality record index. If the logs you mentioned are part of your quality system, I would expect the resulting records to be controlled.
Control of the blank logs(forms) could be as simple as having a statement in your quality system that the most recent revision is always found on-line in folder xyz on server abc, and then having some revision data included in the header or footer of your log if it is in Excel or Word.
Or control could be complex & detailed, describing access to them, how it's controlled, who has the authority to change the logs, who is responsible for removing them when no longer needed, how long to archive, etc.
Whether to go simple or complex depends on the nature of your business, and the quality system you've developed for it. My personal bias is to try to keep it as simple as possible and to drive authority/decision making as far down as possible/management is comfortable with.
CarolX
I use logs to collect data on first piece and final inspection. The data is tallied weekly and the logs are destroyed.
L
lrl116
It sounds like you destroy the logs and do not controll them. Is that correct?
I just don't know if I should keep the logs listed on the document control master list or if they should just be listed on the quality record index.
Is it ok to have logs that are considered records after they are filled-in but not list them on a Quality Record Index?
SteelMaiden
We control logs that collect information used in the process just as any other record, other than that they are usually an electronic form vs. paper. Now, I know that there are people that log stuff for their own scheduling, that we do not control. I consider that as a "day planner" type activity. But anything that records the status of the process at a given point in time is a quality (or environmental) record. Ex. pH logs, speed change logs, etc.
Wes Bucey
Kevin's answer is similar to what I would respond. Logs and records are a special form of document which can be "updated," but not "modified," meaning that it is HISTORY and "it's not nice to rewrite history."
Control is a sliding scale, depending on requirements of customers, regulators, and the organization business purpose. At its most basic, control simply means making an effort to assure folks do not mistakenly refer to an obsolete document. Complex control can get REALLY complex when one begins to consider security matters of protecting sensitive data from competitors or info about one customer or supplier being accessed by another customer or supplier.
CarolX
Yes - that is correct. I use my logs to record first piece approvals and final inspection pass thru. The information is tallied on to a spread sheet, then plotted on a graph. The graphs are used to measure the effectivity of our system.
If this is your method for identifiying records, then, yes, the must be on your index.
L
lrl116
Thank you for the discussion.
I still have not decided if I should document control logs on my document control master list and assign them a number. My current system has document control numbers assigned to all logs. But I am new in the organization and I feel that they should be also listed on the QRI if they are considered records once information is entered.
So a log is a document until it has information on it and then becomes a record.
Wes Bucey
a record is just a special type of document. A blank form with no data is also a document. Once data is entered on the form, it may become a document (such as filling out a purchase request) or it can become a record (such as filling out a machine log.)
Some records have a very short life (one of the previous writers wrote of a log that was destroyed after the information was transferred to a different document.) Other documents can be permanent records (ever been on the receiving end of a teacher's threat "this will go on your permanent record!" ?)
The concept of using
is merely a filing technique. Modern computers have search and retrieval systems which makes such master lists obsolete and redundant. This is only a REQUIREMENT for certain regulatory bodies. It is really no more a "requirement" for complying with ISO Standards than determining whether to use tan file folders or orange (my personal favorite!)
G Inspection Logs - Asked to remove an Inspection Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How do I go about creating document logs and registers with the MS Excel Excel .xls Spreadsheet Templates and Tools 2
B M&TE (Measurement and Test Equipment) Usage Records (Logs) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Internal Audit Non Conformance Tracking Logs and NC Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
P Question in auditing regarding CAR (Corrective Action) Logs Internal Auditing 7
T Implementing Defect Logs into my existing Non-conformance procedure Nonconformance and Corrective Action 4
D Scrap Logs - Do Scrap Logs have to have a document number? Records and Data - Quality, Legal and Other Evidence 27
T Supplier and Customer Survey (including Logs) Ideas and Examples wanted ISO 13485:2016 - Medical Device Quality Management Systems 3
L Audit Logs - What do you do when registrars ask for them? General Auditing Discussions 10
M Training Documentation - Control of Signed Training Documents e.g. Training Logs Training - Internal, External, Online and Distance Learning 10
a_bardi Help me define way of control electronic data files - Logs, etc Records and Data - Quality, Legal and Other Evidence 3
S Clarifications on Lists, Logs and Registers Document Control Systems, Procedures, Forms and Templates 23
Marc Control of Laboratory Notebooks and Logs Document Control Systems, Procedures, Forms and Templates 0
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
S IVD Device History Record ISO 13485:2016 - Medical Device Quality Management Systems 3
E Record Retention - Raw Material (Steel Certs) Records and Data - Quality, Legal and Other Evidence 3
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
N Importer of record - Europe EU Medical Device Regulations 0
M Question for Auditors - "Off the Record" Conversation? General Auditing Discussions 14
C GUDID Device record history Medical Device and FDA Regulations and Standards News 2
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S How do you record your Nonconforming product? Batch production of staged processes Nonconformance and Corrective Action 2
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Defining and Documenting Record Retention CE Marking (Conformité Européene) / CB Scheme 5
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
S Service record requirements for Non-Serviceable Medical Devices CE Marking (Conformité Européene) / CB Scheme 1
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
N ISO 13485 Quality Record Retention Period ISO 13485:2016 - Medical Device Quality Management Systems 4
M Loss of a Quality Record - FDA Inspection Records and Data - Quality, Legal and Other Evidence 4
B MDSAP 8.2.6 CH6 task 17 ANVISA 16/2013 3.2.1 - Label History in Device history record Other Medical Device Regulations World-Wide 3
I Training records and levels - When does training NOT need a record? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Gman2 Quality Record Retention (Internal Audits, CA's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 6
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
S Mobile app data privacy - Length of record retention in a software app Medical Information Technology, Medical Software and Health Informatics 1
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Medical Device News Health Canada - Scientific Advisory Panel on Software as a Medical Device (SAP-SaMD) - Record of Proceedings – January 26, 2018 Canada Medical Device Regulations 0
J Training Record Template and tracking Document Control Systems, Procedures, Forms and Templates 1
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
D Design Outputs vs DMR (Design Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
M Is referenced content sufficient to meet record content requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Reissuing pages of a record 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
