Looking to Impress - New Job - Advice, Thoughts, Comments Welcome
NikkiQSM
I have recently taken on a part time position of Quality Manager at a small company that builds metal medical trays. The trays are held together with brackets and are used to contain medical tools for hospitals.
The trays are FDA approved, but the company is not ISO certified. The owner would like to be ISO 13485 certified by the beginning of the year, to get additional business.
From what I see, major organization is needed. They are a small company - 10 or so employees tops. The owner has been doing all the major ISO related work, but has not kept up on it.
The company outsources almost everything! They provide specs for the metal parts to be cut, and then the parts arrive and they put them together, and ship them out. That's it.
There is a lacking of documentation to say the least. When an order is prepared, all the parts are put on a movable cart. Nothing really stops someone from walking by and just grabbing one of the many pieces. The carts are identified with a single lot number. Nothing more.
I think my biggest hurdle will be getting everyone to follow the process, as everyone just does what they do.
They haven't done an internal audit in 2 years.
How would you approach this challenge? What would you focus on first? Any comments are appreciated.
Johnny Quality
That's quite the challenge you have!
I'd sit back and watch how the business functions and see how it matches to their documented procedures (if they have some). Try to listen and shush for a while and let everyone else talk.
Though you mention the owner would like be ISO 13485 certified by the end of the year? I'm ignorant on ISO 13485 but is four months enough time? I'd find out what's involved and see what the actual time frame is.
Finally, what were you hired for? Did the owner mention what they would like you to? That's another good starting point.
Best of luck!
NikkiQSM
Thanks, Johnny. I already am currently a Quality System Manager for a medical compounder. I've been with the company for 15 years. I am very familiar with ISO 9001 and ISO 13485. I set up the company and got both certifications.
While I am still with that company, I took this part time job as a Quality Manager to help certify the company to the 13485 standard. I explained to the owner that once I have had a chance to see how their process works, I can give her a realistic time frame for certification.
Golfman25
Document what they do and work from there. Do not start creating procedures, based on your past experiences, for them to follow. It won't work. If there are gaps, sit down and address the gaps. You're looking for the easiest way to improve or comply. Keep it simple and don't add a bunch of extraneous stuff.
Tagin
Once your QMS is setup and in place, you will need several months to accumulate data and records for the auditors to certify the system. So, beginning of next year (4 mo from now) as a target seems impractical at best.
If this is so, then this needs to be addressed by top mgmt. They need to proactively reinforce the need for everyone to follow procedures and policies. It is both the benefit and the bane of a very small company to tend to have an informal culture.
NikkiQSM
The company currently has documents, and procedures. It's just no one fills out the documents, and whether or not the process follows the documented procedure - I doubt highly.
I wont be creating too much of anything rather than cleaning it up and updating to what is actually being done.
atitheya
Sometimes it is more than what meets the eye.
Have you done a gap analysis? Setting up a company with the standard, and applying the standard in an already existing company are different scenarios. As Johnny Quality says, observe for some time. You may find that a lot of work is being done. May be some of the already documented procedures need a revision to suit the company. At other instances you need to fill the gaps.
Note down the gaps. Educate the top management on the necessity to plug those gaps and the time assessment. Four months is too short a time but it really depends on the status when you do the gap analysis.
Once the top management is in agreement with you, familiarize others in the company with the standard. Involve them, all of them, in development/revision of procedures and other documentation and implementation planning.
Get the QMS implemented. Conduct internal audits, management reviews and improve the QMS and its effectiveness.
yodon
In addition to what others have mentioned, one thing you'll want to focus on since they are outsourcing most everything, will be purchasing and in particular, Quality Agreements. In the Quality Agreement, be sure to spell out that they can't change anything (parts, process) without informing you.
Great responses so far. Yes its definitely challenging but not an impossible task. Best luck!
monoj mon
This would be the best practice for now. Creating too much new procedures may disrupt the work flow, but rather filter out the information that you want to share with them in order to fill the gap just enough to get them certified this time. After that you can suggest the organization plan you have for their next audits. It usually takes time for someone to get adopted with a new system. As a starter, I would suggest to pursue the owner/top management about your new plan for the next audits. Once s(he) is ready to adopt, the rest of the team will automatically follow.
