Magnetic Particle Inspection - Where's the threads?
L
Lundberg
I'm researching mag particle inspection to see if this is a process that we would consider bringing in house. I did a forum search and almost nothing comes up. Does anyone out there perform mag particle inspection? Any suggestions on setting up the process?
Stijloor
Re: Mag particle inspection, where's the threads?
Hello Lundberg,
I've searched on "Magnetic Particle Testing" and this came up: Magnetic or penetrant Flawdetection: Requirements of identification w/ letter M or P
Read this article: http://www.sme.org/cgi-bin/find-articles.pl?&04dem004&ME&20041209&&SME&
Stijloor.
True Position
I preform some Magnetic Particle Inspection, were you looking at a portable unit or a wet flourescent bench type unit?
Generally the mag particle process is relatively easy to learn and easy to perform. Determine correct current, setup part, coat with fluid, press start, look for particle collection is really all it breaks down to.
L
Lundberg
Both, a wet bench for smaller parts and portable for larger parts.
True Position
My absolute #1 suggestion:
Sample parts, lots and lots of sample parts.
Brake shoes / Calipers are excellent sources for material with lots of very tiny stress cracks which show up beautiful with wet flourescent that they wouldn't have seen with the portable yoke.
A plate with a V cut into the back is good for contracting Mag particle with Die penetrant showing how it travels through thin material.
Nothing gets the point of how it works as actually showing it.
Anerol C
:thanks:Hi,
I'm looking for forms to input data on magnetic particle test and penetrating liquid test results?
Anerol
shunter - 2009
Can anyone tell me what qualifications personnel have to have, to be able to perform magnetic particle inspection?
shunter - 2009
I understand that there are training courses that are available for personnel to take, but what I am looking for is something that says to what level you are required to be trained to be able to 1) train other personnel 2) perform the process. Maybe you are not required to have any "official training" and just be trained on the job at your job site?
Jen Kirley
Quality and Auditing Expert
Stijloor has provided a good source to help understand Level I and Level II in NDT (magnetic particle is just one testing type in NDT).
Trainers and certifiers of personnel who need to work while holding qualifications are usually Level III NDT certified.
You don't need ASNT certs to work in the US. There are CGSB, PCN, and CSWIP technicians working in the U.S. What matters is your employer's and customers' requirements. You may want to check out getting ASNT ACCP certification. This is a nationaly recognized program.
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
R Closing out an API/ISO QMS Audit Nonconformance - Magnetic Particle Examination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Programmable CSF Shunts and Magnetic Field Interference with Implanted Hearing Devices – Letter to Health Care Providers Medical Device and FDA Regulations and Standards News 0
S Portable Magnetic Hardness Testers - Aerospace Manufacturing and Related Processes 4
A Labeling MR safe & MR Unsafe (magnetic resonance imaging topic) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
L Build own Power Magnetic Field Test Equipment for IEC 61000-4-8 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Titanium Implants MR (Magnetic Resonance) Compatibility Labeling US Food and Drug Administration (FDA) 2
S Magnetic Resonance ? Testing to ASTM F2503-08 Other Medical Device Related Standards 6
C Major NADCAP Magnetic Inspection Nonconformance - How to answer it? Nonconformance and Corrective Action 2
B Certificate of Analysis: Cuvettes & Magnetic Stirrers EU Medical Device Regulations 3
B MDD 93_42_EEC Annex 1 section 13.6 - Statement regarding Magnetic Resonance Registrars and Notified Bodies 4
A Quality Tagging Electronic Components - ESD (Electro-Magnetic Discharge) Concerns Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Magnetic or penetrant Flawdetection: Requirements of identification w/ letter M or P AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
I Compressed air system qualification and 1 micron particle analysis Other Medical Device Regulations World-Wide 0
I FDA requirement for 0.5 and 5 micron particle monitoring US Food and Drug Administration (FDA) 0
M ISO 14644 Airborne Particle Count Testing Requirements Miscellaneous Environmental Standards and EMS Related Discussions 6
S Cleanrooms - Particle Measuring - ISO 14644 Other Medical Device and Orthopedic Related Topics 3
Ron Rompen Particle Size Templates General Measurement Device and Calibration Topics 7
J Kanomax hand held Laser Particle Counter Calibration Calibration Frequency (Interval) 6
N Requirements for the Classification of Cleanrooms other than the Particle Count Other ISO and International Standards and European Regulations 5
V Image Analysis - Particle Measurement (Characterization) - Validation - Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Hiac Royco 256 Particle Counter Calibrator Manual - Any Copies for Sale? Calibration and Metrology Software and Hardware 1
K SPC to apply for Particle in Clean Room Class 100 Statistical Analysis Tools, Techniques and SPC 7
E Liquid Particle Counter - Which test is for OQ and which on is for PQ? Quality Tools, Improvement and Analysis 4
M Airborne Particle Counter Calibration - 5 microns particles aerosol General Measurement Device and Calibration Topics 13
S NADCAP and CCA (Particle Counting) in a Controlled Contamination Area - Standards AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Setting Control Limits for Particle Counts Statistical Analysis Tools, Techniques and SPC 9
D Which Handheld Air Particle Counter do you recommend? Other Medical Device and Orthopedic Related Topics 8
L ISO 14644 Result Sheets for Particle monitoring and related monitoring? Other ISO and International Standards and European Regulations 2
Q Interpreting calibration result of Air Particle Counter on Counting efficiency General Measurement Device and Calibration Topics 1
A Particle Counter Results - Interpreting Data for a Class 100,000 Cleanroom Other Medical Device Related Standards 12
C In-House Particle Counter Calibration General Measurement Device and Calibration Topics 12
ISOsandy ISO 14644-3 - Testing Air for Particle Counts Other ISO and International Standards and European Regulations 10
E Dust Particle Counter Model: Handilaz 301 Operation Manual General Measurement Device and Calibration Topics 3
D Gage R&R on a delta measurement - Particle measurement count tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Clean Rooms Training - Particle release (personel), Sedmentation velocity of particle ISO 13485:2016 - Medical Device Quality Management Systems 2
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Industrial RX inspection of welds (Oil&Gas industry) Reliability Analysis - Predictions, Testing and Standards 0
C In-process inspection - Tooling and assembly lines for automotive companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
