Main responsibility for Control Plans - creating and maintaining
Booker
Dear in Cove,
Which department in production organization should be mainly responsible for the process development and to describe the process by Process Flow Charts, PFMEAs, and Control Plans? The approach by CFT is considered. But, there is no common agreement for main responsibility.
Thanks for your hints.
Emmyd
In my experience, it really depends on the size of the company and the corporate structure. In a Tier 1 where I worked, the Quality Engineer created the process flows and the control plans (which also doubled as our first piece sheets and hourly check sheets) but the ME's in Engineering created the DFMEA and the PFMEA. But this was larger staffed plant with a fairly large corporate structure.
At the Tier 2 I work at now, we have many fewer staff and one of the following Quality Engineer/Tech/Manager is responsible for the PFMEA (no DFMEA), process flow, control plans along with everything else that goes into a PPAP - including packaging.
I think it works really well to have a team approach to process development, but you have to identify a champion who makes sure that the work is done. There should be a defined responsible party - it may work better in Engineering or it may be better in Quality. There should be a common goal of making sure the customer and the company are covered regardless of who does the work.
If you are an automotive supplier, how are the PPAPs handled?
Booker
Cross-Functional Team for CFT.
PPAP is another story in our organization. As it seems that PPAP is a goal, which means we need to do paperwork, not developing a process. That means everything is done from a table. Except for the measurements of the product for its validation. The usual question to me as a quality staff is. "When PPAP will be done?" Then my answer could not anything else, like. "Did you finish process design and development stage?". But, this is really another story.
Back to process development. What I do not understand is that quality staff should be responsible for process flow diagrams? Is the quality the key know-how owner for production process? Then to PFMEA - are not the process engineers knowing technology and are know-how masters knowing what can go wrong? And then Control Plans. For me, Control Plan is a list of important steps derivated from PFMEA which has to be focused on? Not a list with only checks, measurements, and tests.
outdoorsNW
Depending on the structure of your company, departments such as design engineering, manufacturing engineering, machine programing (at some companies the programmers figure out some to all of the process flow) need to be involved.
Having said that, at my last company quality created the process flow by extracting the information from the shop floor control system entered by other groups. Quality also used that information to start the PFMEA (no DFMEA) and control plan.
Some work centers had risks and controls that were always present so quality inserted standard information into the FMEA and Control plan.
Ideally engineering would take the lead on PPAPs but the reality is quality ends up being the leader.
Engineering frequently knows nothing about creating PPAPs, FMEAs and control plans. I asked a bunch interns what they were being taught, and most had no exposure in school.
Some engineers want nothing to do with FMEAs and control plans. There was one engineer I sent fill in the blank type requests for information, where all the engineer had to do was provide me with the min and max for something, and I could not get a response. And the engineering manager was no help. My boss went up the chain of command to get an answer for me. The engineering manager was fired a few months later. (No idea how much this contributed to the firing.)
I
inspector 2s
In my experience, anything that starts or has the word QUALITY in it, then unfortunately, it is easy to back heel it to inspection/quality department.
Coury Ferguson
Moderator here to help
Process flows should be under the Manufacturing Engineers, the PFMEA should be under the Process Engineers, and the Control Plans should be under the Quality Engineers. This however, is sometimes not practical depending on the size of the organization. Some organizations like the one I work for the Quality Engineers do all of that with the support of the Plant Engineer. Just my opinion.
P
patricks
^ Thats been my experience as well.
At one point we decided to use a cross-functional team for PFMEA (R&D, ME, QE and an experienced associate). It didn't work out, the meetings were a lot of talk and no agreements. So Quality ended up finishing it on their own. But I think CFT is ideally the right way to do it. In our case, we apparently didn't work well together.
optomist1
A Sea of Statistics
Wow great replies...ain't this site great....for my 2 cents...
-DFMEA - Design Engineering Leads..all others follow and support their lead.
