Looking for resistance welding FMEA examples
L
lovingquality
Hello everyone,
We are starting to take the FEMA more seriously... ( about time). My team and I have be tasked with creating a Golden FMEA for our organization. We currently Stamp, Weld (resistance and Spot) and lite assemble. I was looking for help in finding a resistance weld FMEA that could help us start our brains going. I know every process is different but, I am looking for a genralized FMEA. We use H frame tip to tip welders, with weld controllers. We weld all different size weld studs and nuts, on sheet metal stamping (thickness 2.mm-5.mm). Most of our welders are single hit.
P.S. I just love this site!!!!!!!
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove! :bigwave:
A golden FMEA? Hmmmm. Do you have a copy of the FMEA Manual by the automotive group?
The problem with examples is that it can be so tempting to use the example's information instead of making the FMEA reflect your processes. Templates can be made with documents or spreadsheets, but the information should be entered into some type of blank form.
The Manual is made for automotive, so interpreting it can be tricky. I found a sample FMEA for machinery here. I am not affiliated with Reliasoft.
I wanted to include that example because I thought it did a good job of defining the criteria for assigning severity, occurence and detection ratings. I have seen people struggle to apply automotive manual definitions to their own industries.
This forum also has training for FMEA. Since FMEAs are supposed to be a multifunctional effort, there will need to be some awareness development to get this thing done right.
I hope this helps!
Q
Quality-Geek
WOW, your facility sounds just like mine, except for the location... I'm in Nebraska. Are you in the automotive industry?
While I do have FMEA's that would probably suit your needs, they are so bad that I hesitate to let anyone see them. I inherited an old format that doesn't work very well and doesn't define the criteria well enough to be useful. (We finally got new forms from our parent company, and they are much better. Now if I only had the time to review every FMEA...)
Get onto AIAG's website. They have books and training classes for a ton of stuff, including FMEA's. Also, check out Quality Press - I've gotten a couple useful books there for other subjects. I hope this helps!!
After I posted this, I got an e-mail from ASQ about a virtual FMEA course. I haven't checked into it at all, but I thought the timing was perfect.
L
lovingquality
Well thank you for the replies.
I knew that people would feel that we would use the example as our FMEA. I don't want to do this. We do not have a great deal of Welding experience outside of our walls. We have a few weld tech's, but they are home grown. We are looking for outside experience to glean understanding off of.
Quality-Geek,
I to have inherited a very derelict FMEA system. I have worked for two years to convince everyone if you use the FMEA correctly it will be our saving grace in:
APQP
Root cause
Lessons learned
We have done a great job on our Receiving and Prog. press FMEA's I would be willing to share. I feel if a company is going to borrow a FMEA and just use it as is, then they will suffer in the long run. I will not let that happen to us.
Thanks,
Mike
Jen Kirley
I did a Google search and didn't come up with any samples for a welding process. I do also like referring to samples. :agree:
When I did a search on this site, using the Search tool (yellow font in the blue tool bar above) and key words "welding fmea", I came up with this list of threads. A couple of the threads have attachments in them. Maybe they will help.
Another hint: When reading a post, scroll to the bottom of the page and see a list of suggested similar links.
You are unlikely to get a weld-specific FMEA. Most companies have strong policies against giving out intellectual property such as this. Are there specific areas that we can help with such as weld-specific failure modes?
Stijloor
Hello everyone,
We are starting to take the FEMA more seriously... (about time). My team and I have be tasked with creating a Golden FMEA for our organization. We currently Stamp, Weld (resistance and Spot) and lite assemble. I was looking for help in finding a resistance weld FMEA that could help us start our brains going. I know every process is different but, I am looking for a generalized FMEA. We use H frame tip to tip welders, with weld controllers. We weld all different size weld studs and nuts, on sheet metal stamping (thickness 2.mm-5.mm). Most of our welders are single hit.
How do you define a "Golden FMEA?"
You may want to start developing a draft FMEA (record) and then post it here for review. Examples may help to see how others do it, but the "best" ones are the FMEA's you do yourself.
Stijloor.
L
lovingquality
A "Golden FMEA" is = a FMEA with a collection of Failure modes and assoc. Causes.
We will use this during our APQP process to save time we will add or delete as needed to address our product. We will also use it for our lessons learned updating new Failure modes and causes along with our corrections.
Anyhow If I could ask the forum to list possible failure modes and related causes (related to Spot or resistance welding). I don't need to know how to correct them. We have a very good team to put in place Poka-yokes and process to correct.
