Low Process Capability - Cpk - Man-made part - What to do?
Z
ZLYDCOM
I confused that how to handle the low cpk.
Sometimes we have to "prepare" a good data for auditor to meet requirement.
But some process such as man-made part.
Can anybody help me on this?
W
wmarhel
You could go a couple of different routes:
1) Perhaps the specification limits are unreasonable for a hand-made part. Engineers have been known to make these types of mistakes, regardless of their comments to the contrary.
2) The tools being used, or the level of skill of the person performing the duties is inadequate.
If you could expand on the problem (process, results, etc.) maybe some more light could be shed on the subject.
Keep in mind that process capability is just the measurement of a process as compared to the specification limits. It doesn't necessarily have anything to do with the actual quality of the end product.
Wayne
bramanta
Low cpk mean there is still variation of the ouput which is big if it is compared with specification range. knowing that cpk is low is the first step to improve the process. maybe the material contribute significantly the variation. or may be the machine, tool, the operator as wmarhel said. What we have to do is find the source of output variation and try to reduce it.
hope this help.
Statistical Steven
Statistician
Only 3 things can be done.
1. Change the specifications
2. Reduce the variability
3. Sort and Suffer
Reduction in variation is the quest of most quality professionals, but it is the hardest. Changing the specification requires customer buy off, so that can be difficult. So you can always inspect every unit and throw away the units that fail.
alfawei
3. Sort and Suffer
pls check Ca large ?
if is large>0.125, adjust the process
pls review your control chart ,make sure stable
Murphys Law
Another "It depends" answer.
Low Cpk potentially suggests that you are producing parts out of spec and you need to be 100% testing/inspecting each product.
Why you are fudging it for an audit? It is a bad practice. Your management needs to be seeing this and reacting to it.
Low Cpk could also come from having outlier readings. The distribution may be bimodal. Take a different view on your data not just on the Cpk chart.
Low Cpk may also be because it is too tight a spec as was mentioned earlier.
You could negotiate a relaxation with your customer. You never know, the thing you are taking a yield on is not a customer careabout. (I have seen this many times). On the otherhand, if it is critical and you are taking considerable scrap on this, you need a continual improvement action. Either improve process or your company needs to live with the scrap. (Your business manager should be aware of this as it if it is not profitable, your company should exit that product line or make business case to invest in new process).
Marc
What is the volume? When I think of 'man-made part', I think of very low volume. How does the volume come into play here?
S How to Capture Low Volume Process Info? Lean in Manufacturing and Service Industries 3
G Histogram Interpretation when a process is "running too high" or "running too low"? Quality Tools, Improvement and Analysis 4
K Process Validation of Low Volume Production of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
Q High value for Cp (i.e. low process sigma) - Is MSA required? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
D Importing a general wellness low risk product Other US Medical Device Regulations 3
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
J ISO 14971 applied to ISO 13485? Low risk class 1 devices ISO 13485:2016 - Medical Device Quality Management Systems 5
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Use part of high risk device for establishing low risk device EU Medical Device Regulations 0
R Laminate ESD Mats - Low resistance (RTT) readings Manufacturing and Related Processes 6
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
A MDSAP benefit for manufacturer of low-risk devices Canada Medical Device Regulations 3
Rincewind Clinical Evaluation of very low risk medical devices EU Medical Device Regulations 3
L Nonconformity's risk is too low, so don't report it? General Auditing Discussions 25
E Applicability of Low Voltage Directive (LVD) for 12V equipment CE Marking (Conformité Européene) / CB Scheme 4
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
M Battery Powered Measurement Equipment and Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
G CE Marking - Low Voltage Directive and EMC Directive CE Marking (Conformité Européene) / CB Scheme 4
Marc New FDA guidance on low-risk wellness devices US Food and Drug Administration (FDA) 1
J If/how to apply LVD (Low Voltage Directive) in this case CE Marking (Conformité Européene) / CB Scheme 6
R Looking for good, low cost APQP Software recommendations APQP and PPAP 2
V For screening a design, can we live with the low/poor predicted R-Sq.? Statistical Analysis Tools, Techniques and SPC 3
M Chrysler PSW Sign Off when your product is rated low risk in CQMS IATF 16949 - Automotive Quality Systems Standard 5
S Low Sample Size for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M David vs Goliath (Large Suppliers vs Low Volume Purchasers) Supplier Quality Assurance and other Supplier Issues 11
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
Wes Bucey A "Feel Good" story - 3D Printing Creates Low-Cost Prosthetic Fingers Coffee Break and Water Cooler Discussions 0
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
Y How to cut off Extremely High and Low Data Statistical Analysis Tools, Techniques and SPC 2
M Control Measures for Hazards already deemed Low Risk ISO 14971 - Medical Device Risk Management 6
M Need Machining Low Volume Family Control Plan and PFMEA APQP and PPAP 1
C CE Marking for LVD (Low Voltage Directive) Health and Beauty Products CE Marking (Conformité Européene) / CB Scheme 5
C Suggestions on Sample Plans for High Volume/Low Cost/Low Risk Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F CE Marked Motors - BS-EN61010 for the Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
S FMEA Manual aimed at Low Volume Fabrication Industry FMEA and Control Plans 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
N Extent of Product Traceability Required by ISO 13485 (Low Level Class I Devices) ISO 13485:2016 - Medical Device Quality Management Systems 3
J CAPA Effectiveness Checks on Low/No Volume Processes Nonconformance and Corrective Action 7
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Use of PPMs in Low Volume Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G ISO 17664 Reusable Low Risk Medical Device Cleaning Other Medical Device Related Standards 2
M Differences between High, Medium, Low Risk Suppliers Supplier Quality Assurance and other Supplier Issues 5
K Probability of Occurrence Ranking for Low Volume Manufacturing vs High Volume FMEA and Control Plans 11
M What is the basis of ALARP (As Low as Reasonably Practicable) ISO 14971 - Medical Device Risk Management 9
