Long Lasting Problem with our Supplier sending incorrect parts
Z
zkrasztina
Hallo Dear experts,
We have a long lasting problem with our supplier.
The issue: They supply a small electric device for our trucks, but recently they had a wrong delivery (20Vs devices intsead of 40Vs!) We returned butsince then(!) they are not able to replace this quantity, nor deliver for our current production. I suppose they stopped the 40Vs production.
We tried to make some pressure in different ways but no results.
We are in Europe and the supplier is in the States. So the communication and a visit is very hard from distance. (Our resident there had no succes too)
No we are facing to our customer getting penatly due to the delyed delivery!
What kind of tools are available?
Shall I ask their registars to make sudden audit about this?? Or what?
Thank you for your advice in advance.
Zoltán
:bonk:
True Position
Re: Long Lasting Problem with our Supplier
Were you directed to this supplier from your customer? If so, you'll be in luck since you can then make it the OEM's purchasing / supplier quality problem.
If not, you'll need to see about expediting and who is going to pay for all of that. I would contact your customer if you can't work out an expediting arragement, especially if there's going to be a long delay getting replacement tooling / etc.
John Martinez
While True Position may be on to something, it has been my experience that most contracts from automotive clients, while dictating that you purchase from a particular supplier, does not remove you from being responsible for quality or fines for late delivery.
You need to refer to your contract with your customer to see what was agreed.
Regarding the supplier:
  • What was the qualification criteria used to select them?
  • What did your contract or purchase order specify (i.e. 40V transformer or just “transformer” - you did not specify what specific 40V item in your post this is only and example)?
  • What were the fines you imposed upon them?
  • If you did business based upon a letter of credit, and it has not been paid, then that may be a failsafe.
If you feel you are correct and if they are certified, you can certainly lodge a complaint with their Certification Body, and if the CB is accredited, they will have to take some type of action.
While we await your answer, this may be a good learning opportunity for others. Price in and of itself is NEVER a good supplier evaluation tool. Of course, I’m not stating that this was your only qualification.
Disclaimer: NO – not an attorney, nor is this legal advice. :notme:
Sidney Vianna
Post Responsibly
So, if communication is a problem and the logistics are a challenge, how/why was this supplier qualified in the first place?
You can certainly try to involve the supplier's CB in the mix, since ISO 17021 has provision for the CB to perform short-notice audits, when justified concerns over the effectiveness of the certified system exist, but I doubt the issue will be resolved faster. You can also follow the advice offered here.
What to do if things go wrong?
In the event you are not happy with specific goods or services you receive, you should first of all bring this to your supplier’s attention. You will typically do this via the normal technical and/or commercial communication channels that have been established. Your supplier is obliged to investigate your complaint and should take appropriate actions to avoid or reduce the chances of it happening again.
If, however, you are dissatisfied with the overall performance of your supplier (for example if they continue to provide nonconforming products, do not address your complaints, or are not taking appropriate corrective action). then this is an indication of problems in their quality management system. Depending on the responses you receive, you should be aware that you can escalate your complaint via the steps described below.
If your supplier has a QMS that meets ISO 9001 requirements, they are required to have nominated a person – the management representative – with the responsibility and authority to ensure the system is working properly. You should find out who this is, and make a formal complaint.
If you are still not satisfied with the response from your supplier, and if they are certified by an independent (third party) certification body (registrar), you should bring the matter to the certification body’s attention. You can find the certification body’s name by looking at your supplier’s certificate. The certification body will investigate the problems during their surveillance audits of your supplier’s QMS, or, in critical cases, may decide to carry out an additional specific investigation.
If you do not receive a satisfactory response from the certification body, and if it is accredited (see Figure 1), you should complain to the relevant accreditation body. Details of any such accreditation will appear on your supplier’s ISO 9001 certificate. If you have difficulty in getting this information, you can consult the list of accreditation bodies who are members of the International Accreditation Forum on the IAF Website (www.iaf.nu)
If you feel that you have not received a satisfactory response from the accreditation body, and if it is a member of the International Accreditation Forum (see Figure 1), you can complain to the IAF (www.iaf.nu).
Remember that none of the above will affect your statutory rights as a purchaser and it may be appropriate to take legal action against your supplier instead of, or in parallel with, the above channels. The way in which you do this may vary from one country to another.
Z
zkrasztina
We have contacted already to our customer and his new final deadline is closing, without any changes from supplier's side.
Zoltán
SteelMaiden
It is quite unclear what sorts of communications you have had with your supplier, beyond the fact that you sent product back. When this happened, do you ask for a corrective action, or otherwise make some agreement with them about the time frame this needed to be completed? You say that you suppose they've quit making the part, but there should be communication with them to find that out. A good root cause analysis needs to be done, both on this wrong part, and where your problems lie in communications.
If they have contracted to supply this part for you, and they are unable to do so, they should be reimbursing you and more importantly, they should have notified you as soon as they found they wouldn't be able to honor their contractual obligations. (I'm not a lawyer either, so this is just all layman business operations)
You certainly can contact their registrar to lodge a complaint. Follow Sidney's info on how to do that.
Z
zkrasztina
This supplier has been delivering his products since years without any major issue or complaint. But they suddenly stopped delivery this particulary one item of their (complete) product since months (as I mentioned in my first sentences).
