Machine Feature: Is it possible to consider it Error Proofing?
mayank_thkkr
I am confused whether or not to consider inbuilt machine feature as Error Proofing and identify them as current preventive control ??
:thanx:
DrM2u
Well, you could use this as an example of error proofing if you specified the equipment with certain features that would eliminate the errors you are talking about. An auditor might challenge your position if the features are standard for the equipment, or if the features were not specified on the request for quote, the purchase order, IQ, OQ, or any other internal document related to the selection of the equipment. In other words, "prove to me that you had this error proofing in mind when you selected this equipment in particular".
:thanx:
BEcause you've posted this in the FMEA forum, I'm assuming that you're referring to the PFMEA Occurrence factor. If you have identified a potential failure mode, and a feature of a machine prevents the failure from occurring, I don't see why you shouldn't consider it an error-proofing feature.
On page 93 of the 4th edition AIAG FMEA manual, there's a table that gives guidelines for determination of the Occurrence number. In order to assign a "1," the criterion given in the table is "Failure is eliminated through preventive control."
If a given control prevents a failure mode from occurring, it doesn't matter whether it was specified for that purpose or not.
qusys
:thanx:
As Jim said, I think you can as per AIAG guideline for FMEA..
Is the risk acceptable for you looking at RPN or should you still search for recommended actions, working at occurrence and detection?:bigwave:
TShepherd
The short answer is yes - assuming that when you mean that the Machine does not allow the error to occure - if the machine only catchs the error and stops the process from passing the non-conformity on it commonly know as Mistake Proofing and would result in a different RPN outcome.
Tom :2cents:
Tom :2cents:
Good point. The difference is between Occurrence and Detection. If the machine feature prevents the bad thing from happening, it affects the Occurrence factor; if it detects the bad thing after it happens, it affects the Detection factor.
D Attribute Gage R&R study - Automatic machine that tests for a particular feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
R Machine directory (2006/42/EEC) is applicable or not Other Medical Device Related Standards 0
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Marc The German Enigma Machine of World War II After Work and Weekend Discussion Topics 0
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
C Machine Verification Plan Manufacturing and Related Processes 2
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
GoSpeedRacer Veterinary anesthesia machine CE Marking (Conformité Européene) / CB Scheme 1
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
J Extent of Validation - New machine installed in manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
K IEC 60601-1-9 Compliance mendatory or Not - CT Scan machine CE Marking (Conformité Européene) / CB Scheme 8
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Help with Arburg Allround 320s Injection Molding Machine Manufacturing and Related Processes 3
P Injection Molding Machine Validation Scope Capability, Accuracy and Stability - Processes, Machines, etc. 6
