Magnetic Particle Inspection Non-Destructive Testing Procedure
  • Thread starter SystemsQualityGuy
  • Start date
SystemsQualityGuy
This is a rush job. I just find out this morning that our company will be starting a new Magnetic particle non-destructive testing process. There is pressure to get it ready as soon as possible as we may be in a race against one of our competitors.:mg:
My company will be getting an MT-Tech Grainer, Magnetic Particle Inspection Machine within a day or two. We need to get it up and running very soon. Specifically we need to create procedures and work instructions and start training workers for the machine.
Unfortunately the company that made it is out of business so getting the user manual is a long shot. I have found general procedures for magnetic particle testing online but I would like to have something more specific for this machine.
We could also use some information for setting it up. Will we need any other equipment? What are the safety considerations?
The machine specs are:
Brand: MT-tech Granier
Country of Manufacture:United States
Stock No. 6635-01-218-4884
Model: 43100
Serial No. 05069601
Magnetizing Intermittent Output Current: 4000 DC - 3000 AC AMPS MAXIMUM
[FONT=&quot]Duty Cyle at 4000 AMPS: 1/2 sec. ON, 24 sec. OFF[/FONT]
[FONT=&quot]Size: 54 inches[/FONT]
Any information would be a great help.
Re: Non-Destructive Testing Procedure
Do you have someone trained in MP testing? This is not quite something you could simply set up and read a measurement. If I remember correctly, it takes about 400 hours of experience to be a class 2 certified NDT in this.
I have a MP procedure for our machine, you can PM me. Ours is a probe-light model Y.
SystemsQualityGuy
I am personally very inexperienced with MP NDT. However, it is my understanding that we will be using it to find cracks/discontinuities in parts. If it does require that much training then we've got some problems ahead.
I'm curious about the machine at your company. What type of parts is the machine used to test?
G
GoKats78
Read ASNT-TC-1A and ASTM E1444
Been almost 30 years since I was certified..but those are the document numbers I remember..also Mil-STD 1949
We use it mainly on forgings, looking for cold laps, fissures, things of that nature. Can also be used on welds occasionally. It took some practice to interpret the results, best learned with some defective parts to see how the patterns develop. I have always found it somewhat subjective on the things we check, so I prefer DP testing, which is a bit messier but easier to administer and interpret. Ultrasound (UT) is another option, but again, will require some training. Even visual (VT) is not an 'out of the box' technique. We initially qualified some of our guys using Worldspec online, then they put in the hours.GoKats is correct, there is a milspec it is taken from, but I do not have it with me at the moment. Search "NDT testing mil spec" and you should turn that up.
You will need to pass a Jager eye test as well and have that documented (for all types).
johnson.tan
before you start you need to get all equipment ready and only having the main unit is not enough, you will need:
1) a dark room
2) operation procedure certifited by Level 3
3) burmer Castrol (I hope I spell correctly)
4)goss gauge
5)level 2 operator
Ok, at work now - our training plan contains this reference -
"1.1.1. This Training and Certification Plan developed as per instructions in SNT-TC-1A, and Mil.Std.410E."
SystemsQualityGuy
1) a dark room
4)goss gauge
5)level 2 operator
"Burmer Castrol"-Do you mean the oil burmah Castrol. What is the goss gauge used for? I assume the dark room is necessary so the fluorescent powder stands out. Are there manuals or instructions I can find online that shows how to set all this up?
Gauss gage is used to check the magnetic field and to eliminate the residual field after use. I do not use one since residual magnetism is not a concern for us. You can use a blacklight as a portable fluorescence source, although we only use that for DP, not MP. for MP we use Parker Research Magnetic inspection powder (red) under ambient lighting.
https://www.worldspec.org/ndt-training/ (worldspec site - note I am not affiliated)
G
GoKats78
Are you requirements for Wet or dry particle inspection?
If dry, no need for darkroom. It is typically a red powder.
if wet, you will need a UV light source (black light) that meets the requirements. We didnt always do the inspection in a darkened area..it depended on the requirements.
