Low-tech way to check a chamfer at the machine
cpbraun
I remember in the past seeing chamfer gage sets (like radius gage sets) that operators could use to check the depth of a 45° chamfer at the machine (go/no) Any idea if these are still manufactured or not? Where to get them?
Thanks.
Well I don't know if there are sets out there. you might need to do some calling around...
Personally I'd use a six inch rule with an adjustable stop like the one HEREThis way it can be set and the operator can do the check.
Peace
James
bobdoering
Stop X-bar/R Madness!!
You can go real old school with the double ball method. I don't recommend it...but it is out there as an option.
cpbraun
These work great on circular features, and I have used them often. I am looking for something to check .03-.04 x 45° callouts on non-circular edges....
Without knowing the application, I have to say that this sounds like a pretty specific callout for what sounds essentially like "break the corner" or "remove sharp edges....
How critical is this to fit and function?
Probably your best bet is to have a special gage made up.
Peace
James
cpbraun
Thanks for the reply James. Most likely, I will have to get gages made up. As to your question, I went back to review our print and P.O. and found no mention of fit or function... Never seen that on a technical print before.....
silentrunning
Are you talking about putting an edge champer on a sheet metal part? If so, we use a protractor and caliper for on line checks. A skilled operator can check amazingly close with these tools. It's pretty low tech too. :)
Doug
T Risk Management in a very small low tech, Class 1 Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
Marc Electronic Documents - High Tech vs. Low Tech Document Control Systems, Procedures, Forms and Templates 3
D Ultra low freezer thermometers, best practices? ISO 13485:2016 - Medical Device Quality Management Systems 8
R MSA on set of parts with low variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
Z REACH compliance for low volume product REACH and RoHS Conversations 1
B Combat Low Part to Part Variation in GRR Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Requirements for Cables used for Low-Voltage DC Mains (12-36VDC) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
Proud Liberal Improving low p-value Statistical Analysis Tools, Techniques and SPC 13
D Importing a general wellness low risk product Other US Medical Device Regulations 3
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
J ISO 14971 applied to ISO 13485? Low risk class 1 devices ISO 13485:2016 - Medical Device Quality Management Systems 5
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Use part of high risk device for establishing low risk device EU Medical Device Regulations 0
R Laminate ESD Mats - Low resistance (RTT) readings Manufacturing and Related Processes 6
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
A MDSAP benefit for manufacturer of low-risk devices Canada Medical Device Regulations 3
Rincewind Clinical Evaluation of very low risk medical devices EU Medical Device Regulations 3
L Nonconformity's risk is too low, so don't report it? General Auditing Discussions 25
E Applicability of Low Voltage Directive (LVD) for 12V equipment CE Marking (Conformité Européene) / CB Scheme 4
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
M Battery Powered Measurement Equipment and Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
G CE Marking - Low Voltage Directive and EMC Directive CE Marking (Conformité Européene) / CB Scheme 4
Marc New FDA guidance on low-risk wellness devices US Food and Drug Administration (FDA) 1
J If/how to apply LVD (Low Voltage Directive) in this case CE Marking (Conformité Européene) / CB Scheme 6
R Looking for good, low cost APQP Software recommendations APQP and PPAP 2
V For screening a design, can we live with the low/poor predicted R-Sq.? Statistical Analysis Tools, Techniques and SPC 3
M Chrysler PSW Sign Off when your product is rated low risk in CQMS IATF 16949 - Automotive Quality Systems Standard 5
S Low Sample Size for Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M David vs Goliath (Large Suppliers vs Low Volume Purchasers) Supplier Quality Assurance and other Supplier Issues 11
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
Wes Bucey A "Feel Good" story - 3D Printing Creates Low-Cost Prosthetic Fingers Coffee Break and Water Cooler Discussions 0
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
Y How to cut off Extremely High and Low Data Statistical Analysis Tools, Techniques and SPC 2
S How to Capture Low Volume Process Info? Lean in Manufacturing and Service Industries 3
M Control Measures for Hazards already deemed Low Risk ISO 14971 - Medical Device Risk Management 6
M Need Machining Low Volume Family Control Plan and PFMEA APQP and PPAP 1
C CE Marking for LVD (Low Voltage Directive) Health and Beauty Products CE Marking (Conformité Européene) / CB Scheme 5
C Suggestions on Sample Plans for High Volume/Low Cost/Low Risk Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F CE Marked Motors - BS-EN61010 for the Low Voltage Directive CE Marking (Conformité Européene) / CB Scheme 1
S FMEA Manual aimed at Low Volume Fabrication Industry FMEA and Control Plans 1
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
N Extent of Product Traceability Required by ISO 13485 (Low Level Class I Devices) ISO 13485:2016 - Medical Device Quality Management Systems 3
J CAPA Effectiveness Checks on Low/No Volume Processes Nonconformance and Corrective Action 7
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Use of PPMs in Low Volume Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
G ISO 17664 Reusable Low Risk Medical Device Cleaning Other Medical Device Related Standards 2
M Differences between High, Medium, Low Risk Suppliers Supplier Quality Assurance and other Supplier Issues 5
