Machine Set-Up Sheets for More Than One Kind of Equipment
Jen Kirley
Quality and Auditing Expert
#11
I would think it's quite challenging to set up a universal tool box of machine set up sheets. Aside from making sure the drill bit is the right size, chucks are aligned and properly tightened, I can't think of much in common between a drill press and a CNC gundrilling machine.
Ettore
#12
Why not? Look or example the Aiag control plan. Now it is the form for write a control plan more used, in the past control plans were written in many difference ways.
Or look at the system for write a process there are only few system for write it now IDEF , Turtle diagram, matrix diagram, but in the past? :bigwave:
V
Valeri
#13
Before it goes to the production phase we have all set up data approved via LIV.III of EDP system. We have also control plan for every production line via Intranet and attached at the wall of every Phase of production, issued reviewed and approved after FMEA. The production plan referred to machine set up cards.
Could someone program the EDP system to create a set-up sheet from this information? It's already approved & whenever changed would automatically update the set-up sheet to ensure correct revision is being used.
Jen Kirley
#15
I would think the set up could best standardized in the same fashion as a job router, with steps being given a number.
If a step like "Align chuck jaws" would need to fundamentally change from one tool to the next, it could be broken down by digits, name or number of tool, etc.
A database could hold a master list of all of these, and process steps only belonging to "Sammy" (tool name) could be listed along with generic steps (steps that do not differ from one tool to the next).
Step
1. Select drill bit
2. Insert into chuck
3. Align chuck jaws
3Sammy. Align chuck jaws with a .010 feeler gage; all jaws must touch the curring tool shaft to achieve even pressure and a straight trajectory. Tighten to 25 inch lbs using a .250" allen head torque wrench.
Once a tool set up is established, it could be saved and just edited later.
Disclaimer: this is how I imagine setting up a system in a job shop, using rudimentary tools like Excel or Access. Your needs may vary, and manufacturing flow software almost surely will be more sophisticated, it seems to me.
V
Valeri
#16
Sure, but what do you think Valery, about general standardization of way to design this kind of sheet?
That could be a possibility - If your set-ups were similar, lay out the information for all of them & see what correlation can be made - keeping in mind that "sameness" does not always meet the needs.
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M AS9100C Document Control for Machine Set Up Work Instructions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S SMED on Punching Machine - Reducing Set-Up Time Lean in Manufacturing and Service Industries 4
T Failure Modes for Machine Set-up/Production Dimensional Checks FMEA and Control Plans 2
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
R Machine directory (2006/42/EEC) is applicable or not Other Medical Device Related Standards 0
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Marc The German Enigma Machine of World War II After Work and Weekend Discussion Topics 0
R Revalidation machine line and Stability Studies impact. Medical Device and FDA Regulations and Standards News 3
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
P How far an operator can reach into a machine before it becomes an ergonomic problem CE Marking (Conformité Européene) / CB Scheme 5
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
C Machine Verification Plan Manufacturing and Related Processes 2
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
Marco Bernardi Plane measurement with a 3D touch machine like a CMM. Calibration and Metrology Software and Hardware 3
Marco Bernardi Diameters measurement with 3D touch machine like a CMM Calibration and Metrology Software and Hardware 4
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
GoSpeedRacer Veterinary anesthesia machine CE Marking (Conformité Européene) / CB Scheme 1
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
R How to properly use Survival Analysis to predict time to machine failure Reliability Analysis - Predictions, Testing and Standards 0
K Mammography Machine Bench Testing - FDA 510(K) US Food and Drug Administration (FDA) 5
J Extent of Validation - New machine installed in manufacturing ISO 13485:2016 - Medical Device Quality Management Systems 8
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
D 4M (Man, machine, method, materials) Management Manufacturing and Related Processes 3
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
K Is Compliance Testing of IEC 60601-2-63 mandatory for Europe - Dental X-Ray machine CE Marking (Conformité Européene) / CB Scheme 3
K IEC 60601-1-9 Compliance mendatory or Not - CT Scan machine CE Marking (Conformité Européene) / CB Scheme 8
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