-PFMEA - Quality...more specifically Quality/Product Assurance leads or co-leads with the repsonsible manufacturing engineer...all others support
G Why 1 MOPP to main voltage but 2 MOPP to working voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E Supply chain main policies ,scope, risk assessments & relavant KPI Supply Chain Security Management Systems 2
S SAE AS13004 vs. SAE J1739 - What are the main differences? FMEA and Control Plans 0
Aymaneh ISO 11607-1: 2019 main changes Other Medical Device Related Standards 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Start and main steps of API Q1 Certification Process Various Other Specifications, Standards, and related Requirements 5
H IEC 60601-1 Main Power Cord Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E IEC 60601 Main requirements for the certification of a device with a Li-ion batt IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S IEC 60601 Main requirements for Lithium Ion Battery Powered Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A VDA 4 and PFMEA - What's main difference? VDA Standards - Germany's Automotive Standards 0
M Can a Consultant be the main contact for a Medical Device Company? Other Medical Device and Orthopedic Related Topics 6
M Kinds of plastic for molded parts in a main frame as structure Manufacturing and Related Processes 7
L How document an additional software of my main device software?? IEC 62304 - Medical Device Software Life Cycle Processes 3
B Applications required for main accessories (electrodes) of CE Medical Products EU Medical Device Regulations 4
D Definition Engineer's Main File Definition - What is an "Engineer's Main File"? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
O Main difference between X-bar sigma chart / X-bar range chart Statistical Analysis Tools, Techniques and SPC 4
S Can there be 2 Quality Management Representatives (Main and Sub) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Description of Main Elements of OH&SMS and their Interaction (Documentation) Occupational Health & Safety Management Standards 6
A The main functions and tasks of a Regulatory Affairs position Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
K What are the Main Reports for Production Monitoring? Manufacturing and Related Processes 5
Q APQP Compliance Internal Audit - Ideas, check lists or main questions to prepare APQP and PPAP 9
A Main Effect - Interaction Plots - 2 Level Factorial DOE with 18 Runs Using Minitab Software 8
E What are the main reasons to update data in MDS Sheet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
C Certification process for small consultancy practice far away from main cities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Questions asked in the main audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B ISO 9001 or ISO 9004? What are the main differences? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
G FMEA 3rd edition vs 4th edition - What are the main changes? FMEA and Control Plans 2
G APQP 1st edition VS APQP 2nd edition - what are the main changes APQP and PPAP 2
Q Zero-Based Sampling Plan - Governing document or main reference document Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H Regarding: Describing Graphical Overview and Capability Analysis for main dept leader Quality Manager and Management Related Issues 1
A Guidance on using Turtle Diagrams for Internal Audits (main & sub processes) Process Maps, Process Mapping and Turtle Diagrams 11
N Checking Runout on Internal Bore of Main Shaft Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
J Main Map and Major Process Maps or Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 5
D Main Elements of an EMS - ISO14001 Clause 4.4.4 c) Auditor Interpretation ISO 14001:2015 Specific Discussions 20
S What are the main differences between the Control Plan and the Quality Plan? IATF 16949 - Automotive Quality Systems Standard 2
R ISO 14001 Clause 4.4.4c - Interaction of Main Elements: How to Demonstrate? ISO 14001:2015 Specific Discussions 4
Q Main changes in the new ISO 14001:2004 ISO 14001:2015 Specific Discussions 2
S Six Sigma and Software Development - How to set the metrics for each main process Six Sigma 4
D Possible to list remote manufacturing locations on the main location certificates? IATF 16949 - Automotive Quality Systems Standard 9
C ISO 9001:2000 - Main goal of a communications process in any organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Roving Audits - Main functions is to audit the manufacturing process General Auditing Discussions 18
M Procedure Development Methods - What are the main things that go wrong? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Registrar's Auditors Main Interest - Football Hall of Fame - Little Work Registrars and Notified Bodies 96
JoCam Responsibility for Distribution Agreement EU Medical Device Regulations 2
Evelyn7E Quality is everybody's responsibility Philosophy, Gurus, Innovation and Evolution 29
Q Private Labeler FURLS Responsibility-USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V UDI - OEM or OBL / Legal Manufacturer Responsibility CE Marking (Conformité Européene) / CB Scheme 0
T ISO 13485 - 5.5.1 Responsibility and authority - Small Company Independence ISO 13485:2016 - Medical Device Quality Management Systems 13
B Product Safety Responsibility - Job shop such as a machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