L Magnetic Particle Inspection - Where's the threads? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
F Defining the need to perform the Proximity magnetic fields immunity tests (IEC 61000-4-39) according to the IEC 60601-1-2 ed.4.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Laboratory intentionally skipped the Magnetic Field Immunity test IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
E Magnetic resonance imaging - RMI CE Marking (Conformité Européene) / CB Scheme 0
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Programmable CSF Shunts and Magnetic Field Interference with Implanted Hearing Devices – Letter to Health Care Providers Medical Device and FDA Regulations and Standards News 0
S Portable Magnetic Hardness Testers - Aerospace Manufacturing and Related Processes 4
A Labeling MR safe & MR Unsafe (magnetic resonance imaging topic) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Build own Power Magnetic Field Test Equipment for IEC 61000-4-8 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Titanium Implants MR (Magnetic Resonance) Compatibility Labeling US Food and Drug Administration (FDA) 2
S Magnetic Resonance ? Testing to ASTM F2503-08 Other Medical Device Related Standards 6
C Major NADCAP Magnetic Inspection Nonconformance - How to answer it? Nonconformance and Corrective Action 2
B Certificate of Analysis: Cuvettes & Magnetic Stirrers EU Medical Device Regulations 3
B MDD 93_42_EEC Annex 1 section 13.6 - Statement regarding Magnetic Resonance Registrars and Notified Bodies 4
A Quality Tagging Electronic Components - ESD (Electro-Magnetic Discharge) Concerns Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Magnetic or penetrant Flawdetection: Requirements of identification w/ letter M or P AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Particle Size Measurements General Measurement Device and Calibration Topics 13
A The particle analyst General Information Resources 4
A VDA 19.2 Illig value vs. allowed particle size VDA Standards - Germany's Automotive Standards 4
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
I Compressed air system qualification and 1 micron particle analysis Other Medical Device Regulations World-Wide 0
I FDA requirement for 0.5 and 5 micron particle monitoring US Food and Drug Administration (FDA) 0
M ISO 14644 Airborne Particle Count Testing Requirements Miscellaneous Environmental Standards and EMS Related Discussions 6
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
Ron Rompen Particle Size Templates General Measurement Device and Calibration Topics 7
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
N Requirements for the Classification of Cleanrooms other than the Particle Count Other ISO and International Standards and European Regulations 5
V Image Analysis - Particle Measurement (Characterization) - Validation - Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Hiac Royco 256 Particle Counter Calibrator Manual - Any Copies for Sale? Calibration and Metrology Software and Hardware 1
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
E Liquid Particle Counter - Which test is for OQ and which on is for PQ? Quality Tools, Improvement and Analysis 4
M Airborne Particle Counter Calibration - 5 microns particles aerosol General Measurement Device and Calibration Topics 13
S NADCAP and CCA (Particle Counting) in a Controlled Contamination Area - Standards AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Setting Control Limits for Particle Counts Statistical Analysis Tools, Techniques and SPC 9
D Which Handheld Air Particle Counter do you recommend? Other Medical Device and Orthopedic Related Topics 8
L ISO 14644 Result Sheets for Particle monitoring and related monitoring? Other ISO and International Standards and European Regulations 2
Q Interpreting calibration result of Air Particle Counter on Counting efficiency General Measurement Device and Calibration Topics 1
A Particle Counter Results - Interpreting Data for a Class 100,000 Cleanroom Other Medical Device Related Standards 12
C In-House Particle Counter Calibration General Measurement Device and Calibration Topics 12
ISOsandy ISO 14644-3 - Testing Air for Particle Counts Other ISO and International Standards and European Regulations 10
E Dust Particle Counter Model: Handilaz 301 Operation Manual General Measurement Device and Calibration Topics 3
D Gage R&R on a delta measurement - Particle measurement count tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Clean Rooms Training - Particle release (personel), Sedmentation velocity of particle ISO 13485:2016 - Medical Device Quality Management Systems 2
M Receiving Inspection Plan of COTS and SCH Help Various Other Specifications, Standards, and related Requirements 6
S Why do suppliers submit bad parts // Quality Incoming Inspection Supplier Quality Assurance and other Supplier Issues 12
U How should we build the FDA inspection preparedness team for FDA inspections at factories? General Auditing Discussions 0
K Equipment IQ/OQ/PQ required when you have 100% product inspection? ISO 13485:2016 - Medical Device Quality Management Systems 2
