Machine Shop Tool Crib Procedure - Tooling for CNC mills
P
pjohal
Hi All,
I'm looking for a general Tool Crib Procedure that can be implemented in a machine shop. More specifically, it needs to focus on the tooling for CNC mills in regards to the wear and tear of the tools. How should the tooling be verified, how often (before and after use?), etc.
Does anyone have any suggestions?
Wes Bucey
Prophet of Profit
Hi All,
To narrow the scope of your query:
Is the machine shop engaging in long runs where tooling is likely to wear (degrade) or break before the run is complete? (this might entail implementing an in-process combination procedure of SPC to monitor changes in workpiece quality and periodic inspection of the tool itself for wear or damage.) In the case of a mill working on a large workpiece which may require multiple shifts to complete one workpiece, it certainly makes sense to implement an inspection schedule to examine tool wear. Armed with data from a series of such inspections, a plan can be put in place to swap out tools before degradation affects quality of output, but not too soon. It's all a matter of economics - cost and time to change out tooling (lost production, cost of tool, labor) versus cost and possible damage to either the machine or an expensive workpiece if the tool breaks or fails during operation.
When I had three and five axis machines working on very expensive workpieces (many, many times the cost of the cutting tool), my operators frequently halted production to examine the cutting tool for wear and replacing the tool rather than risk damaging the workpiece if the tool failed or broke. Dull tools can be refurbished, broken ones can't.
In my turning centers, we had both physical and optical probes (depending on the machine) which would periodically check the tool for wear or damage, automatically indexing to a new tool when preset parameters were exceeded. Tools were then examined at leisure to confirm the probes were performing as desired.
The selection of the proper tool (material, design) as well as feeds and speeds is a combination of art and science. The use of Design of Experiments may often be too costly for the size and profit margin on a production run to fine tune to the optimum combination because, especially in low piece price/value, it may be more economical to run a tool to the point where it no longer produces conforming material, scrapping a few piece parts which are less expensive than the tool or inserts.
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T QMS Template Help - Small machine shop/job shop Manufacturing and Related Processes 1
J Starting from scratch - a plethora of challenges for a new Lumber Mill Machine Shop Quality Management System (QMS) Manuals 11
T EN 10204 3.1 Inspection Certificate - Machine Shop Various Other Specifications, Standards, and related Requirements 4
M AS9100d (section 7.1.3) example of compliance in machine shop environment. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B ISO 9001:2015 for a Small Machine Shop need Resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H AS9100D Cert question - Small machine shop - Where can I buy a certificate? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
M Industry Standards - Sheet Metal a Machine Shop Manufacturing and Related Processes 1
J Suggestions on Inadequate Resources in a Small Machine Shop Nonconformance and Corrective Action 2
M API Monogram License for a Small Machine Shop Oil and Gas Industry Standards and Regulations 1
J QMS and ISO 9001 for a Single Person Machine Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
S Job travelers through a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Start Up of a small AS9100 Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S How will ISO 9001 help the machinists in a very small Machine Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
B Machine Shop Yield and Cost - Productivity, Yield and Absorption Performance Manufacturing and Related Processes 3
M Start New Machine Shop OR BUY Business Continuity & Resiliency Planning (BCRP) 9
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
M Machine Shop Process Instructions (Traveler) question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Use of PPMs in Low Volume Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Product FMEA vs. Process FMEA - Aerospace Industry Machine Shop FMEA and Control Plans 5
N Setting up MSA system in a machine shop environment. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N Setting up a new Calibration Room in a Machine Shop Calibration and Metrology Software and Hardware 3
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
H AS9100C 6.2.2 Compliance - Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Microscope Power to use for Visual Inspections in an Aerospace Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K Defect Reporting and Tracking Software for a Small Machine Shop Quality Assurance and Compliance Software Tools and Solutions 1
Project Man The "Ifs" in ISO 13485 Clause 6.4 Work Environment - Machine Shop which makes parts ISO 13485:2016 - Medical Device Quality Management Systems 1
E Configuration Managment in an Engineering Sub-Contract Machine Shop (3 people) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Where to begin defining and monitoring Quality Metrics in a Machine Shop Manufacturing and Related Processes 9
bobdoering Measurement Expert Advice - Modern Machine Shop Magazine Column General Measurement Device and Calibration Topics 0
E Production Planning in an Industrial Machine JOB SHOP Lean in Manufacturing and Service Industries 1
B SPC Software Selection for use in a CNC Machine Shop - InfinityQS and Lighthouse Quality Assurance and Compliance Software Tools and Solutions 3
W Special Training Tools for the Deaf in a Machine Shop Training - Internal, External, Online and Distance Learning 16
Douglas E. Purdy Sample Production FMEA for Machine Shop wanted FMEA and Control Plans 3
C What to expect in a GE Aerospace Audit of a 100 Person Machine Shop Customer and Company Specific Requirements 5
M Training and Competence requirements in a Small Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S What is the Secret of Excellent Quality in a Machine shop? Misc. Quality Assurance and Business Systems Related Topics 29
S Implementing Dock To Stock in a Small Machine Shop Misc. Quality Assurance and Business Systems Related Topics 6
O NET-INSPECT is it worth it? Small Machine Shop doing AS9100 Quality Manager and Management Related Issues 8
Q Machine Shop Yield & Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
D AS9100 Design - Machine shop offering Drafting Services? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R 7.2.1 Customer Requirements Checklist for a Small Contract Manufacturing Machine Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Contract Machine and Fabrication Shop - AS9100 Exemptions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Paperless Electronic Records in a Machine Shop Records and Data - Quality, Legal and Other Evidence 8
L In-Process and Final Inspection for a job shop (Machine) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Is SPC a requirement of AS9100? Small Machine Shop and Assembly AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B Requirements for AS9100 Contract Machine Shop in FAA Certification Process Federal Aviation Administration (FAA) Standards and Requirements 2
L Training Requirements Documentation and Records - Machine Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