The first finding was the wrong specification on this item 20Vs instead of 40Vs. Since we returned they are not able to delive neither answering our questions about it!!! No communication. As I read your comments and advices I am stronly belive I should contact to their registrar now.
Thanks: Zoltán
Sorin
Thanks: Zoltán
That is highly fishy ...did you look for another supplier?
Edit: What I do not understand is why are you bringing the registrar in discussion.
Or....what do you mean by registrar?
True Position
Do you have a contract stating the supplier is to continue to provide 40V units to you? If not, I don't see why the accreditation body would get involved at all.
Wes Bucey
Exactly HOW are you communicating with these folks?
  1. phone? What time of day? Is the executive staff available?
  2. email? Who are you addressing the communication to? Maybe that person no longer works at the company (dead, ill, fired, retired, etc.)
  3. snail mail? Did you use registered or certified mail, requiring someone to sign for it?
In my opinion, you need to exhaust EVERY method to contact a responsible person at the supplier to get "some" reply concerning the situation. Only AFTER you have exhausted those avenues, should you start a dialog with a registration entity. Look at it this way, if a supplier is ignoring ALL attempts at communication with the customer, he probably won't be any more responsive in communicating with a registrar.
  1. In the meantime, your company will still be without product - where are you going to get product?
  2. Have you contacted alternate suppliers?
  3. Do you owe the supplier money?
  4. Have you paid money in advance for product not received?
  5. If you do not owe money to supplier and supplier is not holding your money without delivering correct product, WHY keep up the effort at all? Just get a new supplier if you are sure you have done everything to contact this supplier.
  6. It is not your job to police this supplier instead of proceeding with your business.
  7. Get on with your business and don't waste time, effort, and energy on punishing a screwed-up supplier.
Marc A silk casing enables long-lasting, implantable Wi-Fi medical devices Other Medical Device and Orthopedic Related Topics 1
T Defining the lifetime of medical devices - long lasting parts such as bone screws. ISO 13485:2016 - Medical Device Quality Management Systems 3
C Packaging Long Parts Manufacturing and Related Processes 3
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
Watchcat How long is this going to take? (UK & ventilators) Manufacturing and Related Processes 14
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
1 How to measure straightness on a HEX Long Bar Manufacturing and Related Processes 7
A PFMEA - How long should the recommended actions remain in the recommended actions column? APQP and PPAP 3
M FDA News Statement from USFDA on steps to strengthen the long-term safety oversight of the Essure device Medical Device and FDA Regulations and Standards News 0
A Class I medical device and Category III PPE - Long length gloves EU Medical Device Regulations 5
T How long will ISO 9001:2015 Recertification Take? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Tracking savings - Long term projects and the day to day decisions Preventive Action and Continuous Improvement 5
C How long is an OEM obligated to provide spare parts and repair EU Medical Device Regulations 2
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
L Please help my division with quality [long] Service Industry Specific Topics 1
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
A How to systemically improve product quality in short-term and long-term basis? Preventive Action and Continuous Improvement 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
K Internal Audit CAR - How Long for Responses to be Received? Internal Auditing 8
B Control of Duplicate Documents - Limited Scope (long) Document Control Systems, Procedures, Forms and Templates 5
Proud Liberal How long does your company take to close an 8D on average? Problem Solving, Root Cause Fault and Failure Analysis 12
D Long length measurement of 18" up to 100" with an accuracy of .005 min General Measurement Device and Calibration Topics 8
S Long time for NB to review to change the classification of one of our products! CE Marking (Conformité Européene) / CB Scheme 4
M Is calibration from long ago still valid on never used pipettes? General Measurement Device and Calibration Topics 8
S How long should it take to get new TS 16949 certificate? IATF 16949 - Automotive Quality Systems Standard 1
M How long should AS9100 Certificate issuance take? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
G SDS (Safety Data Sheets) Records - When and how long? Occupational Health & Safety Management Standards 8
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
O Takt Time Calculation for Long Runner Product Lean in Manufacturing and Service Industries 5
W AS9100C registration - How long does the system have to run before initial audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Corrective action on Non-conformances from a long time ago ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Pre-clinical Animal Studies for long term implantable medical devices EU Medical Device Regulations 5
R Long Range OC Curves - Acceptance Sampling Switching Rules Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
V How long can a development stage incident be open? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
D How long must we provide service parts to Ford? IATF 16949 - Automotive Quality Systems Standard 7
S What documents/records should we be retaining and for how long? Document Control Systems, Procedures, Forms and Templates 6
AnaMariaVR2 Dirty Medicine - Long-term criminal fraud at Ranbaxy Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
R Does long-term body worn medical monitoring device need to meet IEC 60601-1-11? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Wes Bucey Discrimination against long term unemployed Career and Occupation Discussions 2
C How long does AS9100 QMS need to be in place before the Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
5 5S Coordinator (Long-winded) Job Title Career and Occupation Discussions 8
B Management Review Meetings too Long - How to Shorten and Improve Effectiveness Management Review Meetings and related Processes 7
L How long can the sample for Bio-Burden Test be kept? Other ISO and International Standards and European Regulations 4
