Looking for calibration specification for Fluke 7250 pressure controller
Rmack
EDIT: Sorry, something changed the message title I originally posted. I'm not looking for specs, I know where those are. What I'm looking for is discussion on what part of the spec you would use in this situation to determine the tolerances to put in a calibration procedure.
I’m trying to write a calibration procedure for a Fluke 7250 pressure controller and their jumble of specs has me a bit confused.
According to the sales guys the precision is 0.005% reading.
Calibration tolerance in their documentation is 0.009% of reading where accuracy is defined as the maximum deviation from the value of pressure including precision, stability, temperature effects, and the calibration standard.
It seems to me that stability, temperature effects, and the calibration standard would certainly effect the uncertainty of the measurement but don’t belong in the calibration limits column of the cal procedure. That in order for it to achieve the 0.009% accuracy spec it would need to agree with the standard within the 0.005% of reading precision at calibration time.
Their method appears to compare the 7250 to the standard and call it good if it is within 0.009% of reading. This seems inflated to me and would result in even poorer instrument performance when stability and temperature effects would be different from conditions at calibration time.
When you write a procedure which spec would you use?
dgriffith
Have you tried the Fluke website http://us.flukecal.com/products/pressure-calibration/automated-pressure-controllercalibrators/7250-series-pressure-controll?quicktabs_product_details=1 for the 7250. Contains spec info and a few examples describing what they mean.
We calibrate our 7750i, 7010-1 and 7010-10 controllers; when I get a chance I'll post about it.
I would use the precision value 0.005%rdg as the performance limits for calibration (tolerance).
The total uncertainty values are what you would use when the controller is the reference for another UUT. They mention control stability separate from the total. I would include it additonally if controlling instead of just measuring.
Your standard would have to be a suitable substitute for theirs to keep the 0.009% total uncertainty valid.
Edit to your edit: I look at it like this: The 0.005% rdg precision is the measurement performance tolerance. As a measurement instrument, it will meet that limit with the appropriate calibration reference standard, and of course during calibration it is in measurement mode. This is the intrinsic capability, so to speak.
When a controller controls, it is measuring its own pressure; it develops an error signal that controls the valves, etc. etc. to cause the target pressure and measured pressure to be equal (electrically/digitally). Valve control and other influences cause the performance limits (in control mode) to increase, say 0.009%rdg.
So, 0.005% to calibrate it, 0.009% when you use it.
Rmack
Dgriffith,
Your description really clears it up. Red stuff and blue stuff I'll gladly read it all.
Thank you!
RMack
Slammy
Quick Question: Which organization do you feel should oversee Calibration and Metrology.. Manufacturing Engineering or QA?
dgriffith
There is no set 'department'. It might depend on the company, their willingness to bring in a qualified person(s), or who has the most experience within the company.
NASA Metrology is under Safety and Mission Assurance (SMA) at the agency level, but at the individual Centers you will find Metrology under Research, Flight Operations, SMA, QA and many others.
No rule, though many private companies have it under some Quality function (because they're the experts in all things quality, don'tcha know... :rolleyes:).
Rmack
It really depends on the place but it's very important that the calibration functions are allowed to operate without undue pressure to provide results that are "convenient". In my experience that's more likely to happen with metrology aligned under quality assurance.
S Looking for a Threaded Ring Gage Calibration Laboratory General Measurement Device and Calibration Topics 13
T Calibration Services in the Midlands UK (Looking For) General Measurement Device and Calibration Topics 3
D Looking for Calibration Software for small company General Measurement Device and Calibration Topics 20
J Looking for a Calibration Facility for a Surface Roughness Tester General Measurement Device and Calibration Topics 2
M Looking for a copy or template of a In House Calibration Report for a Dial Indicator General Measurement Device and Calibration Topics 1
A Label Printer for Gauge Calibration Purposes - Looking for Recommendations Calibration and Metrology Software and Hardware 6
S Looking for Calibration Supplier in Montreal area... General Measurement Device and Calibration Topics 2
M Laboratory that performs densitometer calibration - Looking for General Measurement Device and Calibration Topics 1
D Looking for a "User Friendly" calibration system software package Calibration and Metrology Software and Hardware 18
T USAF DoD trained in calibration - Looking for Careerpath advice.... Career and Occupation Discussions 5
L Looking for SOP for the Calibration of the Laboatory Equipment Document Control Systems, Procedures, Forms and Templates 7
C I am looking for the best practices on calibration labeling General Measurement Device and Calibration Topics 5
C Calibration Engineer - Looking for information to develop a job description General Measurement Device and Calibration Topics 2
B Looking for Calibration / Reference Standards tracable to NIST General Measurement Device and Calibration Topics 15
A Looking for Calibration Lab's on Reynosa, Mexico ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Looking for information on calibration proficiency testing (dimensional) Training - Internal, External, Online and Distance Learning 1
J Looking for partners Paid Consulting, Training and Services 2
bryan willemot Looking for an Approved vendors list template Document Control Systems, Procedures, Forms and Templates 11
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
M We are looking for a Contract Manufacturer US Food and Drug Administration (FDA) 2
mihzago Looking for an Australian/ NZ Sponsor Other Medical Device Regulations World-Wide 4
S New Foreign Exporter Looking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
N Looking to Impress - New Job - Advice, Thoughts, Comments Welcome Career and Occupation Discussions 23
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
N Looking for Gamma sterilization facility in China ISO 13485:2016 - Medical Device Quality Management Systems 4
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
A New to QC, looking for resources Problem Solving, Root Cause Fault and Failure Analysis 3
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
C Looking for China Good manufacturing practice China Medical Device Regulations 1
M Is Harmonised EN 1041 (Information Supplied By Manufacturer) Worth Looking At? EU Medical Device Regulations 7
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
A We're currently looking for any studies performed on various PPE materials Qualification and Validation (including 21 CFR Part 11) 1
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