Just to give you some in-sight or examples of what I am up against:
When we started reviewing our FMEA's we had let's take the receiving failure modes:
Then
Improper Gage and Coil Width
Chemical Condition
Rust
Now
Improper ID
Chemical Condition
Physical and Surface Condition
Rust
Foreign Material
lamination
Scoring
And I could go on.... it was the same for the Failures and causes we went from around 5 to 14 or more.
CarolX
I have a really silly question to start - what is the difference between resistance and spot? In my book they are one in the same - RSW - resistance spot welding.
OK - so here is my list of what can go wrong
Weld Quality
Weld Location
Number of Welds
Now that is a pretty generic list, but it really covers it all - I am sure you can get real specific about different aspects of weld quality such as nugget size, deformation, etc. but this may get you started.
Hope this helps a bit.
Matt Swartwood
First, you must identify all current and possible ways the process can fail. Then you identify all of the possible causes for each failure and what failsafes you have in place to prevent each cause of failure. Finally, determine RPN's based on how severe the issue would be, how often it could occur, and how easily the defect would be noticed) Hint: the more fixturing/error-proofing you put in place, the lower the detection number will be.
Potential failure modes for spot weld (metal to metal) might include:
Weld in wrong location
Not enough or too many welds
Weld shear
Poor penetration
Cold welds
Undersized weld nugget
Weld does not meet peel test requirements
Weld porosity
Burn through
Weld flash (sharp burrs)
Part deformation or damage
Potential failure modes for spot weld (metal to nuts/bolts/other hardware) might include:
Hardware fails torque test
Hardware fails pushout test
Threads damaged
Flash in threads
Flash in hole
Hardware off center
Hardware not flush
Hardware not square/perpendicular
Wrong hardware used
Hardware in wrong position (GD&Tpositional callout)
Hardware in wrong location (wrong hole)
Hope this helps.
J Looking for partners Paid Consulting, Training and Services 2
bryan willemot Looking for an Approved vendors list template Document Control Systems, Procedures, Forms and Templates 11
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
K Looking for a job as Quality Engineer Career and Occupation Discussions 2
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
M We are looking for a Contract Manufacturer US Food and Drug Administration (FDA) 2
mihzago Looking for an Australian/ NZ Sponsor Other Medical Device Regulations World-Wide 4
S New Foreign Exporter Looking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
N Looking to Impress - New Job - Advice, Thoughts, Comments Welcome Career and Occupation Discussions 23
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
N Looking for Gamma sterilization facility in China ISO 13485:2016 - Medical Device Quality Management Systems 4
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
A New to QC, looking for resources Problem Solving, Root Cause Fault and Failure Analysis 3
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
C Looking for China Good manufacturing practice China Medical Device Regulations 1
M Is Harmonised EN 1041 (Information Supplied By Manufacturer) Worth Looking At? EU Medical Device Regulations 7
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
A We're currently looking for any studies performed on various PPE materials Qualification and Validation (including 21 CFR Part 11) 1
C Looking for APQP Training recommendations preferably in the aerospace industry APQP and PPAP 2
M Looking for third party reviewers for FDA submissions US Food and Drug Administration (FDA) 2
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
W My company is looking to start a materials testing lab that conforms to ISO17025:2017 ISO 17025 related Discussions 3
pashah Looking for Usability File Template acc. IEC 62366-1 and IEC 60601-1-6 IEC 62366 - Medical Device Usability Engineering 4
pashah Looking for Clinical Evaluation SOP acc. MEDDEV and EU MDR Other Medical Device Related Standards 1
bryan willemot Looking for a good CoC to put with my certification sheets when we send parts Document Control Systems, Procedures, Forms and Templates 1
L I'm looking for Translation Procedure Guide MEDDEV 2.5/5 Rev.2 (NOT Rev.3) CE Marking (Conformité Européene) / CB Scheme 0
K Looking for a good Six Sigma book Six Sigma 7
G Looking to move to an electronic QMS software Software Quality Assurance 11
C Looking for source of silicone contamination in ISO Class 8 Cleanroom Other Medical Device Related Standards 2
F Looking for a Japan MAH recommendation that is not too expensive Japan Medical Device Regulations 6
P Looking for Risk Assessment Template - Not necessarily Asset based IEC 27001 - Information Security Management Systems (ISMS) 1
S Looking for procedure on UDI (Unique Device Identification) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
M Start-Up Company looking for ISO 13485 Certification Body and Medical Device CE Mark Notified Body Registrars and Notified Bodies 6
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
Ajit Basrur Looking for a Design Transfer Checklist 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N I am looking at two Registrars Registrars and Notified Bodies 18
