Looking for Equipment Specific Preventive Maintenance templates/Procedures/forms
skiman
I am looking for Equipment Specific Preventive Maintenance templates/Procedures/forms that I can modify for our equipment requirements.
For example: for a large industrial centrifugal fan, once we have listed the lockout/tagout requirements what tasks should we list for the technician to perform and what check list items should be included.
I am looking for templates we can modify for a general industrial manufacturing/processing plant, I do not expect a generic form/template to be adequate for our purposes without modification.
Thanks in advance!
Randy
Here's a unique thought...Why not ask someone who is actually a maintenance expert to help? You know, someone who on a daily basis gets their hands dirty actually maintaining equipment. An expert, so to speak.
If I were needing information about cooking procedures I'd go to a professional cook instead of a car mechanic.
Marc
Don't let Randy get to you. There might be some experts here.
I will say this may be too specific as there are often differences in brands, etc. E.g. One motor may have sealed bearings whilest another may need to be oiled at a specific interval. When writing maintenance procedures it is usually best to look at the manufacturers manual that came with the equipment. Usually a manufacturer will at least give a 'minimum' maintenance schedule.
Does anyone here have anything as specific as the thread starter is looking for?
harry
Equipment specific maintenance? Procedures? Templates?.
I thought the best source is the machine manual. Who knows better than the designers and manufacturers? And who can say that you did not do a good job if you follow the manual?
Cari Spears
Hi skiman - welcome to the cove.:bigwave:
Here are the simple maintenance charts we use. These are the tasks that each machine's main operator is responsible for. Each machine has its own and the requirments come from (as already suggested) our machine maintenance expert and the manuals for the machines. You'll notice that the machine manuals are referenced in them here and there for more in-depth instruction if needed.
skiman
Thanks for these interesting comments.
I am sure that there are "experts" here, it is obvious from looking at the forums.
The facts are that most equipment mfg's simply do not provide much more than to say, "Perform appropriate maintenance tasks, check equipment condition including drivers, foundations, and controls".
I agree that the operators and mechanics should be the "In-house Experts". Unfortunately a discussion with them often goes like this, "What was the final installed belt tension?"
"I tightened them!"
"How tight, what spec's were used and the tension tester reading?"
"I know how tight they need to be, I know how to do my job!"
They often view procedures and checklists as a controls issue and a method to place blame and judge them; rather than guidelines to insure that an activity has been properly completed, an historical record, and a feedback loop to facilitate efficiency and effectiveness improvements.
I realize that correctives for this barrier will not be implemented through PM's but those actions are outside of my direct influence.
I can issue PM's that facilitate feedback, then the accountability defaults to those with influence responsibility.
Were I free to construct PM's as I prefer, I would use the Center for Chemical Process Safety (CCPS) guidelines, ISO or others. However that is not my mandate.
I am hoping that someone will already have developed templates with indicated tasks so I will not need to reinvent what has already exists. I do expect that I will have to change and customize them to include specifications and tolerances (Like belt tension and alignment), but I would prefer to start with a baseline.
The file I have attached is my start for a fan, but we have everything from kilns, dryers, conveyors, incinerators to pumps and everything in between!
Thanks in advance!
Craig H.
Skiman,
We have something VERY similar to what Cari has (its almost spooky how close). I suggect you use Excel, and turn on the gridlines in Page Setup so that the grids will print. And DO print them (even in our move towards less paper I will continue to demand this). There are some nice metal clipboards available that can hold the forms and also withstand being taken out into the plant. Encourage your folks to take the checklist out into the plant with them, and check off each item as it is done. Also, if more than one type of grease/oil is used, indicate what type to use for each bearing, and how much, right on the form. My goal, as these were developed years ago, was for these to serve as a reminder and a guide. The audit trail, if needed, is an added bonus.
As far as attitudes go, since we are 24/7, and there are 4 operators for each position, they do a pretty good job of policing themselves, and the checklists get looked over by me during audits. Rarely is there a problem.
jimmydqc
Your forms are great...very detailed. Do the operators/machinists resist or put off filling them out at the scheduled intervals?
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
B Looking for a Standard identifying SME's (Standard Measuring Equipment) General Measurement Device and Calibration Topics 1
L Looking for SOP for the Calibration of the Laboatory Equipment Document Control Systems, Procedures, Forms and Templates 7
S Looking for information on U-Charts - Semi-conductor equipment manufacturer Statistical Analysis Tools, Techniques and SPC 6
D 17025 - I am looking for someone to come in and certify our laboratory equipment ISO 17025 related Discussions 1
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
J Looking for partners Paid Consulting, Training and Services 2
bryan willemot Looking for an Approved vendors list template Document Control Systems, Procedures, Forms and Templates 11
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
M We are looking for a Contract Manufacturer US Food and Drug Administration (FDA) 2
mihzago Looking for an Australian/ NZ Sponsor Other Medical Device Regulations World-Wide 4
S New Foreign Exporter Looking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
N Looking to Impress - New Job - Advice, Thoughts, Comments Welcome Career and Occupation Discussions 23
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
N Looking for Gamma sterilization facility in China ISO 13485:2016 - Medical Device Quality Management Systems 4
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
A New to QC, looking for resources Problem Solving, Root Cause Fault and Failure Analysis 3
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
C Looking for China Good manufacturing practice China Medical Device Regulations 1
M Is Harmonised EN 1041 (Information Supplied By Manufacturer) Worth Looking At? EU Medical Device Regulations 7
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
A We're currently looking for any studies performed on various PPE materials Qualification and Validation (including 21 CFR Part 11) 1
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
pashah Looking for Usability File Template acc. IEC 62366-1 and IEC 60601-1-6 IEC 62366 - Medical Device Usability Engineering 4
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
bryan willemot Looking for a good CoC to put with my certification sheets when we send parts Document Control Systems, Procedures, Forms and Templates 1
L I'm looking for Translation Procedure Guide MEDDEV 2.5/5 Rev.2 (NOT Rev.3) CE Marking (Conformité Européene) / CB Scheme 0
K Looking for a good Six Sigma book Six Sigma 7
G Looking to move to an electronic QMS software Software Quality Assurance 11
C Looking for source of silicone contamination in ISO Class 8 Cleanroom Other Medical Device Related Standards 2
F Looking for a Japan MAH recommendation that is not too expensive Japan Medical Device Regulations 6
P Looking for Risk Assessment Template - Not necessarily Asset based IEC 27001 - Information Security Management Systems (ISMS) 1
S Looking for procedure on UDI (Unique Device Identification) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