Regarding filling out the documents/following the procedures, make these documents easily accessible to each and everyone (if not confidential). As a general practice, in my company, we hang the forms in folders (or keep a computer/tablet if it is an online form) at every section where it is needed and have assigned someone to keep/collect the records everyday. Same goes with the procedures, we keep the copies at many places for everyone's easy access so that whenever in doubt one can quickly have a look at it. If it is a flowchart, we make a big poster of it and hang it for everyone's visibility.
L Looking for SOP Template for UDI under MDR EU Medical Device Regulations 4
C Supplier Audit - Looking for a quality audit checklist General Auditing Discussions 3
H Looking at options... Misc. Quality Assurance and Business Systems Related Topics 6
R Looking for ISO 13485 Internal Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
M Looking for Navy Instruction OD32193 or OD32190 Various Other Specifications, Standards, and related Requirements 4
P Looking for help with an Ansys Workbench problem Manufacturing and Related Processes 0
X Looking for 17025 auditor to perform internal audit on IT software testing laboratory ISO 17025 related Discussions 3
Ed Panek Looking for Test Resource General Measurement Device and Calibration Topics 1
M RAPS RAC Device - Looking for resources / prep materials & study group Professional Certifications and Degrees 4
S Looking to find a pharmaceutical manufacturer that would be interested in buying or licensing a USDA 510k clearance General Information Resources 4
Anerol C Looking for sorting services at Singapore Career and Occupation Discussions 2
K AS9100 - Looking for advice on how to become a CB Auditor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G Medical Device Auditor (CMDA) certification exam by ASQ - looking for input Career and Occupation Discussions 3
R Looking for an efficient contract management solution Contract Review Process 1
K Design History File - Looking for Examples of DHF's. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Looking to outsource Internal Audit - MDSAP competent auditor needed Other Medical Device Regulations World-Wide 9
Q Measurement Equipment Revocation - Looking for a Disposal Form with Risk Assessment IATF 16949 - Automotive Quality Systems Standard 10
B Looking for SSCP file of IVD devices EU Medical Device Regulations 7
M Looking for a copy of ISO 10651 Hospitals, Clinics & other Health Care Providers 6
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Q Looking for a 5S tracking database Problem Solving, Root Cause Fault and Failure Analysis 4
N Looking for a recommendation for an EU MDR Importer EU Medical Device Regulations 1
K Technical file for MHRA - looking for assistance with self declaration Class I device CE Marking (Conformité Européene) / CB Scheme 8
bryan willemot Looking for an Approved vendors list template Document Control Systems, Procedures, Forms and Templates 11
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
M 'Active' device? Software/laptop with attached camera 'looking' at passive metal probe EU Medical Device Regulations 3
K Looking for guidance to write an SOP on Statistical Methodologies? Statistical Analysis Tools, Techniques and SPC 7
blackholequasar Looking into Nadcap for the first time AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
A 21 CFR 820 - Risk Management - Looking for some guidance US Food and Drug Administration (FDA) 3
S We are looking for EU authorised Representative for both Class I and Class IIb devices EU Medical Device Regulations 7
K Looking for a job as Quality Engineer Career and Occupation Discussions 3
B Looking for 10 Internal Audit Online Training Participants ISO 17025 related Discussions 2
M We are looking for a Contract Manufacturer US Food and Drug Administration (FDA) 2
mihzago Looking for an Australian/ NZ Sponsor Other Medical Device Regulations World-Wide 4
S New Foreign Exporter Looking 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Looking for a training organization that can provide in house DFMEA training FMEA and Control Plans 4
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
S Looking for Quality Content to Build Medical Device Curriculum - Concept to Commercialization Training - Internal, External, Online and Distance Learning 4
N Looking for Gamma sterilization facility in China ISO 13485:2016 - Medical Device Quality Management Systems 4
A 5 x 5 Risk Matrix - Looking for a good example Manufacturing and Related Processes 2
M Looking for a Presentation on Design for Excellence (DfX) Manufacturing and Related Processes 2
J Looking for a EU MDR Gap Analysis template EU Medical Device Regulations 6
J Looking for a template SOP for UDI implementation for EU Medical Devices EU Medical Device Regulations 1
A New to QC, looking for resources Problem Solving, Root Cause Fault and Failure Analysis 3
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K I’m looking for a square probe for my linear height gauge Manufacturing and Related Processes 1
C Looking for China Good manufacturing practice China Medical Device Regulations 1
