Machine issue in Cpk/Ppk and Control Plan - PPAP Submissions
Jimmy_Nie
Dear pros,
In the PPAP submissions, machine numbers for a specified process are mentioned in both Control Plan and and Capability studies(Cpk or Ppk). My question is,
Is the machine number for a specified process mentioned in Control Plan the same as the one mentioned in the Capability studies for the same process ?
is it Cpk report or Ppk report to be submitted for the Capability studies in the PPAP submissions?
Thanks,
Jimmy
sinned
Registered Visitor
Hi Jimmy,
i do not fully understand your first question. But the fact is i typically do not mark the m/c number on the control plan.
To your 2nd question, i submit PPAP package with Ppk studies where a number of samples for measurement were selected at random from the PPAP batch of parts. This PPAP batch will not be large in most of the time. The key difference between the two is in the way you collect your samples. If you are able to use control chart in your PPAP run, you can compute Cpk as well.
In fact, i found it a dilemma when chosing between Ppk and Cpk for PPAP submission. Because the PPAP run is normally short in time and small in qty, you can't obtain a representative control chart for Cpk calculation. Hence, you go for Ppk. Ppk is supposed to cover all variations in the process. But in the short PPAP run, variation from mat'l etc. may not enter into the picture. Giving Ppk in PPAP only tell the customer your capability at that particular point in time. Ppk says nothing about future performance. So customer gets no information at all on your future performance by looking at your PPAP. On the other hand, Cpk gives you the best possible capability of your process which, in the eyes of the customer, may be more valuable for them to consider approving your PPAP.
Maybe i still need some light here.
Howard Atkins
Forum Administrator
Dear pros,
Thanks,
Jimmy
Welcome to the cove.
You are supposed to define the machine that you use for the production as different machines can give different results.
Companies that use different machines for production usually declare this and say they are equivalent.
Change of machine could require a new PPAP.
I always submit Ppk as the PPAP run needs to be only 300 parts.
Jimmy_Nie
Many thanks to sinned and Howard Atkins.
we may find that we need to identify/describe Machine, Device, Jig, Tools for Mfg. in the Control Plan (please see Control Plan in APQP manual for details). Also on the Ppk study sheet (or X-bar and R control chart), we need to describe machine No. for the certain process which in some case, the the same characteristics as the one in the Control Plan). This is why I ask the previous question.
Personnally I agree with Howard Atkins.
But where can I find proof (somewhere in PPAP or APQP, etc.) so that I can convince others that I am correct?
Thanks again. Happy New Year.
Jimmy
Dave Dunn
Regarding Cpk/Ppk for PPAP submissions, review your customer's supplier quality manual if they have one. They may require capability be reported using a specific index.
Howard Atkins
Forum Administrator
From the 4th edition PPAP Handbook
I
nitial Process Studies.
The purpose of the initial process study is to understand the process variation, not just to achieve a specific index value. When historical data are available or enough initial data exist to plot a control chart (at least 100 individual samples), Cpk can be calculated when the process is stable.
Otherwise, for processes with known and predictable special causes and output meeting specifications, Ppk should be used. When not enough data are available (< 100 samples) or there are unknown sources of variation, contact the authorized customer representative to develop a suitable plan.
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
R Machine directory (2006/42/EEC) is applicable or not Other Medical Device Related Standards 0
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Marc The German Enigma Machine of World War II After Work and Weekend Discussion Topics 0
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
C Machine Verification Plan Manufacturing and Related Processes 2
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
GoSpeedRacer Veterinary anesthesia machine CE Marking (Conformité Européene) / CB Scheme 1
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
J Extent of Validation - New machine installed in manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
K IEC 60601-1-9 Compliance mendatory or Not - CT Scan machine CE Marking (Conformité Européene) / CB Scheme 8
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Statistic Tools to Know Capability of Sealing Machine for Seal Width Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Help with Arburg Allround 320s Injection Molding Machine Manufacturing and Related Processes 3
P Injection Molding Machine Validation Scope Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
